Local Time 21:49 20 Nov 2026 Privacy Policy
Forum Index : Wanted : converter
brucedownunder2
Posted: 12:12am 08 Feb 2008
Anybody out there got a 24 to 48 volt dc-dc converter ?..maybe an ex-telcom or comms piece of equipment. I want something to feed my 48v battery bank off the 24v solar panel when the wind is not generating the 48v wind gennie..
Bruce
Bushboy
sPuDd
Posted: 12:03pm 08 Feb 2008
Nope, but you should be able to build a simple enough
unit to do the trick. How much power (watts) are your
24V panels putting out?
sPuDd..
It should work ...in theory
robbo
Posted: 07:11am 26 Jun 2008
Hey Bruce,
There is a place called "telephone wreckers" at Loganholme, -not to far from you. I went in their the other day and he had piles of things that you might be interested in. I bought 2x 12v 12ah batter from him for $26 each, so isnt overpriced.
Worth a look if you still want those converters ?
Ph 38065111.
"the Earth was not given to us, by our fathers, rather, it is lent to us by our children".
FandPwithPVC
Posted: 08:33am 26 Jun 2008
Hi Bruce
I have an ex Telecom 48VDC to 80VDC at .5 Amps DC to DC converter. You can have it for the price of posting it. It is in mint condition and nicely boxed .
Regards Dennis L
brucedownunder2
Posted: 09:39pm 26 Jun 2008
Thanks Guys ,,will be in touch
Bruce
Bushboy
sPuDd
Posted: 10:21am 28 Jun 2008
Bruce,
Link to Otherpower Forum Posting
The above posting contains a lot of info for you if you
want to try making a boost converter yourself. Also I've
started using the LT1268BCT of late, which is the 7.5amp
direct replacement for the LT1170. It runs at 150khz which
helps keep the inductor/cap sizes down.
Linear will often give you a sample or two as well, which
is great for testing a prototype
sPuDd..
