Local Time 01:53 23 Oct 2026 Privacy Policy
Forum Index : Electronics : Source for SMD rel;ays
larny
Posted: 01:25pm 08 Nov 2017
I need relays with the following specifications:-
A coil voltage in the range 5 Volt to 48 Volt.
Contacts - either DPST or DPDT able to switch at least 60 Volt DC and a current rating of at least 500 mA.
I prefer SMD mounting but through the hole will suffice if SMD relays with the above specifications are not available.
Does any one know where I can purchase such relays? I need 80, so the price is critical.
I tried RS Components & Element 14, but they have little to offer.
I also did a search of Chinese companies but found their web sites frustrating. The ones I viewed did not have a sensible search engine. Besides, I have the feeling they don't want enquiries from the likes of me.
Any assistance will be appreciated.
Len
joebog1
Posted: 01:40pm 08 Nov 2017
wescomponents.com
You will need an ABN to order from them however
They have a pretty good range but ALL are PCB mount.
Test the site by searching for
RL-P-5 5 volt coil
RL-P-12 12 volt coil
RL-P-24 24 volt coil
will switch 240 volts AC @ 500 mA
220 VDC @1A
14mm X 9mm overall footprint
Joe
OOPS I forgot
5volt version $1.40
12 volt and 24 volt is $1.30
They have a similar unit in SMD
RL-PS-5
RL-PS-12
RL-PS-24
But twice the price
Edited by joebog1 2017-11-09
larny
Posted: 02:34pm 08 Nov 2017
Thanks Joe,
I registered with them but have to wait for them to process.
I think my daughter has an ABN, so I may be able to use her's.
Len
joebog1
Posted: 02:48pm 08 Nov 2017
I dont think they much care!! its more a GST thing.
If you buy 80 relays, order a catalogue!!!! ( used to be free )
about 800 pages of stuff
they are the ducks nuts for bits n pieces.
they do very little SMD stuff apart from chips
Joe
larny
Posted: 07:37am 20 Nov 2017
Thanks for the suggestions. After consideration of the various options, I have decided to not use relays & use 2 16F1708 PICs as they have sufficient pins & IOC on every pin.
Len
