Local Time 13:46 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to learn RF remote codes?
     Page 1 of 5
Posted: 02:04am 10 Mar 2018
I have a need to use some little 433MHz transmitter units. Matching up a suitable receiver is no problem, but reading the data and learning the remote codes IS.
I need to be able to learn new transmitter codes into the MicroMite in the next crazy idea I have. There are learning receivers all over eBay and AliExpress for only a few bucks, but they can only remember ONE code - I need to be able to learn up to 20 different ones.
Here is a simple 2-page PDF for the RT1527 encoder chip:
2018-03-10_115403_RT1527.pdf
Here is another datasheet for the same encoder, with a little more detail:
2018-03-10_115502_RT1527_HS1527_20-bit_remote-control_encoder.PDF
Receiving the data from the transmitter is dead easy using something like an SYN470 Receiver Module
Here is the datasheet for the SYN470R receiver chip.
The 470 receiver is a lovely little chip, and is my go-to receiver device these days, and I have had much sucess with it, cos all the receiving and processing is done for you in this device.
What I need to be able to do, is connect the data output line from the receiver chip to the MM, and read the data so as to learn the codes.
That SOUNDS easy, but the problem is HOW. The data stream from the 470 device is not in any kind of pre-established protocol, it's just a stream of bits.
Does anyone here have any bright ideas as to how I might go about reading the data stream into the MM?
Once I have it in the MM, the rest is easy, but reading the data is going to be the tricky bit.
crez
Posted: 03:17am 10 Mar 2018
after the sync bit is received, assuming an 80khz clock freq on the encoder
for each data bit you would have to:
wait for a rising edge
wait 0.6 ms
read the level and store it in a 24 bit buffer
increment the buffer pointer
all this happens in 1.6ms
I think a cfunction would be required
Posted: 03:35am 10 Mar 2018
Wow, yes, that is rather fast.
The 470 chip does have a useful pin - #12, WAKEB, which goes low when the device detects incoming RF signal, which could perhaps be used to trigger and release the Cfunction - if I end up doing it that way.
Cfunction Gurus - what are your thoughts?
Posted: 05:53am 10 Mar 2018
I hooked up a 470 receiver to my logic analyser and this is the output:
The sync seems to be about 6ms in length, followed by the data. This repeats like this:
When no button is being pressed, the data is just white-noise.
EDIT: Forum software is compressing these images, so they look a little fuzzy. Let me know if you want me to link to un-squeezed versions on Dripbox. (Dropbox)
EDIT: Each of the bits in the packet appear to be 0.8ms each, regardless of if they are zeros or ones.Edited by Grogster 2018-03-11
Posted: 07:58am 10 Mar 2018
Hi G,
This reminded me immediately of the Apple IR de-coding I done a few years back; and it looks like a similar technique can be used.
Is the RXd data in the above image (according to the expected Tx stream datasheet) 24 bits as: 0111 0101 0001 1100 0000 0010 ?
Also, please confirm the mS time between the start of each bit.
In the meantime I will remind myself of my Apple decoding program written without a C-Function (but you may need to use a C-Function if the mS time is small)
WWEdited by WhiteWizzard 2018-03-11
Posted: 08:01am 10 Mar 2018
If I understand you correctly, then you just want the MM to 'learn' (i.e. de-cipher) the 24bit values such as the one above I interpreted from your image?
Posted: 08:05am 10 Mar 2018
Hi G,
Check out this post - scroll down a bit and see an image 'identical' to your waveform
Trevorc
Posted: 10:23am 10 Mar 2018
Hi,
Some time ago, I needed the codes from a stair lift to be able to replace the remote.
I came across this site, http://arduinobasics.blogspot.co.uk/search?q=RF+Remote+Capture
You need to be a bit of a detective and able to use a spreadsheet, but it worked for me then.
Good luck Edited by Trevorc 2018-03-11
PeterB
Posted: 12:14am 11 Mar 2018
G;Day Grogster.
That code was used many years ago in all sorts of places.
One version was Hi for 80%, LO for 20% for a 1 and HI for 40$, LO for 60% for 0.
I never understood why it was 80/20 & 40/60.
When I used it I used 80/20 & 20/80 over a radio link with about 100 bits and repeated for error detection.
To read the data you use a mono set to half the bit period and strobe.
Good luck.
Peter
Posted: 12:22am 11 Mar 2018
@ WW - As per the 2nd datasheet which has a bit more information, they say that each word consists of a sync bit, 20 address bits, and 4 data bits, so 25-bit. 24-bit if you don't count the sync bit.
Your interpretation of the data is how I see it, yes. Basically, looking at the datasheet, a short pulse-width is a zero, and a long pulse-width is a 1.
Here are images of the first two bits following the sync bit:
[Quote=WW]If I understand you correctly, then you just want the MM to 'learn' (i.e. de-cipher) the 24bit values such as the one above I interpreted from your image?[/Quote]
Correct. Once I know what the 24-bit word is, the MM can save it permanently via VAR SAVE. I would probably do that via a single-dimension array of 20 elements.
