Local Time 10:49 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Armmite L4: 5.05.04 STM32L476 support
Posted: 06:28pm 02 Jan 2019
This release includes support for the STM32L476RG as used on the NUCLEO-L476RG. The same binary is used for all supported L4 devices.
The STM32L476RG has the advantage of more RAM and more flash memory but due to a pin conflict it loses one of the three SPI ports.
MM.DEVICE$ now returns "Armmite L476 - 64 pin" for the STM32L476RG and "Armmite L43x - nn pin" for the L43x series devices
In addition the release supports the ST7789 display
OPTION LCDPANEL ST7789, orientation, DCpin, RESETpin, CSpin
and specific measurements of the chip characteristics
PIN(TEMP) ' returns the die temperature of the chip
PIN(VDDA) ' returns the calculated value of the analogue reference voltage
PIN(BAT) ' returns the RTC battery voltage
PIN(SREF) ' returns the measured internal reference voltage with a VDDA of exactly 3.0V
PIN(VDDA) seems to give a higher voltage than would be expected (approximately 3.4V with an real input of 3.3V) but using it to set OPTION VCC does seem to yield more accurate analogue readings - for example to accurately read the RTC battery voltage use:
OPTION VCC PIN(VDDA)
PRINT PIN(BAT)
Edited by matherp 2019-01-04
Posted: 09:05pm 02 Jan 2019
Firmware link?
Posted: 10:56pm 02 Jan 2019
  Quote  Firmware link?
It was there honest
2019-01-03_085559_ArmmiteL4.zip
Posted: 11:03pm 02 Jan 2019
Thanks.
I ordered a NUCLEO-L433RC and some bare chips yesterday.
It might be a while before I can find an excuse for the STM32L476RG.
It will get used to pad an order out to the free freight level.
sawasdee01
Posted: 01:00pm 03 Jan 2019
Hi Matherp,
Happy New Year and thank you for a truly wonderful addition to the MM family.
Wrt to the ST7789 display driver - what are your thoughts on a capacitive touch screen driver for the many low cost 240x240 displays that have this option?
Along with the low power features of the STM32L476, this would create a fantastic foundation platform for wearable projects.
Best wishes.
Sawasdee
Posted: 02:05pm 03 Jan 2019
  Quote  what are your thoughts on a capacitive touch screen driver for the many low cost 240x240 displays that have this option?
Please provide a link and I'll have a look
sawasdee01
Posted: 05:25pm 03 Jan 2019
Hi Matherp,
Although this is a very common display, as it is used in many wearable devices, there are quite a few variations to connectors, pinouts, etc. I have tried to select three reasonably stable and well known suppliers (if there is such a thing).
You may need to paste the links below directly into the address bar of Google for the searches to work correctly:-
TOPFOISON
A 240x240 ST7789 based display with a pre-installed capacitive touch screen. Uses the FT6206 touch screen controller.
https://topfoison.en.alibaba.com/product/60851500049-807524730/Topfoioson_1_6_inch_240_240_sunlight_readable_tft_lcd_dis play_for_sport_application.html?spm=a2700.icbuShop.41413.11.70cf15c9oFuSxE
AMELIN
A 240x240 ST7789 based display with a pre-installed capacitive touch screen. Uses the FT6336G touch screen controller.
https://amelin.en.alibaba.com/product/60830257164-807938078/1_54_inch_lcd_touch_screensmall_lcd_screen_100_new_IPS_TFT_2 40_240_with_CTP.html?spm=a2700.icbuShop.41413.17.68f97afdInuloK
FORMIKE
A 240x240 ST7789 based display with a pre-installed capacitive touch screen. Almost definitely uses either the FT5306 or FT5206 touch screen controller.
https://www.alibaba.com/product-detail/IPS-screen-1-54-inch-tft_60786707992.html?spm=a2700.icbuShop.41413.23.65132b8cwod Kc4
All three displays have SPI interfaces, although there are also modules available with the MCU (8080?) type interface.
I suspect that the Topfoison will be the highest quality product of the three and has a unit price of approx US $16 based on MOQ 1. The others can be had for approx $10 MOQ 1.
Best wishes.
