Local Time 07:47 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite eXtreme 5.04.14: Sprites on TFT
Posted: 08:04pm 15 Feb 2018
Please find attached MMX5.04.14 for 100/144 pin parts
2018-02-16_045942_MMX5.04.14.zip
and for 64-pin parts
2018-02-16_050002_MMX645.04.14.zip
Changes are:
allows OPTION LCDPANEL USER to be used in a program. NB this option is not permanent and needs to be set again after a reboot.
Implements new drivers for 16-bit parallel ILI9341, SPI ILI9341, SPI ili9481, and 16-bit parallel 4.3" SSD1963 using an in-memory framebuffer.
By default the Micromite eXtreme has 469K bytes of available RAM for use in user programs. This is much more than is normally needed given that the program is stored in flash memory and that will hold a program of up to 544K.
This release optionally uses some of that available RAM as a framebuffer for various displays in order to overcome some of the limitations of directly addressing the TFT display. This is best explained by watching a video of sprites running on a 4.3" SSD1963 display using a driver with and without the framebuffer.
The mechanism of moving a sprite is as follows:
1. replace the sprite with the stored background
2. scroll the background
3. save the background for the new position of the sprite
4. re-display the sprite
The effect of this can clearly be seen in the first part of the video where the sprite flashes repeatedly and is only barely visible between loops of the program.
By using a framebuffer, all of these steps can take place within the memory of the Micromite and only when they are completed the complete area affected is written to the screen as a single operation.
Of course this approach is not only useful for sprites but can make any sort of animation look much better. The user has complete control of when the screen is rewritten. By default each Basic statement that updates the screen will cause a write to the TFT panel (a sprite move is a single Basic statement). However there are two statements that allow the user to override this.
OPTION AUTOREFRESH OFF
will stop drawing statements updating the screen and just the framebuffer will be updated.
OPTION AUTOREFRESH ON
will cause the display to be updated to the current status of the framebuffer
So for example the pseudo code for updating an analog clock display might be:
REPLACE HANDS WITH BACKGROUND
REWRITE HANDS IN NEW POSITION
The new drivers are enabled as follows:
All MMX
OPTION LCDPANEL ILI9341_BUFF, orientation, DCpin, resetpin, chipselectpin
This uses 150K of memory leaving 319K for user programs (320x240x2 = 153,600 /1024 = 150). Time to write entire screen (cls rgb(red)) 29mSec. Time to scroll entire screen 49mSec
OPTION LCDPANEL ILI9481_BUFF, orientation, DCpin, resetpin, chipselectpin
This uses 300K of memory leaving 169K for user programs (480x320x2 = 307,200 /1024 = 300). Time to write entire screen (cls rgb(red)) 156mSec. Time to scroll entire screen 194mSec
100/144 pin only
OPTION LCDPANEL ILI9341_16_BUFF, orientation, DCpin, resetpin, chipselectpin
This uses 150K of memory leaving 319K for user programs (320x240x2 = 153,600 /1024 = 150). Time to write entire screen (cls rgb(red)) 10mSec. Time to scroll entire screen 30mSec
OPTION LCDPANEL SSD1963_4_16_BUFF, orientation, DCpin, resetpin, chipselectpin
This uses 255K of memory leaving 213K for user programs (480x272x2 = 261,120 /1024 = 255). Time to write entire screen (cls rgb(red)) 16mSec. Time to scroll entire screen 50mSec
Edited by matherp 2018-02-17
IanT
Posted: 09:19am 16 Feb 2018
How many are there in Team 'Matherp' - and what sort of shift patterns do you work?
Amazing!
IanT
Posted: 09:16am 23 Feb 2018
Updated manual
2018-02-23_191643_Micromite_eXtreme_Manual.pdf
astro1
Posted: 05:27am 04 Mar 2018
Anyone else seeing issues with GPS command not responding with valid data?
Open "com1:9600" As GPS,11
Print GPS(valid)
Print GPS(date)
Print GPS(time)
Reads Ok on v8/9.
Posted: 09:45am 04 Mar 2018
  Quote  Anyone else seeing issues with GPS command not responding with valid data?
