Local Time 20:46 22 Oct 2026 Privacy Policy
Forum Index : Electronics : resistor vallue
irishron40
Posted: 04:10pm 19 May 2015
Hello.
in this power supply it suggests R1 to be 2k2 2,5 Watt
http://electronics-diy.com/power-supply-lm317-2n3055-0-28v-6-8a.php
I dont have it, but I do have a 2k 5 watt cement resistor
would that be ok to use? or does it need to be 2k2
thank you
ron
BobD
Posted: 04:16pm 19 May 2015
Ron
That looks OK. It looks like it is there to drain the capacitor C2 when the power is shut off.
Bob
Edited by BobD 2015-05-21
Pete Locke
Posted: 11:04pm 19 May 2015
Bob is right. But given it's the low voltage side of the power supply you can leave it out. Just a discharge resistor. You could put anything above that ohm value to do the job. The wattage needed will decrease as the ohm value goes up. Simple equation is 'Watts (of resistor) = v squared over resistor value.
All good fun :-)
Pete Locke
Posted: 11:13pm 19 May 2015
This is a very good link to basic Ohms law...
http://commons.wikimedia.org/wiki/File:Ohm's_Law_Pie_chart.svg
irishron40
so i could even put in a 20k 1/4 watt?
thanks
ron
BobD
Posted: 11:35pm 19 May 2015
Ron
Yes, you could. It all depends on how quick you want the stored electricity in the capacitors to bleed away.
Pete
I loved that diagram so much that here it is. I know the basics but to get the other I usually manipulate formulae. No need now.
Bob
2015-05-20_093343_OHMS_LAW.pdf
irishron40
Posted: 12:12am 20 May 2015
thank you both.
ron
