Local Time 23:47 22 Oct 2026 Privacy Policy
Forum Index : Electronics : 95mm cable end dressing
brucedownunder2
Posted: 07:01pm 05 Jul 2016
Hi Forum mates,
I have some 95mm multistranded welding cable ...
Do any of you know of "bootlace" terminations that will suit this size cable ? Up to 35mm are available on e bay ,but the 95mm range of cable must use another form of dressing for fuse blocks and equipment termination .
getting back into some workshop work again ,,,, been fairly crook this last year ..
Bruce
Bushboy
oztules
Posted: 11:54am 06 Jul 2016
Can't help with the cable problem, but am glad your doing better now.
How is your w7 conversion been running?
..........oztules
greybeard
Posted: 11:30pm 06 Jul 2016
Didn't someone on here make there own terminations out of some copper tubing?
They flattened an end and drilled a hole for the mounting bolt to go through it.
oztules
Posted: 12:41am 07 Jul 2016
Guilty as charged.....
..........oztules
Madness
Posted: 01:03am 07 Jul 2016
I must confess I have quite a few of them around the place, a few layers of flattened out copper pipe works as a bus bar too.
brucedownunder2
Posted: 01:25am 07 Jul 2016
Thanks for the replies...
Some. People have made terminations out of copper water pipe ,but what I,m talking about are those ,boot lace type ferrules for crimping the ends of large diameter cables ,. They usually have a ,pin, on the end ,so you can fit the cable end neatly into a small hole with a grub screw ,usually provided in circuit breakers,terminal blocks,Etc. I,m talking about 95mm size cable ,,,,inverter to battery bank leads.
John, yep, my W7. Conversion is running ,must be 18 months now ,perfect,no fan,silent,draws about 20 Watts on standby. .I,m happy with the hard work it took to convert,but would recommend flexible welding wire next time for the DC feed winding.
Have the small meters for voltage,Amps ,in and out , but haven,t got aroundtoit. Yet,lol.
I,ll post some stuff about my 2Kw. Exmork project soon ,,got cancer of the bladder,minor,but into hospital and get nasty proceedure every six months , so , I,m not as active as 10 years ago ..
Bruce.
Bushboy
jeffj
Posted: 02:45am 07 Jul 2016
95 mm crimped lugs will probably need a hydraulic crimping tool.
If you only need a few I suggest as other posts, get some copper tube and flatten it, cut 1/2 way through and roll up the end that has to go in the fuse holder. If its hard - get the copper red hot and quench it to anneal it.
Tin the copper before bending it around an appropriate mandrel then solder it up.
If you have access to a lathe turn them from solid The spindle of an old brass tap may be big enough.
Jeff
yahoo2
Posted: 05:36am 07 Jul 2016
EIA distribution do 95mm bootlace in packets of ten. No idea on price.
rhino tools go up to 70mm2 in bootlace ferrules. packet of 50 for around $30
Hi Bruce, Good to hear from you!
I am up watching the tennis, cant sleep.
