Local Time 02:10 22 Oct 2026 Privacy Policy
Forum Index : Electronics : Stepper motor
pacco1
Posted: 05:24pm 16 Oct 2009
i have 6 wire stepper motor and i don't know are they + or - wires wire colors are brown,pink,blackred,orange and yellow.somebody can help me?
floodrod
Posted: 05:30pm 16 Oct 2009
+ and - don't matter. You need to get 3 bridge rectifiers and hook up each phase to it's own rectifier.
Use a multimeter and see which leads tone out. You will have 3 pairs of 2.
Run each pair to a bridge rectifier then combine all three + outputs together and all 3 - leads together. This will give you lower volts, but higher amps.
If you want higher volts and lower amps, hook the outputs up in series. +-+-Edited by floodrod 2009-10-18
Posted: 11:51pm 16 Oct 2009
This page may help...
http://www.thebackshed.com/windmill/assemblyMini3.asp
Downwind
Posted: 03:24am 17 Oct 2009
Just measure the resistance with a multimeter between one wire and the rest and you should find two other wires will give a resistance reading.
These three wires are one half of the motor.
Do the same for the remaining three wires.
You should now have 2 groups of 3 wires.
Use the 2 wires in each group that have the highest resistance reading between them.
Leave the lower resistance reading 2 wires unused.
Sometimes it just works
