Local Time 21:22 21 Oct 2026 Privacy Policy
Forum Index : Electronics : High idle power revisited
Murphy's friend
Posted: 08:07am 06 Sep 2023
A while back I posted about my 6KW inverter having an unexpectedly high standby power.
This I 'cured' by increasing the dead time capacitor. This inverter is now powering my house and working fine but wiseguy and others were not convinced I made the right 'cure'.
Now, experimenting with my 3 KW inverter, which is very similarly built, just a smaller toroid transformer, I notice it too had an unacceptable high idle power. Worse than my big inverter had in fact.
Sooo, having time on my hand, I started checking parts. Nothing faulty was found, dead time capacitor changes made little difference and in the end the problem was pinned to the mosfets alone.
They are mounted on carrier boards so they can be exchanged without resorting to messy soldering fixes (one of my better ideas ).
Here is how they look, there are four identical boards:
This board is fitted with IRFP4468PbF mosfets. All 4 boards test faultless when driven by a 20KHz, 50% duty cycle square wave. As load I used LED car brakelights with suitable dropping resistors so testing could be done at 55V DC.
But, driving the mosfets from the symmetrical control board output (either NANO or EG8010 derived), the inverter takes too much idle power.
Now the really strange thing, if I replace those carrier boards with ones fitted with new HY4008 mosfets the idle power is where it should be.
As the IRFP4468's had been in use for some time previously I wonder if these things change in some way. Still switching 20KHz square waves but not what the control board feeds them.
Or is it something entirely different?
poida
Posted: 10:06am 06 Sep 2023
I see a rather large difference in
turn on (& off) delay and rise times between the IRFP4468 and the HY4008
The test conditions for the parts are different so it's apples and oranges
but it surely must give some guidance...
IRFP4468: tested at Vgs = 10V, Rg = 2.7 Ohms
turn on delay: 52ns
rise time: 230ns
turn off delay: 160ns
fall time: 260ns
HY4008: tested at Vgs = 10V, Rg = 6 Ohms
turn on delay: 28ns
rise time: 18ns
turn off delay: 42ns
fall time: 54ns
clearly the HY4008 will switch a lot faster than the IRFP4468
total Gate charge is 195nC for the HY4008
and 360nC up to 580nC for the IRFP4468
I think the slower switching IRFP4468 require a longer deadtime than what you have designed. The shoot through is causing the high idle power consumption.
Edited 2023-09-06 20:08 by poida
Murphy's friend
Posted: 10:26am 06 Sep 2023
Thanks Poida, your expertise is very welcome.
At last I have an explanation, in my ignorance I did not check these important specifications.
I will do some more research with larger dead time capacitors.
I wonder if you could do me a favor and check the data for an IPTC014N10NM5 with respect to possible dead time problems.
I'm considering using those for a compact inverter.
poida
Posted: 10:48am 06 Sep 2023
IPTC014N10NM5 seems to be fast switching and moderate Gate charge.
Vgs = 10V Rg 1.6 Ohms
turn on delay: 36ns
rise time: 30ns
turn off delay: 85ns
fall time: 30ns
168 nC total Gate charge
it appears that to get this fast switching you will need a
high current Gate drive design, and use 1.6 ohm resistors
to drive them hard.
100V, 1.4 mOhm and very large pulsed current rating, over 1000 Amps..
I can't help but suggest you get a decent DSO to observe deadtime
as seen at the FET's Gate pins to be completely certain there is
no shoot through from your designs.
Solar Mike
Posted: 11:09am 06 Sep 2023
Those IRFP44XX series mosfets have a multiple die arrangement inside them, the resulting large gate charge characteristic requires a very meaty gate driver; as you have 4 in parallel then perhaps your driver chip or transistor buffer cannot supply enough current to get them to switch quickly, needs to supply >10 amps peak @12v.
As Poida say's you need a good scope to test this.
Murphy's friend
Posted: 03:14pm 06 Sep 2023
Thanks poida, appreciate your comments.
A Rigol DSO like you have would be nice but its outside my hobby fund range. I was looking at the Hantec DSO and wonder if that would be suitable, also what kind of probes will I need to see the switching at the gates of both mosfets since they have no common ground?
Murphy's friend
Posted: 03:24pm 06 Sep 2023
It won't let me update my last post but its this DSO
Murphy's friend
Posted: 03:32pm 06 Sep 2023
Sorry about the no find link above - this forum's editing feature does not like me.
Anyway, I was looking at a Hantec DSO2C10
poida
Posted: 02:45am 07 Sep 2023
yes, something like that will do the job.
2 channels and external trigger input.
Assuming your gate drive supply is 15V...
set both channels to 5V/div
ch1 is on the low side Gate, the ground clip is on DC supply ground
now, to get the high side Gate signal, we must keep in mind that
this signal rides on top of DC+ supply, potentially 57V
The Gate signal goes from 57V to (57V + 15V)
again, put ch2 ground clip on DC supply ground.
I am lucky to have some isolated probes, which can be used to remove this 57V offset.
But when you don't have these, you need to use the DSO vertical offset to the maximum
to bring the high side Gate signal to the same DC level as the low side.
I see in the Hantec's user manual the offset range is +/- 50V for 0.5V to 10V/div
and so this is just what you need.
Set both channels to 5V/div, use the offset to bring the high side gate down 50V.
Line up both signals vertically and then you will be able to see
the two Gate drive voltages. as the FETs are switched on and off.
This will show if there is much overlap (causing shoot through and high idle loss)
you could have test setups that feed a constant PWM width,
in which case you could just use ch1 to trigger off of.
Or maybe you want to see how it goes for an entire 50Hz output cycle
(approx 400 PWM pulses), so I would use the 50Hz square wave output from the
EG8010 or pico/nano to trigger off, using the external trigger input function.
The DSO has 4M memory when using both channels so it will give you a good view
of what is going on over a long period of (sample) time.
Murphy's friend
Posted: 07:47am 07 Sep 2023
Wow poida, info like this is gold for somebody like me. Thank you for taking the time, I have printed out your reply to have handy when I get my hands on that DSO.
Regarding my high idle power problem, your suggestions did the trick   .
Using 2.2 Ohm gate resistors and 10nF dead time capacitors the idle power of this 3KW inverter is now 19W, running with 16  IRFP4468 mosfets.
And I learned a fair bit in the process to getting this result, thank you all for your valuable input.