See this thread
Posted: 10:17am 04 Mar 2018
Update to fix the GPS bug and also allow a PWM duty cycle of zero. No change of version number
100/144-pin
2018-03-04_201632_MMX5.04.14.zip
64-pin
2018-03-04_201727_MMX645.04.14.zip
frederic
Posted: 08:00am 30 Mar 2018
Hi everybody,
new for me on this forum, with a limited english !!!
i am working on my own pcb for MMX 144pin,
with HEX from 2018-03-04_201632_MMX5.04.14.zip
everything is working well except 4.3" display
OPTION LCDPANEL SSD1963_7,L ok for 7"
OPTION LCDPANEL SSD1963_7_16,L ok for 7"
OPTION LCDPANEL SSD1963_5,L ok for 5"
OPTION LCDPANEL SSD1963_5_16,L ok for 5"
OPTION LCDPANEL SSD1963_4,L not working for 4.3"
OPTION LCDPANEL SSD1963_4_16,L not working for 4.3"
of course, i checked with several 4.3" displays, i checked these 4.3" displays on another board, working well on MMB+ so displays are ok,
i produce a second MMX 144 board for checking on another board
same result, not working with 4.3" ?????
i tried also :
OPTION LCDPANEL SSD1963_4,L with a 5" of course 800x480 for 480x272 give a funny
double display , but is working well
i need a little help
fred
Posted: 08:06am 30 Mar 2018
fred
I've noticed some 4.3" displays seem to react slower than other sizes. The current code works with my 4.3" displays but one of them was a bit marginal whereas, as you say, 5" and 7" displays are fine. I can't do anything at the moment (in the Var) but will post a slowed down version late next week for you to try.
Have you tried the buffered driver?
SSD1963_4_16_buff
Edited by matherp 2018-03-31
frederic
Posted: 11:51am 30 Mar 2018
thanks for this quick answer,
happy to ear that you got the same trouble
i tried :
option lcdpanel SSD1963_4_16_buff,l
not accept :
CPU exception #0 at address 0x99760462
processor restarted
oups!!!!
thanks
Posted: 04:12pm 30 Mar 2018
@frederic
Ensure you issue a OPTION LCDPANEL DISABLE first; then type the 'new' LCDPANEL parameters
WW
Posted: 04:18pm 30 Mar 2018
  Quote  option lcdpanel SSD1963_4_16_buff,l
option lcdpanel SSD1963_4_16_buff,l,n
You must specify the RD pin number. The code should trap for that I'll fix it in the next release
frederic
Posted: 05:47pm 30 Mar 2018
option lcdpanel SSD1963_4_16_buff,l,142
is working well, well, well
thank you so much for your great job and help,
another little question :
is it possible to use MMX interpreter for commercial application ?
thanks
fred
sagt3k
Posted: 07:47am 31 Mar 2018
Hi Frederic
We must ask Geoff . But the use of MMbasic is free (without modifying and redistributing the code), so it is possible to flash the boards that project and sell only the HW that develops, describing the paternity of the firmware.
Antonio
Posted: 09:44am 31 Mar 2018
  frederic said   is it possible to use MMX interpreter for commercial application ?
thanks
fred
I suppose you need the permission of everyone whose code is in it.
(As you do to use it at all.)
I think there's some info on Geoff's web site(s) but you'd need to check with everyone else as well.
Posted: 10:12am 31 Mar 2018
  Quote  another little question :
From Geoff's site, and the same applies to my contribution to the MMX
  Quote  New License
My new license is simple, it is still open source, it is just not based on the GNU GPL. It says (in summary) that the executable program produced by me is free to be distributed in any way for any purpose. The source is freely available and can be modified for personal use but it, and any executables generated from it, may not be distributed without first consulting me and obtaining my permission.
PicFan
Posted: 12:13pm 25 May 2018
A question:
Is the command "Static" implemented in the "Micromite extreme"? If so, in which version?
Thanks and best regards !
Wolfgang
Posted: 01:21pm 25 May 2018
  Quote  Is the command "Static" implemented in the "Micromite extreme"?
No: Geoff hasn't released the code yet as the MM+ version is still in beta
PicFan
Posted: 08:26pm 26 May 2018
Yes, ok - thank you !
PicFan
Posted: 08:57am 07 Jun 2018
Hello Peter !
Please, can you help me with this problem ? Please look on this post. Problem
Thank you and best regards !
Wolfgang
Posted: 09:08am 07 Jun 2018
  Quote  Please, can you help me with this problem ?
No - sorry, this is in the guts of MMBasic and one for Geoff. It is also pretty obscure so may not be easy to find. Suggest you find a work round by avoiding multidimensional arrays
UPDATE 5.3 doesn't seem to have the problemEdited by matherp 2018-06-08