Sawasdee
panky
Posted: 04:21am 04 Jan 2019
Fired up both L4's (L432KC and L476RG) with the latest code above using MBED - both worked straight out of the box. Have not tested with displays yet.
panky
PS. Love the NUCLEO-L476RG - quick, low power and almost as much memory as a 470, fully assembled with Arduino shield connection, all pins broken out, ST Link i/f included and CHEAP (A$23 from rs-components delivered overnight to country NSW freight free - less than assembled 170's).
Posted: 08:42am 04 Jan 2019
  Quote  Fired up both L4's (L432KC and L476RG) with the latest code above using MBED - both worked straight out of the box.
Glad it is all working for you. The L4 code is pretty much where I want it now subject to bugs found and fixed.
I have one more feature to add which is to allow the com port to wake the CPU from sleep. This would allow you to set up COM1 listening to an HC12 or similar and then go to sleep. Any incoming data could then wake the processor which could execute the incoming request and then go back to sleep - perfect for remote logging type applications.
I then really need to do a manual pulling together all the goodies included in the L4 - I hate documenting
Are you using the flash file system? This, I think, is a real strong point of the L4 implementation.
panky
Posted: 09:40am 04 Jan 2019
Cheers Peter,
I will connect up a flash ram chip tomorrow, test and let you know.
Doug.
panky
Posted: 03:19am 05 Jan 2019
Peter,
Some problems with the L476 - I am using an Arduino shield with the Winbond 25Q32 on it wired as per your instructions. I have wired D8 on the shield as the 25Q32 chip select line. So, starting up ...
> ARMmite L4 MMBasic Version 5.05.04
Copyright 2011-2018 Geoff Graham
Copyright 2016-2018 Peter Mather
> print mm.device$
ARMmite L476 - 64 pin
> print mm.ver
5.0504
> option vcc pin(vdda)
> print pin(bat)
3.302277252
> print pin(temp)
16
... all OK so far.
Now I want to use pin D8 as the chip select for the 25Q32 so I test it first -
> setpin D8,dout
Error: Pin 0 is invalid
... as pin D8 is on pin 42 of the STM
> setpin 42,dout
> pin(42) = 0
... measured 0 on pin 42 / D8
> pin(42) = 1
... measured 3.3V on pin 42 / D8 so pin 42 is D8 and works.
Now I try to set up the flash
> Option flash D8
> Option flash 42
Compatible flash memory not found
... so,
I have double checked the wiring to the 25Q32 and it is as follows
Pin 1 : Chip select, connect to any free pin on the uP - I am using D8
Pin 2 : SPI data out, connect to SPI2-IN (D12) on the uP
Pin 3 : _Write enable, connect to GND
pin 4 : GND, connect to GND
pin 5 : SPI data in, connect to SPI2-OUT (D11) on the uP
pin 6 : SPI clock, connect to SPI2-CLK (D13) on the uP
pin 7 : RESET, connect to RST on the uP
pin 8 : VCC, connect to 3.3V
Any suggestions as to where I am going wrong?
Doug.
NB. The Arduino numbering does not work on the L432 either. D.
Disregard - dopey Doug - of course it does not work on the L432 - there is no Arduino connector there!!!
Edited by panky 2019-01-06
panky
Posted: 05:21am 05 Jan 2019
Further to my last post above, a short looping program writing to SPI2 appears to have the clock on PB3 (Pin 31 of CN10/D3 on the Arduino connector) and SPI2 MOSI on PB5 ( Pin 29 of CN10/D4 on the Arduino connector).
Doug.
Posted: 08:41am 05 Jan 2019
The Arduino nomenclature is supported on the 432 but not (yet?) on the 476 - just use normal pin numbers. See the pinout details at the end of the first page of this thread for details.
{ GPIOB, GPIO_PIN_3, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 55 SPI2-CLK
{ GPIOB, GPIO_PIN_4, DIGITAL_IN | DIGITAL_OUT , NULL, 0},// pin 56 SPI2-IN
{ GPIOB, GPIO_PIN_5, DIGITAL_IN | DIGITAL_OUT , NULL, 0},// pin 57 SPI2-OUT
Edited by matherp 2019-01-06
Posted: 10:39am 05 Jan 2019
This minor update allows you to use the Arduino nomenclature for pins on the NUCLEO-L476RG or NUCLEO-L433RC, e.g.
