Local Time 21:22 21 Oct 2026 Privacy Policy
Forum Index : Electronics : 2sd313. Equivalent
irishron40
Posted: 10:06am 31 Oct 2023
Hi ,  could I use a tip41C. Instead of a d313?
I think both base voltages are 5volt
Ron
SimpleSafeName
Posted: 11:45am 31 Oct 2023
Looks like the TIP41C is superior with the exception of gain. I didn't see a spec for the transition frequency of the TIP41C though.
And these guys seem to think that it would do as a replacement:
https://audiokarma.org/forums/index.php?threads/2sd313-replacement-when-used-as-series-pass-transistor-in-power-supply.688206/
