Local Time 00:10 22 Oct 2026 Privacy Policy
Forum Index : Electronics : Voltage drop calculator
Smart Drives
Posted: 09:34pm 31 Aug 2009
Just found this calculator has a few more options
than most.
http://www.csgnetwork.com/voltagedropcalc.html
All smart drive parts sold
Custom built turbine parts on
Multicam flatbed CNC Router
Smart Drives
Posted: 10:00pm 31 Aug 2009
just thought i would put this here to help
some people with the calculator.
wire thickness chart.
AWG--------mm2(cross sectional)
0---------53.46
1---------42.39
2---------33.61
3---------26.65
4---------21.14
5---------16.76
6---------13.29
7---------10.55
8---------8.36
9---------6.63
10--------5.26
11--------4.17
12--------3.31
13--------2.63
14--------2.08
15--------1.65
16--------1.31
17--------1.04
18--------0.82
19--------0.65
20--------0.52
21--------0.41
22--------0.33
23--------0.26
24--------0.20
25--------0.16
26--------0.13
Edited by Smart Drives 2009-09-02
RossW
Posted: 05:43am 01 Sep 2009
  Smart Drives said   just thought i would put this here to help some people with the calculator.
0---------53.46
1---------42.39
... etc
For those who have/use IRC, my bot can help with these things too. Converting to/from AWG, resistance etc.
15:35:40-1/09/09| <RossW> !awg 4/0
15:35:40-1/09/09| <RossBot> 0000 (4/0) AWG wire is
0.166191 square inches (107.219553 square mm,
11.684019mm dia), 0.156501 ohms per Km Cu
(0.247623 Al)
15:36:50-1/09/09| <RossW> !awg 12
15:36:50-1/09/09| <RossBot> 12 AWG wire is 0.005129
square inches (3.308781 square mm, 2.052529mm
dia), 5.071355 ohms per Km Cu (8.024104 Al)
15:37:39-1/09/09| <RossW> !2awg 4
15:37:39-1/09/09| <RossBot> 4.000000 sq mm (0.006200
sq inch) wire is 11 AWG, 4.195000 ohms per Km Cu
(6.637500 Al)
it also can do your standard volts/ohms/amps/watts by taking any two and telling you all the others:
15:39:10-1/09/09| <RossW> !ohmslaw 400w 25.6v
15:39:10-1/09/09| <RossBot> 25.600 volts at 15.625 amps
through 1.638 ohms for 400.000 watts
and wind power, air density and a heap of other things. (And there's usually someone to chat to there too!)
irc server: irc.albury.net.au
channel: #aussiere
