Local Time 23:45 22 Oct 2026 Privacy Policy
Forum Index : Electronics : Winding toroid with aluminium wire?
Posted: 07:15pm 13 Jun 2016
Is there any reason you can't use enamelled aluminium wire when rewinding a toroid for use as an inverter instead of copper?
Posted: 07:26pm 13 Jun 2016
Only reasons to avoid it would be it has a higher resistance than copper wire, so has less current capacity and will get hotter quicker than copper.
Posted: 07:53pm 13 Jun 2016
Good point - should have thought of that myself, actually.....
Madness
Posted: 01:46am 14 Jun 2016
You would need to use thicker wire also. If you get some of those Aero Sharps you will get heaps of wire from them.Edited by Madness 2016-06-15
Posted: 03:09am 14 Jun 2016
Yes, I will follow up on that PM.
Thank you for taking the time to send me that PM.
I just hope I can get some.
