Local Time 14:06 21 Oct 2026 Privacy Policy
Forum Index : Electronics : Possibly cheap parts in Oz - Q. to Gill
domwild
Posted: 05:32am 23 Mar 2007
Silicon Chip, current issue, page 43 lists surplus electronic components from Rockby Electronics.
200V 2x30A super fast diodes $1.50 part SF3004PT
60V 70A 35W N-Ch MOSFET $1.00 part 2SK3061 NEC
This MOSFET is powerful; perhaps experts like Gill with their "black belt in electrickery" may be able to tell me
if it can be used in place of the SDB85N03L to use back-EMF braking or are we talking about apples and pears?
Thanks.
Winston Churchill
Gill
Posted: 01:19pm 23 Mar 2007
Gee Dom, you sure know how to put a bloke on the spot.
I'm guessing your going to retro fit just the breaking part of that controller circuit to your existing charging circuit.
So, looking to diodes, seems OK, though I would use more. Say 4, as parallelling 2 diodes does not give double the amp capacity as you might expect.
Now the mosfet seems OK too. Once again I would use more. Try 2, to be sure to be sure. Make sure to get the pin-out arrangement when you order so you can connect correctly.
I am surprised to see no heat sink on these mosfets on the assembled kit. I couldn't help myself... I would.
Best of luck with the mod.
Cheers Gill _Cairns, FNQ
domwild
Posted: 04:39am 24 Mar 2007
Gill,
Thanks for that. Am using three of the 35A metal-case rectifiers, so I do not intend to use those diodes for the rectification. The diode info is for members of the forum, who may find those prices to be reasonable.
Am tempted to add the back-emf braking despite the fact that my PVC props seem to stall rather than overspeed anyway, this seems to be a problem with the profile. Besides, using the Picaxe, this could be progammed easily based on RPM should it be necessary.
From memory,when I searched the web for the SDB85N03L I did not get a hit, which is strange. Oatley's web site seems to be out of order at the moment.
Winston Churchill