SETPIN A1,AIN
SETPIN D2,DOUT
PIN(D2)=1
PRINT PIN(A1)
2019-01-05_203903_ArmmiteL4.zip
Note: the special functions assigned to the pins do not map the silkscreening on the Nucleo - see table below. Also D0 and D1 are the console pins so cannot be used for normal I/O
{ NULL, 0, PUNUSED , NULL, 0}, // pin 1 VBAT
{ GPIOC, GPIO_PIN_13, DIGITAL_IN | DIGITAL_OUT, NULL, 0}, // pin 2
{ NULL, 0, PUNUSED , NULL, 0}, // pin 3 OSC32_IN
{ NULL, 0, PUNUSED , NULL, 0}, // pin 4 OSC32_OUT
{ GPIOH, GPIO_PIN_0, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 5
{ GPIOH, GPIO_PIN_1, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 6
{ NULL, 0, PUNUSED , NULL, 0}, // pin 7 NRST
{ GPIOC, GPIO_PIN_0, DIGITAL_IN | DIGITAL_OUT | ANALOG_IN , ADC1, ADC_CHANNEL_1}, // pin 8 -A5
{ GPIOC, GPIO_PIN_1, DIGITAL_IN | DIGITAL_OUT | ANALOG_IN , ADC1, ADC_CHANNEL_2}, // pin 9 -A4
{ GPIOC, GPIO_PIN_2, DIGITAL_IN | DIGITAL_OUT | ANALOG_IN , ADC1, ADC_CHANNEL_3}, // pin 10
{ GPIOC, GPIO_PIN_3, DIGITAL_IN | DIGITAL_OUT | ANALOG_IN , ADC1, ADC_CHANNEL_4}, // pin 11
{ NULL, 0, PUNUSED , NULL, 0}, // pin 12 VSS
{ NULL, 0, PUNUSED , NULL, 0}, // pin 13 VDD
{ GPIOA, GPIO_PIN_0, DIGITAL_IN | DIGITAL_OUT | ANALOG_IN , ADC1, ADC_CHANNEL_5}, // pin 14 COUNT/WAKEUP/IR -A0
{ GPIOA, GPIO_PIN_1, DIGITAL_IN | DIGITAL_OUT | ANALOG_IN , ADC1, ADC_CHANNEL_6}, // pin 15 SPI-CLK -A1
{ NULL, 0, PUNUSED , NULL, 0}, // pin 16 CONSOLE-TX -D1
{ NULL, 0, PUNUSED , NULL, 0}, // pin 17 CONSOLE-RX -D0
{ NULL, 0, PUNUSED , NULL, 0}, // pin 18 VSS
{ NULL, 0, PUNUSED , NULL, 0}, // pin 19 VDD
{ GPIOA, GPIO_PIN_4, DIGITAL_IN | DIGITAL_OUT | ANALOG_IN , ADC1, ADC_CHANNEL_9}, // pin 20 DAC-1 -A2
{ GPIOA, GPIO_PIN_5, DIGITAL_IN | DIGITAL_OUT | ANALOG_IN , ADC1, ADC_CHANNEL_10}, // pin 21 DAC-2 -D13
{ GPIOA, GPIO_PIN_6, DIGITAL_IN | DIGITAL_OUT | ANALOG_IN , ADC1, ADC_CHANNEL_11}, // pin 22 SPI-IN -D12
{ GPIOA, GPIO_PIN_7, DIGITAL_IN | DIGITAL_OUT | ANALOG_IN , ADC1, ADC_CHANNEL_12}, // pin 23 SPI-OUT -D11
{ GPIOC, GPIO_PIN_4, DIGITAL_IN | DIGITAL_OUT | ANALOG_IN , ADC1, ADC_CHANNEL_13}, // pin 24
{ GPIOC, GPIO_PIN_5, DIGITAL_IN | DIGITAL_OUT | ANALOG_IN , ADC1, ADC_CHANNEL_14}, // pin 25
{ GPIOB, GPIO_PIN_0, DIGITAL_IN | DIGITAL_OUT | ANALOG_IN , ADC1, ADC_CHANNEL_15}, // pin 26 -A3
{ GPIOB, GPIO_PIN_1, DIGITAL_IN | DIGITAL_OUT | ANALOG_IN , ADC1, ADC_CHANNEL_16}, // pin 27 COUNT
{ NULL, 0, PUNUSED , NULL, 0}, // pin 28
{ GPIOB, GPIO_PIN_10, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 29 COM2-TX -D6
{ GPIOB, GPIO_PIN_11, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 30 COM2-RX
{ NULL, 0, PUNUSED , NULL, 0}, // pin 31 VSS
{ NULL, 0, PUNUSED , NULL, 0}, // pin 32 VDD
{ GPIOB, GPIO_PIN_12, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 33