So I need to be able to 'Read' the code of a new remote into the MM and save it. The system will then respond to that remote as the MM has memorized it. At any point in time, a routine can be entered to re-learn remote codes, which will overwrite the old ones, allowing new ones to be programmed into that same 'Slot'.
@ Trevorc - Thanks, I will read that link.
Posted: 12:27am 11 Mar 2018
  PeterB said   G;Day Grogster.
Good luck.
Peter
Yes, that appears to be what they are using for 1 and 0 in this data stream.
Can you please elaborate on your comment that "Use a mono set to half the bit period and strobe." - Confused.
PeterB
Posted: 12:37am 11 Mar 2018
G'Day
If the bit period is 0.8 ms,
trigger a mono set to 0.4 ms with the rising edge of the data.
Then fire a second mono on the trailing edge of that mono set to "skinny" to strobe the bits.
The 1's will be HI and 0's will be LO.
That was in the days before micros and you probably.
Peter
PeterB
Posted: 01:26am 11 Mar 2018
But wait there's more.
I think you young blokes would set up an interrupt to fire on a rising edge and then read the data 0.4 ms later.
But this is getting a bit clever for me.
Peter
Posted: 03:33am 11 Mar 2018
Grogster,
Do you have control of the frequency setting resistor?
If so, you can slow the pulses down a bit if needed.
When I want to do small timing intervals, I make my own high precision timer.
Set a PWM output to 100kHz and feed that output into one of the counting pins. Read the counting pin as required and you have 10 uS resolution.
You still have the problem of program execution time but this UNTESTED test program is the way I would try first up.
  Quote   DIM tick AS INTEGER, tock AS INTEGER
DIM code$
PWM 1, 100000, 50 ' this is out high resolution timer whch gets connected to pin 15
SETPIN 15, CIN
SETPIN 16, INTB, blip ' triggers on a high or low transition
DO
IF INKEY<>"" THEN
PRINT code$
ENDIF
LOOP
END
SUB blip
tick =
PIN(15)
IF PIN(16) = 1 THEN ' we went from low to high
tock = tick
ELSE ' we went from high to low
IF tick - tock > 40 THEN ' 400 uS is longer than a short interval so must be a "1"
code$ = code$ + "1"
ELSE
code$ = code$ +
"0"
ENDIF
'PRINT code$ ' printing will slow things down far too much
ENDIF
END SUB
Assuming a 28 pin micromite,
Connect pin 4 (PWM 1A output) to pin 15 counting input.
Connect your signal to pin 16
I have taken 200uS as the short time and 600uS for the long time.
The program does as little as possible:
On a rising edge trigger, reset the counting variable.
On a falling edge trigger, check the time since the last rising edge trigger and determine if it is a long or short pulse.
Send a code then press any key to see the result.
I have not bothered stripping sync pulses out or clearing the string at any stage.
Posted: 04:48am 11 Mar 2018
Very clever!
Thanks. I will set that up and play with that concept later tonight.
As the sync pulse is just a 'Long-low' to overcome the receiver white-noise, then the first pulse the MM should see, should be the rising-edge of bit-1, correct?
Posted: 05:26am 11 Mar 2018
I think the sync pules will be a short high followed by the long low.
It won't matter. This is just to see if the mite can work fast enough.
Posted: 06:12am 11 Mar 2018
code$ is all 1's, till the string is too long. No matter if I press the button or not.
Does that mean the MM is not fast enough within the interpreter?
Also, when NOT pressing a button, the receiver outputs white-noise, so I woluld love some pointers on how to deal with that.
I am looking at another transmitter unit, which uses the MUCH easier to use SC/PT2260 transmitter and matching SC/PT2270 receiver chip. They are easier, as the decoder chip has a VT(Valid Transmission) output which the MM can use to know when there is a transmission coming in, and four data output pins that reflect what you code the transmitter for.
The 1527 chip is a pain in the arse, actually......
Posted: 06:19am 11 Mar 2018
You said earlier that your receiver had a squelch pin.
Use that to enable interrupts when there is a signal and disable when no signal.
The other device you are considering sounds easier to work with.
PeterB
Posted: 06:27am 11 Mar 2018
Did you try my method?
You would need to detect the long period of nothing to initialize the system but after that it should be easy.
Peter
Posted: 06:30am 11 Mar 2018
Yeah, Jim, I think you are right.
There are other choices and the 2260 matched with a 2270 or 2272 is a beautiful thing, as the 2260 does the encoding, and the 2270/2272 does all the decoding for you, just driving output pins(on the decoder IC) which can directly interface to the MM.
I have done this before in the past, and it worked a treat. The only REAL limitation, is that you can only have 15 transmitters, as you only have four data bits/pins on the decoder chip to play with. However, reading the four-bit data is DEAD easy with the PORT command.....
Time for a rethink, perhaps. The 1527 unit is cheaper then the 2260 unit, but only by a couple of bucks.
     Page 1 of 5
