Local Time 01:01 22 Oct 2026 Privacy Policy
Forum Index : Electronics : parts needed
Tonda
Posted: 02:46pm 15 Nov 2009
Parts needed
Gentlemen,
I just joined you forum today. I need 2SK 3061 N-chanel Mosfet and I found some article about it dated in 2005. You said that it is available in Australia then.
I can not find it in Canada. Any help will be appreciated. I would need 40-50 pc. for my project.
Kind regards, Tony at www.radiodoctor.org
Tony
KarlJ
Posted: 06:17am 16 Nov 2009
Jaycar lists a
2SK1058 N channel mosfet rated at 7A
at $16.35 in quantities of 25+
or an IRF540N rated at 100V 33A for $4.75
or STP16NE06 60V16A at $1.85
try www.jaycar.com.au
GWatPE
Posted: 08:50am 16 Nov 2009
What purpose are the mosfets for. General low voltage, low frequency swithing allows many options. More info will allow a better solution.
Gordon.
become more energy aware
Tonda
Posted: 03:29pm 16 Nov 2009
Gentlemen,
Thanks for your help. I was trying to get it locally from US or Canada for last 2 weeks, but no luck. I just got about 100 quotations from Hong Kong, ranging from 0.25 cents to $2.50. They all want to sell me something,and ship it the same day , where in Canada or US nobody cared.
This N-channel mosfet will be used to make solid state vibrators for old tube car or home radios. The reason why I tried Australia was article from 2005 on your site by Dom? There is a guy in AU selling vibrator kits, but after several e-mails, no reply. I guess he does not want to sell to Canada and does not care.
Kind regards, Tony
Tony
Posted: 12:12am 17 Nov 2009
Hi Tony
Do you have a link or contact for the Australian article, I can look into it for you.
I have a passion for old valve radios, I have several, most work, some need a little TLC.
Tonda
Posted: 01:56am 18 Nov 2009
Hello Glen,
All I have is the e-mail to this man in AU, who sells vibrator kits. I do not have his website.
E-mail is xxxx.au
His name is Tony Maher.
Regards, Tony at www.radiodoctor.org
Edited by Tonda 2009-11-22
Tony
9c12m
Posted: 02:04am 18 Nov 2009
There maybe some related information at this site:
http://www.portabletubes.co.uk/sitefiles/ausbatt.htm
D
Robb
Posted: 03:15am 18 Nov 2009
Glen is there a way to PM email addresses and stuff like that? That guy is now spam bot fodder.
Tonda
Posted: 01:47pm 21 Nov 2009
I am sorry Robb,
I did not know that forums could be picked up by spammers . I removed Tony's email. If anybody needs it, please contact me.
Edited by Tonda 2009-11-23
Tony
Dinges
Posted: 06:47pm 21 Nov 2009
Tonda,
It sounds to me that any old FET (N-channel) should work. I had a look at the datasheet ( http://www.datasheet.org.uk/pdf-datasheets/Datasheets-306/93 603.pdf) and the Id=35A (70A peak) seems overkill (never mind the fact that 35A continuous from a TO220 package is wishful thinking - a bunch of STE45NK80 FETs happen to be lying on my desk - 45A, but in ISOTOP package....)
If you'd post the schematic people could make a better guess at the needed ratings for that FET, but 35A (continuous) seems to be way overkill to me for a vibrator that only has to power the filaments and anodes of 3-5 valves.
Sounds like any old FET of 200V/10A should work, but if you post a schematic we can determine for certain.
Seems *very* unlikely that the 2SK3061 is the only part that would work - most likely any generic FET with suitable ratings will do the job, be much easier to find and a whole lot cheaper to boot.
Peter. (<-- spent the better half of the day wondering why he kept blowing up tantalum elcos and TTL ICs on a complicated board... till he realized that he had earlier replaced a 7805 by a 7812.... )
(and fully repaired/restored a Philips BX453 valve radio in the past - about 10 different, unrelated defects in that one)
Downwind
Posted: 12:46am 22 Nov 2009
Doh!! Silly bugger!!
Good to see im not the only one that makes silly mistakes.
Maybe a headset magnifying glass needed.
Pete.
Sometimes it just works
Tonda
Posted: 01:53am 22 Nov 2009
I'm sure you are correct, Peter,
But first I will make the vibrator working with those 2SK3061 and than I'll try to substitute for something available locally. I'm getting those from Hong Kong for
US $ 0.31 each, good price, but shipping to Canada was $29.00.
I have no idea how to place a schematic on this forum, I would have to scan it first and than e-mail it as attachment? I would be working on this schematic later, I would have to figure out some modyfications for positive ground car radios .
Regards, Tony
Tony
