Local Time 02:04 23 Oct 2026 Privacy Policy
Forum Index : Electronics : 6-15kW OzInverter, OzControl board.
Clockmanfr
Posted: 12:56am 03 Jun 2016
The 6kW - 15kW OzInverter. The OzControl board.
And the list of components and parts required.
PDF's are A4 size.
I will do limited runs of double sided PCB boards:-
The New 6-15kW Power Board, The New OzControl Board and the OzCooling Board. These 3 PCB's will be offered as an extra option with the Making a 6kW OzInverter Book.
I will post Links to purchase very soon.
2016-06-03_104719_OzContrlBrdB3June16.pdf
2016-06-03_105614_PCBOzContrlBrdList1.pdf
Clockmanfr
Posted: 11:54am 05 Jun 2016
Sorry, these PDFs for the OzControl board, have now been superseded.
There are now additional components for the sake of some domestic dwellings with particular types of Earthing and impedance issues.
I will post a new PDF update shortly.
Clockmanfr
Posted: 12:59am 07 Jun 2016
As you can see on the OzControl Board No 8, there is now a small 220vac to 12vac 3w Isolation transformer, this is for the Voltage sense.
Also modifications to the Voltage sense to make it a fine tune, board power on LED and connectors for off board LEDs.
There is a double sided board, but these PDF's relate to a single side home Etch.
2016-06-07_105638_OzContrlBrd8Etch7thune16a.pdf
2016-06-07_105821_PCBOzContrlBrd8List.pdf
Link to the Book and the PCB boards.
http://www.echorenovate.com/new-book--make-a-6kw-inverter.php Edited by Clockmanfr 2016-06-08
joebog1
Posted: 09:46pm 22 Aug 2017
I thank you gentlemen!!
I shall keep you posted, BUT I have two weeks up the cape, building of all things, culverts for the new super highway to the the tip of Cape York.
My technology is main frames, so to multi skill I learned to operate big cranes.
Sorry I wander.
I will be away for a few weeks, but I will keep you up to speed.
Again!! my thanks for your patience and help
Joe
