Local Time 15:31 22 Oct 2026 Privacy Policy
Forum Index : Electronics : LED polarity, PC front panel sw.
domwild
Posted: 12:36pm 29 Jun 2012
Apologies, slightly off topic again!
Just building a new PC and am worried as the front panel cables are not idiot proof for me so I panic, most likely unnecessarily.
HD LED: Orange/white, which is + -?
Reset switch: Red/white, which is GND/Reset?
Power LED: Blue/white, + -?
Power switch: Black/white, GND/PWR?
Google tells me not to worry, if LEDs stay on all the time, then I just reverse the cable, but I better get a second opinion from the forum.
The ASUS manual warns me not to connect a 1394 cable to USB. I have a card reader, which has a thick round cable with markings of AWM 2835 60deg, 30V. Should I panic?
Winston Churchill
domwild
Posted: 08:46pm 30 Jun 2012
Thanks, worked that one out myself, LEDs connected with the wrong polarity do not burn out motherboards!
Winston Churchill
