Local Time 17:27 22 Oct 2026 Privacy Policy
Forum Index : Electronics : Interconnecting strings of batteries
davef
Posted: 06:58pm 12 Jun 2013
I have two strings of 6Volt batteries with 4 batteries in series in each string. These two strings are connected in parallel.
Would be there much benefit in inter-connecting these so that every battery is directly in parallel with its neighbour. IE three inter-connecting wires, possibly to help equalise the charging across the whole system.
Thanks,
davefEdited by davef 2013-06-14
graynomad
Posted: 04:18am 15 Jun 2013
I don't know about that but there is a disadvantage, you cannot disconnect one bank to work on the system. With two banks you can do that and everything continues to run.
Edited by graynomad 2013-06-16
Rob Gray, AKA the Graynomad, www.robgray.com
davef
Posted: 07:40pm 15 Jun 2013
Good point.
