Local Time 03:08 22 Oct 2026 Privacy Policy
Forum Index : Electronics : Couple of IGBT's For Your Next Inverter Project.
Chopperp
Posted: 12:29pm 17 May 2022
I'm no where up to date with (really) high powered electronics so I was quite impressed with these two IGBT's from Infineon as show cased in EW.
The data sheets make interesting reading. Of course, there are higher powered devices available.
Brian
ChopperP
Haxby
Posted: 06:13am 19 May 2022
Absolutely gorgeous aren't they?
And still only 3v drop at 2000 amps.
Blast proof case? Hmmmm maybe not in my hands
I wonder how they are mounted. I can't see any screw terminals. Maybe sandwiched in a proprietary holder heatsink combo.
Posted: 12:25pm 19 May 2022
"I wonder how they are mounted."
High power SCRs have been in that package for about 40 years, we called them hockey pucks. There are many kW of heat to get rid of so they are clamped between two water cooling blocks with special bolts. They have just the right amount of stretch to maintain the right pressure over a wide temperature range. if the pressure is too high the chip cracks and if too low the thermal resistance rises. The silicon "chip" is almost the same diameter as the package.
Haxby
Posted: 09:17pm 19 May 2022
  phil99 said  "I wonder how they are mounted."
Is there a technical reason MOSFETs can't be built to this size? I only see small ones.
Posted: 11:58pm 19 May 2022
"Is there a technical reason MOSFETs can't be built to this size?"
Just a guess, I imagine gate capacitance would be huge and very difficult to drive.
Another detail for the SCRs, the two faces of the puck are anode and cathode so the cooling blocks are the connections and can have more than 1kV between them. The bolts had large teflon bushings and the cooling system used distilled water and teflon tubing.
Chopperp
Posted: 11:54am 20 May 2022
Thanks for that info Phil. Interesting.
I know when cooling high powered RF transmitters, special precautions have to be observed including the use of distilled water & very good insulation.
@ Haxby, I suppose they are a bit gorgeous....
ChopperP
