Local Time 02:04 23 Oct 2026 Privacy Policy
Forum Index : Electronics : Multi vibrator.
Phil23
Posted: 10:07am 05 Oct 2017
Was a little amused when Ozrules used this term.
One thing immediately hit my mind.
This.....
Old 60's Inverter.
I remember it in my father's shed in the late 60's to early 70's.
Dad & the TV Tech often talked about it's multi vibrator....
Now this inverter needed some serious attention from the scientific mind of an 8 year old....
So one school holidays, while parents were absent, the project began.
Grabbed my bed lamp & a double adaptor & headed off to the shed....
Out with the inverter, the battery charger & a spare 12V battery...
I'm sure most will work out the rest.
And yes, the project failed.
Phil.Edited by Phil23 2017-10-06
oztules
Posted: 10:32am 05 Oct 2017
At least it was Aust made...nothing is now.
Free energy is freely available due to the quantum electro dynamics... (QED) but it has strings attached. The more mass/energy that is spontaneously created from the vacuum of space.... the shorter the time it can exist, before you have to give it back.
So conservation of energy and momentum and mass can be, and is continually broken, but in the wash it all turns out normal.... but in planck time it is a probability amplitude mess.
I guess in theory, you can create an entire new universe from nothing... but have to create and dismantle it and give it back in ten to the minus 43 seconds.. or thereabouts.... and that makes it no more than a thought experiment with virtual particles.
On the macro level, your experiment turned out correct, and you were well on the way to discovering QED... well done.
( and who hasn't tried it in their childhood .... mine was a electric go cart and a generator... and we all know how well this turned out. )
.........oztulesEdited by oztules 2017-10-06
Madness
Posted: 10:54am 05 Oct 2017
E = mc2
Phil23
Posted: 10:19am 06 Oct 2017
  oztules said  ( and who hasn't tried it in their childhood .... mine was a electric go cart and a generator...
Best I've seen was from a Local Motor Mechanic;
Smallest alternator he could find, coupled to a 12V motor.
Front pulley still in place with the addition of the largest radiator fan found in the shop.
Pole mounted, the motor assisted by the fan, & pull started by the pulley.
It was a week long work in progress as a camping "Accessory".
Not sure what I outputted..., but do know car alternators need a "few" RPM to get going.
