Local Time 22:05 20 Nov 2026 Privacy Policy
Forum Index : For Sale : some nice gear
brucedownunder2
Posted: 01:26am 20 Mar 2010
Hi Crew,,
I'm moving on and will sell some very nice gear.
Control panel
with,solar input Voltmeter, input Ampmeter.
Wind input Voltmeter, input Ampmeter.
Rotary Switch to Voltmeter for , Wind, Solar, 3 Battery Banks.
Regiulator with Charge Mode/ Equalise mode/ shunt on, LED's.
Two heavy duty rotary switches for battery inputs and battery outputs.
Full bank of circuit breakers and professional connector banks.
3 Phase ac-dc heavyduty rectified diode bank mounted on big heatsink.
appropiate heavy duty diode for wiring protection
heatsink with fan on the blocking diode for the regulator.
3 Phase shutdown switch for the wind turbine.
600-800 watt enclosed vented dummy load (stand alone unit).
fused meters and ample room for a future tachometer on this professional steel enclosure.
2 banks of 'Yausa" 63 Ah agm batteries giving a 24volt bank of 756Ah (12 batteries).
These are in very good condition.
All battery interconnect cables.
Turbine platform with "Trev's" foundary and fibreglass aluminium F&P bearing assembly.
Extended spline F&P shaft by foundary and fibreglass to accomodate a dual F&P rotor assembly.
One F&P neo retrofitted rotor (that has seen easily 600watts) .
One F&P stripped and ready for fitting supplied neo's
ABS plastic blades ,really well made and now ready for fitting to a supplied steel hub.
These parts are all made by myself over the last 5 years and are of very good quality,hundreds of hours being put into research and building.
Buyer to pack and provide transport,small trailer required. East of the gold coast by 20 minutes , Mt. Tamborine area. (07) 55453513
BruceEdited by brucedownunder2 2010-04-10
Bushboy
brucedownunder2
Posted: 10:10pm 26 Mar 2010
OK,re the previous post of my stuff for sale,get in touch and we'll see what we can do ,,lots of other F&P stuff under my house that could stitch up a deal also..
Bushboy
HeadsUp
Posted: 05:55am 11 Apr 2010
you might get more interest if you state the size and voltage / current ratings and brand names etc
for eg
what is the rating of the big rectifier ?
brucedownunder2
Posted: 09:58am 11 Apr 2010
Thanks Heads up,
I'll let it die a natural death as nobody appears to be interested. I'll mothball it and maybe drag some gear out as time goes by. Really was trying to help someone with actual working gear ,but I'm not interested in posting it ..
I'll move on with my new project and let the gear sit in those big plastic boxes ..
Bruce
Bushboy
tindish'n'fish
Posted: 12:12pm 29 Apr 2010
just read your add looks like some useful gear (some of which i dont no what for).I read the post where you said you were not interested in posting it.I live in southern tas and cant get to qld.would it fit on a pallet,i could get it picked up by courier.let me know if you have any thoughts bob
dont touch the brown wire
brucedownunder2
Posted: 09:28pm 29 Apr 2010
OK, Bob .
I,ll go through and sort a few things out in the near future. I am tossing up on re-using some stuff ,as I might put a second wind gennie up ,later.
I'll keep you in mind .
Thanks for your enquiry.
Bruce
Bushboy
