Local Time 18:53 22 Oct 2026 Privacy Policy
Forum Index : Electronics : Tracer 2210RN MPPT IC part numbers
davef
Posted: 08:31pm 02 Sep 2014
I had the misfortune to have to repair one of these units. I removed the whole PCB, with toroid inductor by carefully cutting through the RTV material providing mechanical stability. As it turned out this was not necessary. There are only a few resistors plus the switching FETS on the bottom side.
U12 LM27313 (SRPB)
U10, U14 LM2903
U11 TC4427AE
U7 IR2110S
D10 ER2002CT PEC (dual)
uP STM32F102C8
U9 LMV932
Q2, Q3 and Q4 FB4310Z (IR)
Q11 and Q12 T260 BV2T14 (couldn't find this one on Google)
U3 74HC595D
U13 LMR14206 (SJ2B)
I was impressed that Google found the LMx parts with just the package description. I think I gave it a head start by suggesting ti.com
If more than about 42Volts is applied to the battery terminals, U13 is the unit likely to pop.
Even though the unit can detect which sort of a battery system it is on, 12 or 24Volts ... it does NOT select the appropriate fusing! On 24V you have 2 * 25AMP blade fuses in parallel, which is about twice what the unit is rated at. I would consider removing one fuse if you ALWAYS operate the unit on a 24V system.
Cheers,
DaveEdited by davef 2014-09-04
