Local Time 21:55 20 Nov 2026 Privacy Policy
Forum Index : For Sale : 8ZED 8 in1 Power Stn w Solar Charger
TronicSavyyJohn
Posted: 03:47pm 07 Jun 2012
8 in1 Power Station with Solar Charger
http://performanceshop.com.au/8-in1-Power-Station-with-Solar -Charger-and-Air-Compressor-8Zed_1997.html
Air compressor for pumping tyres and other inflatables Rated to 260Psi
Tough rubber handle and rubber buffered impact absorbing edges
AC and DC chargers included
12V 12Ah SLA battery inside
Cold Cranking Amps: 250CCA (Please check vehicle requirements)
200W (400W surge) MSW Inverter - 240VAC outlet at rear for powering mains devices **
5 LED work/map light at front panel
Charging and air compression dial indicators
2 x 12VDC sockets for running 12V appliances
DC charging takes approximately 12 hours (Initial Charge)
AC charging takes approximately 34 hours (Initial Charge)
Charging jack
USB Outlet
Built in air cooling fan
Battery level indicator
DC & AC Charging Cables Supplied
3 month warranty
