Local Time 21:50 20 Nov 2026 Privacy Policy
Forum Index : For Sale : Garage Sale - All to go.
robbo
Posted: 03:11pm 28 Mar 2009
Garage Sale. All items to go.
******NOTE _ALL ITEMS NOW SOLD ***************
Thanks.
Items can be purchased separately or as a system. Pick up would be best due to the weight of all these items/ or happy to have courier pick up. Home address is in South Brisbane. Contact me for prices if not on this page. Offers are welcome.
Email to rkelms<at>bigpond<dot>net<dot>au, or phone mobile 0433444578.
-Working, single motor wind turbine, LOW wind speed cut in. Currently has 3 phase, 6 pole motor. Max about 5amps, but always charging. Heavy tail for late furling, with tail stop. Rectified on turbine.<make offer>
-Dual motor body with 2 x F and P motors., currently working on tail furling. Designed to mount a 48mm pole. Adjusting nuts for hub and shaft alignment. <make offer>
-Prop built for 3 or 6 blades. 2.06 metre blade diameter. Painted PVC. <make offer>
-Oatley K241 regulator 12Volt.With a EMF back braking system and dump load setup. Charging lights, fully built and working.
-Electrical panel including white box (Ex medicine cabinet), and K241 Regulator kit inside. Also contains, analogue multimeter for rectifier input and amps gauge (up to 20 amps).Anemometers rpm gauge is on left. On the right of panel is car batt gauge, measuring Batt levels by leds. <make offer>
- 3 x 12volt car batteries. All hold charge well. No dead cells, leads included.
- Near new 1000 watt inverter from 12v to 240volt. Peak at 2000 watts. Leads included, wanting $200.
- 8 metre swing type gin pole, (with 48mm steel pipe). Electric cable runs thru middle of pole. 3 x Guy wire included and Anemometer mounted near top part of cabling. Have added extra pipe to extend at bottom (See picture) for ease of use. <make offer>
-Anemometer is home made and windspeed tested. 3 cups and a reed switch.
- Various motors and parts available. Shafts and Bearings, 1 still in F&P Wm cabinet. 7 phase motor and hub (Was the previous motor on turbine and measured the most power at 296 Watts). approx 40 klms winds.
- 300 watt pure sign wave Inverter (12v), modified ups with fan and leads to batts.$45
(match solar panel below).
- 17 watts solar panel with charger.Suitcase style (two panels-can take anywhere) with max 7amp charger. Comes with 2 x 12amp sealed lead acid batteries $100 (total)
(SOLD)
- 4 x 1.50metre pine pieces for a future blade project (3 of are partly cut). <make offer>
- Wireless Weather station,measures wind speed, thermometer,Hydrometer, min/max history.-LCD display works well (SOLD)
Many other smaller parts and components available, rectifiers, hubs, etc.
14REDEdited by robbo 2009-05-29
"the Earth was not given to us, by our fathers, rather, it is lent to us by our children".
