Local Time 16:25 22 Oct 2026 Privacy Policy
Forum Index : Electronics : Using a F&P as a motor? Article in SC.
Posted: 04:54am 27 Jan 2012
In the Feburary 2012 edition of Silicon Chip magazine there is a very well written article by Nenad Stojadinovic about using the F&P Smartdrive as a motor.
Driving the F&P as a motor is a common question here on the forum, but we've never had a good solution. Nenad has found it, using a BLDC motor controller. The article also mentions re-wiring the F&P to give more power at lower voltage.
thebackshed.com gets a mention too, which is great
VK4AYQ
Posted: 05:00am 29 Jan 2012
Hi Glenn
Haven't been able to get the article yet but was looking at some model outrunner 3 phase motors I have and I believe the driver 80 amp at 18 volts would be a basis for a controller as a fet driver to run the motor.
What do you think of that, it would make a useful motor in the workshop in a lot of applications.
All the best
Bob
Foolin Around
