Local Time 21:49 20 Nov 2026 Privacy Policy
Forum Index : For Sale : 12v to 110v invertor to good home
marcwolf
Posted: 12:51am 15 Mar 2013
Hi folks.
I have this invertor that I got a while back with the idea of modding it to put out 240v. But could not.
Here are the specs
The most powerful PROwatt ever, it provides you the ultimate in mobile power and dependability - anytime, anywhere.
The PROwatt 2500 is designed for heavy-duty use in both recreational and industrial markets. Able to meet the rigors of challenging environments and loads alike, this powerhouse is capable of meeting the demand time and time again, year after year.
Surging to 5000 watts peak power, 3000 watts for 5 minutes, and producing 2500 watts of continuous power, the PROwatt 2500 has a multitude of applications including circular saws, table saws, routers, planers, work lights, large microwave ovens, washers and dryers, air conditioners, bread makers, ice makers, coffee makers...and much, much more. Max. Continuous Power
2500W
Surge Capability
(Peak Power) 1 HP (5000W)
5 minute 3000 W
Optimum Efficiency approx. 90% efficient
No Load Current Draw <600 mA
Output Voltage 115 VAC RMS +/- 5%
Output Frequency 60 Hz quartz crystal controlled
Output Max. Continuous Power 2500W
Surge Capability
5 minute 3000 W
Output Waveform Modified Sine Wave, phase corrected
Input Voltage Range 10 - 15 VDC
Low Voltage Alarm Yes (10.6 Volts)
Low Voltage Cut-Out Yes (10 Volts)
AC Receptacles Single (Included in box as accessory)
Fuse Internal - not user replaceable
Weight (lbs.) 20
Length (in.) 19
Width (in.) 8
Height (in.) 6
I just want it gone so please give it a good home. As you can see it's heavy so not freight.
Dave
Coding Coding Coding..
Keep those keyboards coding..
RAW CODE!!!!!
