Local Time 18:09 22 Oct 2026 Privacy Policy
Forum Index : Electronics : ANybody built a good 24V 30A+ Charger.
wallablack
Posted: 10:42am 10 Nov 2013
Hi Guys,
I wish to build a 24V 30 AMP+ battery charger or power supply. I want it to go to 35V but it must be 30+ amps. I want to use it to boost up my 24V 400AH battery bank on low sun and low wind days.
Does anyone know of any good designs....cheaper the better and if I can build it from recycled parts I would be more than happy...
Foolproof systems do not take into account the ingenuity of fools.
dwyer
Posted: 11:01am 10 Nov 2013
hi
Best way do Google searching look up for second hand forklift batteries changer that will product high amps is easy way to find
Dwyer the bushman
MOBI
Posted: 12:11pm 10 Nov 2013
I have a couple of old gasless mig welders (courtesy of downwind) that produce pretty well near the current you are looking at. I had to wind a couple of extra turns on the core to get the right voltage.
The unit doesn't have any regulation but the voltage selection switches give a fair range of control. It wouldn't take much to fit a few voltage taps. I used it when I had the generator going for welding. These days I generally have enough charge current now that I have hooked up a grid tie inverter to my RAPS system. The new mono panels really work well.
I used the diode assembly that came with the mig welder as they seem to be able to handle surges and a good deal of heat. A small computer fan as a cooler wouldn't go astray. The potted bridge rectifiers that hobbyists usually use kept over heating and blowing up.
David M.
Downwind
Posted: 04:03pm 10 Nov 2013
Did you try a forum search.
Glenn done this one a little while ago.
http://www.thebackshed.com/forum/forum_posts.asp?TID=5262&PN =3&TPN=1
Pete.Edited by Downwind 2013-11-12
Sometimes it just works
wallablack
Posted: 11:00am 11 Nov 2013
Very interesting read Pete.
I always search before asking...maybe not thoroughly enough lol.
Edited by wallablack 2013-11-12
Madness
Posted: 09:33pm 11 Nov 2013
You could just use the welding transformer idea as a bulk charger and have it turn off at a pre-set voltage. Would be very easy to do with an Arduino, that way you could also switch to a different windings for absorbing charge.
