Local Time 18:53 22 Oct 2026 Privacy Policy
Forum Index : Electronics : Powering a welder with an inverter.
Madness
Posted: 09:34pm 30 Jul 2014
Just wondering if there is any issues or concerns about running a welder off an inverter. I have a 240 AMP MIG welder (old school non inverter) and a Trace 4.5 KW inverter, mostly I would be welding light gauge steel and >120 Amps. For heavy gauge material I have a 10 KW generator that will power the welder comfortably at full power.
So far I have not attempted running the welder off the inverter as it is a transformer type and I am concerned all that inductance may not be inverter friendly. Would be more convenient than having to start the generator, especially for small jobs. As I have 7 KW of PV panels I am not concerned about battery drawdown.
Posted: 10:06pm 30 Jul 2014
Hey Madness
I use my MIG on my 7kw Latronics inverter quite often, for little jobs. For bigger jobs, where I might be welding for several minutes, or its late in the day, I fire up a 6kw generator and use that instead of the inverter. Mainly because my battery bank is small, and I've only got 2.2kW of panels, so I would prefer to save the power for the night.
I would check with the inverter manufacturer just to be safe.
Madness
Posted: 10:51pm 30 Jul 2014
Thanks Glenn,
Unfortunately Trace is not around now but they where taken over by Xantrex, I will give them a try.
As I have got heaps of batteries at scrap price (golf cart batteries) and cheap 2nd hand panels I don't have to worry about drawing down the batteries as they are on float for about half of the day anyway.
Gary
graynomad
Posted: 02:00am 28 Sep 2014
I build an entire motorhome body using a Lincoln 170 off an inverter. Can't remember the brand of inverter now but I also do light welding on my 3300W Trace inverter as well.
EDIT: Crap, I just noticed the age of this thread, oh well the info might be useful in a future search.Edited by graynomad 2014-09-29
Rob Gray, AKA the Graynomad, www.robgray.com
Madness
Posted: 10:56am 28 Sep 2014
Hi Graynomad,
Thanks for your input, what is the highest current you have welded with from the Trace inverter?
graynomad
Posted: 04:06am 14 Oct 2014
Sorry for the delay, I never got a notification.
I can't remember now, it was just emergency repairs and TBH I got pretty duck-sh*t welds.
I think the inverter I built the truck with was a 5000W Victron, that had no problems.
These days I use a 24VDC MIG when in the field in the 4x4, that works off two AGM batteries.
