Local Time 05:59 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CAD softwares....
Posted: 09:43pm 28 Jun 2018
Hello all.
I need a CAD software for designing front panels that can then be laser-cut from the files. I used to use QCAD as it was free, and after about an hour, it would revert to single-layer only unless you purchased it.
That was fine, as I only needed layer zero as the laser cuttings/outline.
The latest version of QCAD has changed, and now the application forces a close after an hour or so - they have got wise to people just using layer-zero. And fair enough.
QCAD is not that expensive - about US$40, so I am considering purchasing a license for it, not that I do THAT much CAD for laser-cutting.
However, before I do that, does anyone else know of a good easy to use CAD that can export DXF files for laser-cutting? QCAD is all I really know of, and an internet search revealed lots of other softwares, but I thought perhaps members here might have some experience with some of them, and could offer their thoughts and opinions.
Chopperp
Posted: 10:41pm 28 Jun 2018
Got to hand it to Mr Google. AutoCAD probably bit out of your price range though Groggs
I use a very old copy of Visual CADD, which had had an upgrade path originally from Generic Cadd many many years ago. Expensive though.
ChopperP
Posted: 11:14pm 28 Jun 2018
Ahhhhhh........yeah. The price on AutoCAD is stunning. No thanks. QCAD is still the frontrunner unless another member can suggest something else.Edited by Grogster 2018-06-30
Posted: 11:44pm 28 Jun 2018
I use TurboCAD Deluxe.
I have use it for 20 years but don't use it enough to get proficient. I can do what I have to do but that's about it.
Like most programs, you can still get a trial version.
Any change will give you lots of head banging so if your existing program does what you need, I would hesitate to change.
What might happen eventually, is the laser cutter will want a newer version of the files so you WILL have to update.
Posted: 12:49am 29 Jun 2018
Cheers for that one, Jim. I have downloaded a trial of Designer 2018 which is 2D only, but that is all I will ever want. An 868MB download though - crikey!
I will try it out and see if it is any easier to use then QCAD - they are both about the same price, so then I can pick one.
Posted: 03:57am 29 Jun 2018
The most important thing to do is check that it can output in a format that the laser people can read.
VK2MCT
I use MS Visio, which I have used for years.
Not cheap tho.
John.
atmega8
Posted: 04:33am 29 Jun 2018
Give it a try:
Frontpanel Designer from Abbacus
Posted: 05:07am 29 Jun 2018
Well, for 860MB of download(and 1.7GB of install!), you would expect the application do actually DO something, which it does not. Took ages to install, then gives me a trial reminder window where I can purchase and activate, or continue with the 15 day trial. I click on continue, and the application closes. I never get past that point. Not impressed, uninstalled.
Will try Frontpanel Designer, Danke atmega8.
EDIT: Oh, Front Designer! I have that. I used it to make all my decals. It cannot export DXF files though, so I can't send the results to the laser-cutting place.Edited by Grogster 2018-06-30
MicroBlocks
Posted: 05:49am 29 Jun 2018
I have a laser cutter and I know DXF is not the only format that can be processed.
It is the default for CAD programs but it is no the best for lasercutters actually as the DXF format does not really support curves very well, they are replace with short lines.
Formats like .ai (adobe illustrator) or .svg (Inkscape) are in my opinion better as they need less conversion to the lasercutters internal format.
Ask your laser cutting place about those formats. If they can not handle them, you have a reason to doubt if they are professional. :)
Make sure you also add a little 1cmx1cm square to your design as sometimes scaling can be a problem with conversions. The little square is easy to check and confirm everything was processed correctly.Edited by MicroBlocks 2018-06-30
Posted: 07:02am 29 Jun 2018
[Quote=MB]the DXF format does not really support curves very well, they are replace with short lines.[/Quote]
Funny you should say that, as one panel I got done at one place, the round holes were not round as you point out. They were lots of little straight lines. It did not REALLY matter once the switch was mounted in that hole, but if it was going to be visable, then it WOULD matter. I wondered about that at the time.
SteveA
Posted: 07:23am 29 Jun 2018
Autocad Fusion 360 is free for hobbyists.
Probably overkill for 2d panels and a steep learning curve!
MicroBlocks
Posted: 07:36am 29 Jun 2018
Just use Inkscape. :) Thank me later. :)
Posted: 07:56am 29 Jun 2018
QCAD can export to Inkscape SVG files, so that might be me then.
Posted: 08:15am 29 Jun 2018
OK, purchased QCAD for US$40 or so, and when I did that, they offered the E-book of some 276 pages for only 12 Euro more, so I added that too.(normal price is 30 Euro for the E-book) I am sure the book will come in handy.
@ MB: Here is the 'Advanced SVG export' option....
Quazee137
Posted: 08:19am 29 Jun 2018
Inkscape has been a great tool for may years.
Here's one I am using as a 3D viewer tool.
FreeCAD
there is Linux, Mac and Windows downloads.
MicroBlocks
Posted: 08:31am 29 Jun 2018
Looks ok. I would deselect 'Export point entities'. Points do not have any diameter or width anyway.
Lines also should be without a line width.
A laser cutter has a kerf of about 0.2mm. If you need very tight fits then you will have to do some tests. For example a 8mm hole will end up being 8.2mm. Most of the time not a problem, but if it is you need to adjust for it by shrinking the diameter with 0.2mm.
This changes with every lasercutter and even with the same machine it changes when using different speeds and power settings.
Extruded acrylic is a more consistent and cuts easier and leaves a nice edge.
Colored acrylics however are often cast and this has more variances in thickness.
For instance a 3mm thick sheet can be anywhere between 2.5 and 3mm. Sometimes you have to keep this in mind when it needs to be tight fitting in thickness.
Posted: 09:09am 29 Jun 2018
@ MB: One of the things I was thinking of designing in QCAD - other then the steel panels, was an acrylic case or at least a nice looking bezel for the 5" LCD and 7" LCD. This would allow people to box-up their 5" or 7" LCD projects with a professional looking LCD bezel or perhaps a full case. 3D printed ones just don't look professional enough to me. They are OK, but they look rough due to the way that 3D printers work.
yobortsa
Posted: 10:49am 29 Jun 2018
My reply too late Grogster being that you have ordered, but for reference I use LibreCAD and drive my machine with K40 Whisperer. Total non-proprietary, free and open source end to end. I find LibreCAD frustrating, being used to AutoCAD from way back, but I percist in order to use open source software. The solution is now robust and reliable and runs on low spec PCs.
For 3D printing, I generally use OpenSCAD but am trying FreeCAD which is a beast in comparison but nothing like the size of the commercial alternatives.
Regards, David
CircuitGizmos
Posted: 07:42pm 29 Jun 2018
https://www.freecadweb.org/wiki/Screenshots
Another free option.
