Local Time 22:26 21 Oct 2026 Privacy Policy
Forum Index : Electronics : 1996 SLA bat. ex scrap yard
domwild
Posted: 07:16am 16 Apr 2009
This SLA batt. showed 11.7V but has a 1996 sticker on it. Is it worthwhile to offer some money for it at the scrap yard? Read on this forum or Fieldlines, that a flooded lead-acid batt. with 10.5V in it can still be resurrected.
What about other SLAs in the yard with 4.5V or slightly higher voltage readings???
Thanks.
Winston Churchill
Bernie the Bolt
Posted: 07:54pm 30 Apr 2009
Hi Dom, I have no experience with sealed lead acid, but anything over 10.5 v can be partly or fully restored with a pulser, but be warned it can take several months on trickle charge with pulser (desulphater) to do this. I have had some success with ex camper van batteries. but I do not bother with anything that reads less than 10.5 volts initially. (I think this indicates a shorted cell) Sometimes a battery you have good hopes for will suddenly lose voltage whilst undergoing desulphation - again this is due to a shorted cell, this is caused by dendrites (wahtever they are) but I understand a pulser based on the pic log can avoid this (it shorts the battery in ms pulses, wich prevents the dendrite build up)The pulser I use is from enquiries@courtiestown.co.uk
Bernie the Bolt
I'd rather be sailing!
domwild
Posted: 06:40am 02 May 2009
Thanks, Bernie for that. Have followed the desulphator page, which now has moved. Interesting stuff!
Winston Churchill
