Local Time 07:46 22 Oct 2026 Privacy Policy
Forum Index : Electronics : F&P wiring / output voltage conversion choices
flyingfishfinger
Posted: 08:50pm 01 Jun 2021
Hi all-
Been thinking about this for a while and I can't really figure out how to proceed. Since I'm starting to make some progress on the DIY MPPT for my PV, I was going to just build a 2nd one for the micro hydro while I'm at it.
However, it's become clear to me that the input voltage options complicate this somewhat for the latter.
Basically, the unmodified F&P outputs 380V AC, 3-phase, unloaded. I'd like to keep it unmodified so I don't lose too much power between my water location and the battery, which are at best ~200 feet apart.
If I rectify this voltage, I'll end up with a max of over 500V DC that I don't quite know what to do with unless the MPPT can be built with IGBTs to handle this much input.
I've put an alert on Ebay & Craigslist for 3-phase tranformers, but those are rare and very pricey in the ~500W power levels.
What other options do I realistically have here?
R
Posted: 09:09pm 01 Jun 2021
It will only generate 380v at flat out maximum rpm.  I have no idea how fast the spin dry cycle is on the highest of the three speeds, but its fairly fast.
Output voltage will be proportional to rpm, so the actual voltage you end up with will probably be a lot lower. A lot also depends on the circumference of your hydro and how fast the water speed.
Best to just put it all together and run some tests and see what you get.  Then change things accordingly.  Too many unknowns at this stage.
flyingfishfinger
Posted: 09:12pm 01 Jun 2021
  Warpspeed said  Output voltage will be proportional to rpm, so the actual voltage you end up with will probably be a lot lower.
I did this test at 500RPM. Even if the actual use case IS much lower, shouldn't the system be designed to handle the no-load case for safety? That's what I'm asking about, effectively.
But yes, next opportunity to take measurements is in a month - just trying to plan ahead best I can.
R
Edited 2021-06-02 07:15 by flyingfishfinger
Murphy's friend
Posted: 08:12am 02 Jun 2021
Can you put a centrifugal brake on the shaft?
BenandAmber
Posted: 09:08am 02 Jun 2021
Keep in mind I am just a monkey see monkey do jack leg among giants on this forum
I have gave a similar thing some thought
I have several similar motors
I have been debating with myself to use one or two of them for a windmill
Or to use a 2 to 3 hp 3 phase induction motor that I made into a alternator
I turned down the rotor just enough to add small high temp motor magnets to it
The small rectangular magnets are in rows to exactly cover just the iron part of the rotor
I tried to make it just like I imagined it would be magnetized by stator when running as a motor
It does a really amazing job when turned or just rocked back and forth with two fingers
It will light up a large led flood bulb or a regular filament bulb out of a old microwave
My thinking was the permanent magnets would start a currant in the stator at low speed when driven as a alternator
This current in stator would then   cause the iron core of the rotor to become magnetized adding to and becoming much greater than the small permanent magnets
My thinking was it would have low to no cogging because of the small magnets
Then as the rpms go up so would the strength of the magnetic field in the rotor
I always have several projects going on at one time and haven't made it back around to testing it
I wrote about it because testing it turning by fingers or hand seem very promising
If my hair brained induction magntizing rotor at low speeds idea doesn't work out
I still think big strong magnets on a three phase motor that the original rotor has diagonal instead of straight lines would make a very good choice for home made alternator
That's what run on sentence should look like lol still king lol
The rpms and the resistance of the load will determine the voltage and amperage of the output of your alternator motor
Fisher and Paykel Samsung have many poles
When running as a alternator the rpm along with numbers of poles will determine the Hertz of the ac output
The number of north south poles for one complete turn and the rpms determine the Hertz
The higher the frequency Hertz the smaller the transformer can be for the same wattage amps volts watts
This may have to be considered when choosing one bigger or three smaller trannys to step down the three phase ac voltage
Regular transformers laminated steal or iron that are used at 50 or 60 Hertz are not good for alot higher frequency or herts
They will loose energy by heating up
This is called over saturation
Some say only frequency causes saturation
Others say current can cause saturation
My hair  brained thinking thanks that the higher the amperage magnetic the lower the capacitance voltage
When one rises the other falls
when the capacitance and inductance are turned perfect in the choke to absorb the flip-flopping
you won't see any ac voltage on the battery cable going to your inverter
capacitance in the non-magnetic and amperage in the magnetic
this is my  understanding what is happening in a inverter choke
I would like to read a back and forth between the greats on here about it
The material the core is made of determines how high the frequency can be
The higher Hertz transformers are usually some type of ferrite
Alot less magnetic but much higher in capacitance when voltage is flipping
if you want lots of energy you think big but it is truly in the small or not here at all or we could be swimming in it
but don't know it like a bird on a wire lol
There are countless mixtures of ferrite cores made
You have to pick the one best suited for the job
To pick the best one best suited you must know the voltage amperage frequency "herts"
And all of these will change when the load or resistance changes
So this comes right back to the answer you was already given by a great lol
Now if you really want to do something find a way to keep the load from affecting the rpm no cogging or back emf
You can change the phase angle with respect to time like to add a phase to a motor by adding a capacitor
The two parts that make up electric do not travel at the same speeds
This can be proven with many capacitors and inductors in series and parallel configuration
two rows of capacitors connected end to end with inductors connected in between like runs of a ladder across the two rows of capacitors
Or you can hook the inductors in two long rows and the capacitors being the runs of the ladder
This proves you can slow down or speed up each of the two parts needed to have electricity
The magnetic is the amperage it spirals down the line the capacitance is the voltage part it goes straight
When you short out a coil of a tranny the voltage drops and amperage goes really high
the tranny may even jump around if really bad you may need a clothing change
when you open a switch the voltage rises high enough to jump through air
as a spark
the higher the magnetic or amps and or voltage on the line of the switch being opened the bigger the spark
The voltage will continue to rise to Infinity if it had to to let the magnetic get out
This different speeds happens 24 7 on the grid
This along with high voltage maybe how the grid overcomes the massive amounts of resistance in every foot of wire from Power Station to where the power is used lol
Now keep in mind any of the above info could be wrong this is just my understanding
I really like it when I am wrong this means I am getting a more accurate understanding of the relentless never ending search for how things truly work
Thanks for your time
Edited 2021-06-02 20:12 by BenandAmber
