Local Time 18:08 22 Oct 2026 Privacy Policy
Forum Index : Electronics : Digital Panel Meter Issue
GerryS
Posted: 05:54pm 17 Sep 2013
Hi All:
I rolled my own LCD digital panel meters using the 7106 chip. I suspect this chip is what is used in all the small inexpensive meters and in the topology described for the digital panel meter on this website.
I am using two Murata DC-DC isolated converters (one for each meter) to produce the isolated 9 VDC needed but when I hook everything up, I get different readings when compared to my digital multimeter. Here's the mystery, when I use a standard 9 V battery, the meters read accurately - when I put in the isolated supply, the readings are not accurate.
I talked to Murata and they were stumped as well. The converters need a minimum load (the meters take 1 mA so I have ballast resistors to add another 10 mA of current. Plus used a 1 uF tantalum cap for noise filtering. Nothing worked.
Have used other panel meters as well, same result.
Any thoughts?
Thanks in advance for your help.
Gerry
gwshand@runningdogcapitalists.comEdited by GerryS 2013-09-19
isochronic
Posted: 07:34pm 17 Sep 2013
just wondering, are you powering both from the same 9v battery,
(ie in parallel with a common ground) ?
BobD
Posted: 08:39pm 17 Sep 2013
Have you checked the converter output under load, with an oscilloscope, for noise and ripple?
What speed is the 7106 oscillator running?
Have you discussed this problem with the makers of the 7106? Is that Intersil?
The only application notes I saw all show a battery supply for the 7106. My readings were limited.
Downwind
Posted: 10:33pm 17 Sep 2013
I think its a simple problem of ground loops and not a common ground as Chronic had pointed towards.
I think if you connect both grounds (negative) of each circuit together (common ground) than your problem might be solved.
Pete.
Sometimes it just works
GerryS
Posted: 12:57am 18 Sep 2013
Hi Downwind:
I did try the scenario with just one meter on one power supply - same issue. I'll do a little more experimenting and see what comes out of it.
Thanks,
Gerry
Posted: 04:01am 18 Sep 2013
What are you measuring with your digital meters, Volts or Amps?
GerryS
Posted: 05:18am 18 Sep 2013
Measuring voltage with one and amperage via a shunt through another.
isochronic
Posted: 03:24pm 18 Sep 2013
The meter power source ground, and the measurement negative
reference connection, are not necessarily the same.
IMHO the critical result would be from using two separate
batteries to power the two 7106's. One meter measures the
voltage from power+ to power-, the other one measures the
potential difference across the shunt resistor. Apart from the
measurement connections, the meters should be isolated at this stage.
Then, use your multimeter to take measurements across the same
points, and compare the live results. They should be the same.
If they are different it means there is an unaccounted offset
to start off with.
Then narrow it down by swapping in the modules.
Posted: 03:19am 19 Sep 2013
  GerryS said   Measuring voltage with one and amperage via a shunt through another.
I had similar problems with a shunt reading Amp meter on my sailboat. The problem went away when I located the shunt in the negative battery lead which allows one to connect the common input & common power together on the Amp reading digital panel meter.Edited by Tinker 2013-09-20
