Local Time 23:19 21 Oct 2026 Privacy Policy
Forum Index : Electronics : A simple charge controller
Russell
Posted: 11:15pm 15 Aug 2009
Just put one of the charge controllers together and having some trouble. As soon as I apply power,the R1 12k frys. It all looks good, no dead shorts or connections crossed. Using 1/4 watt resister, don't know if that is correct or not. thanks for any help.
Robb
Posted: 12:02am 16 Aug 2009
What are the colour bands on your '12k' risistor?
Russell
Posted: 12:07am 16 Aug 2009
Hi Robb looks like brown,red,black.gold. Thanks
Posted: 12:43am 16 Aug 2009
Thats a 12 ohm resistor, not a 12k ohm. It should be brown red orange gold/silver ( the last one is the tollerance )
http://www.thebackshed.com/Windmill/Docs/ElectricComponents. asp
Russell
Posted: 12:57am 16 Aug 2009
thanks Glenn I will try it with the wright resistor
Robb
Posted: 05:59am 16 Aug 2009
Ok so what colour is your 3.3k. I'm thinking it must be wrong too to be able to smoke the 12 ohm above it.
Russell
Posted: 04:54pm 16 Aug 2009
Yes its wrong to, Got a good lessen in reading color codes on resistor. Going to spent some time tonight swapping out resistor. Bear with me guys,got a lot of good idea's but little slow on the learning curve.
timbo
Posted: 02:31am 17 Aug 2009
I'm trying to find the parts to put one of these together (24 volt version) and I have found everything but the DB139. I have tried several searches for it and subs but haven't found it. Everything else I have found at newark.com
Can anyone tell me where to find it? Or a sub I can use?
Russell
Posted: 03:46am 17 Aug 2009
Timbo try this place they seen to have everything under the sun. http://www.mouser.com/ And timbo its a BD139 not a DB, I think its a miss print on the veroboard layout. Also the R1 12k on the veroboard layout is marked as a 10k, I think this is correct but Im a Newbie to, maybe some one with more know how got confirm is.
Robb
Posted: 01:11pm 17 Aug 2009
The sections of the opamp are transposed too. 1/4 and 2/4 are swaped on the layout. It dosn't matter apart from creating confusion .
timbo
Posted: 03:33pm 17 Aug 2009
Thanks for the help. Now with the correct part # I found everything I need at Newark for about $14.00.
Any idea what kind of power this will handle? From looking at the scematic it looks like the relay needs to be able to handle the power. I hope to get 500W out of my generator so I better be sure I have 40A relay.
Russell
Posted: 04:45am 18 Aug 2009
It works! Amazing what happens when you use the right parts. Thanks for the help, next thing is to hook this up to my turbine and start charging batteries.
Posted: 05:30am 18 Aug 2009
Hey Russell, happy to hear it. You got to watch those resistor color codes. The 5 band resistors are a real nightmare.
Timbo the output is limited by the relay, your right. The BD139 will drive a typical 12v spot light relay, anthing bigger and you could use a smaller relay to switch a bigger relay.
readyakira
Posted: 05:04pm 20 Aug 2009
Can ya post the link to the controller info you used? It sounds like a relativly simple circuit you designed...
Don't you think Free/Renewable energy should be mandatory in new buildings?
Russell
Posted: 03:01am 22 Aug 2009
readyakira the link is http://www.thebackshed.com/Windmill/articles/TL084-Controlle r.asp this is the same place that this form is on.
