Local Time 05:50 22 Oct 2026 Privacy Policy
Forum Index : Electronics : The new DB9 PCB connectors from FTDI
vasi
Posted: 10:41am 21 May 2010
This is great! We don't have to use anymore inconvenient USB to serial converters and cables as this
We just solder this DB9 converter on our PCB. Simply great! It will take a while to get spread on all markets around world...
See the original article.
Elvish name: Mablung Miriel
Beyound Arduino Lang
GWatPE
Posted: 01:01pm 21 May 2010
Hi Vasi,
I have a similar component from FutureTech. My unit plugs into the USB of the PC, and has the Comm, I/O and a 5V & 3.3V supply, including data indicators and hardware handshaking if needed. Mine is tiny as well, smaller than a normal USB connector.
I gave up waiting for info from other forum members,so I have now an E-PC running win 7. This unit,I have now tried on this new PC, and I have programmed chips, and COMMS work well.
This little device works on WIN XP, VISTA & WIN7. There are drivers for most other systems as well.
Gordon.
become more energy aware
vasi
Posted: 03:29pm 21 May 2010
With this, is easy to design a board for any kind of microcontroller (Picaxe, AVR, PIC and others) without native USB connection. Can't wait to see them on the market (nothing yet in my area).
This breaks the monopoly of others: Arduino, Amicus18, and any other board with the FTDI chip soldered on it.
Vasi
Janne
Posted: 08:59am 23 May 2010
That's a nice find, thanks for sharing. Should be a nice plug & play replacement for any old serial port connector.
For new applications, however, I would like something like this, but with the usb +5V also being available. It's quite handy to steal the 5V to the microcontroller also from the usb power, eliminating the need for any other power supply.
If at first you don't succeed, try again.
My projects
Bryan1
Posted: 10:24pm 23 May 2010
Hi Guys,
Great find Vasi so of course I just had to look at dontronics to see if they had it but instead I found this one. Just as small and a heap more features.
Cheers Bryan
domwild
Posted: 10:32pm 24 May 2010
Great find, Vasi. Thanks for that.
Winston Churchill
