Local Time 03:59 22 Oct 2026 Privacy Policy
Forum Index : Electronics : so what's the furthest you've done a radio link with fleabay modules?
CaptainBoing
Posted: 08:03am 29 Nov 2021
Quite an interesting read.
https://www.theregister.com/2021/11/24/lora_to_the_moon/
and, largely unrelated but a face-palm, this was linked from that article... https://www.theregister.com/2021/02/19/airspeeder_alauda_drone_investigation_with_photos/
the pictures of the quality of work are shocking.
Edited 2021-11-29 18:14 by CaptainBoing
Pete Locke
Posted: 06:06am 30 Nov 2021
A great read thank's.
Posted: 11:27pm 02 Dec 2021
Pictures are truly staggering - erk....
Those prototyping boards should only ever be used to prove a concept on the bench IMHO.  Most of the prototype things I build, I still design an "A" variant PCB for them, then fix anything I find wrong in the "B" variant.  Point is, I get a professional PCB made even when I am prototyping anything.
I don't think I would be comfortable designing wireless links for a drone though, cos as this case has shown, one bad bit of design COULD potentially put commercial aircraft at risk - that could have ended REALLY BADLY if it strayed into the path of an aircraft....yikes....
In addition to the kill-switch, I would have liked to have seen at least some kind of altimeter kill-switch thing, so if you lost all wireless control, and it happened to climb higher then a certain height, the altimeter thing would kill the power, and the drone would fall out of the sky - but not be able to climb up into the habitat of the commercial aircraft.
But then, I would not be doing drone controls anyway!