{ GPIOB, GPIO_PIN_13, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 34 SPI3-CLK
{ GPIOB, GPIO_PIN_14, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 35 SPI3-IN
{ GPIOB, GPIO_PIN_15, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 36 SPI3-OUT
{ GPIOC, GPIO_PIN_6, DIGITAL_IN | DIGITAL_OUT, NULL, 0}, // pin 37
{ GPIOC, GPIO_PIN_7, DIGITAL_IN | DIGITAL_OUT, NULL, 0}, // pin 38 -D9
{ GPIOC, GPIO_PIN_8, DIGITAL_IN | DIGITAL_OUT, NULL, 0}, // pin 39
{ GPIOC, GPIO_PIN_9, DIGITAL_IN | DIGITAL_OUT, NULL, 0}, // pin 40
{ GPIOA, GPIO_PIN_8, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 41 PWM1A -D7
{ GPIOA, GPIO_PIN_9, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 42 COM1-TX / PWM1C -D8
{ GPIOA, GPIO_PIN_10, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 43 COM1-RX / PWM1D -D2
{ GPIOA, GPIO_PIN_11, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 44 PWM1B
{ GPIOA, GPIO_PIN_12, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 45 COM1-DE /COUNT
{ NULL, 0, PUNUSED , NULL, 0}, // pin 46 SWDIO
{ NULL, 0, PUNUSED , NULL, 0}, // pin 47 VSS
{ NULL, 0, PUNUSED , NULL, 0}, // pin 48 VDD
{ NULL, 0, PUNUSED , NULL, 0}, // pin 49 SWCLK
{ GPIOA, GPIO_PIN_15, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 50
{ GPIOC, GPIO_PIN_10, DIGITAL_IN | DIGITAL_OUT, NULL, 0}, // pin 51
{ GPIOC, GPIO_PIN_11, DIGITAL_IN | DIGITAL_OUT, NULL, 0}, // pin 52
{ GPIOC, GPIO_PIN_12, DIGITAL_IN | DIGITAL_OUT, NULL, 0}, // pin 53
{ GPIOD, GPIO_PIN_2, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 54
{ GPIOB, GPIO_PIN_3, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 55 SPI2-CLK -D3
{ GPIOB, GPIO_PIN_4, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 56 SPI2-IN -D5
{ GPIOB, GPIO_PIN_5, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 57 SPI2-OUT -D4
{ GPIOB, GPIO_PIN_6, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 58 I2C-SCL -D10
{ GPIOB, GPIO_PIN_7, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 59 I2C-SDA
{ NULL, 0, PUNUSED , NULL, 0}, // pin 60 BOOT0
{ GPIOB, GPIO_PIN_8, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 61 PWM2A -D15
{ GPIOB, GPIO_PIN_9, DIGITAL_IN | DIGITAL_OUT , NULL, 0}, // pin 62 -D14
{ NULL, 0, PUNUSED , NULL, 0}, // pin 63 VSS
{ NULL, 0, PUNUSED , NULL, 0}, // pin 64 VDD
panky
Posted: 10:42pm 05 Jan 2019
Thanks Peter,
File system working now on the L476 using the Winbond 25Q32 on SPI2. Arduino style pin numbering also works - thanks very much.
Doug.
djuqa
Posted: 05:37am 09 Jan 2019
Just recieved my STM32 Nucleo board
Installed your wonderful version of MMBasic
Worked first time
You are (Plus Geoff) brilliant
UPDATE:-
Un-installed Armmite Firmware
It works OK, but I have re-installed the Original firmware
as it suits my purposes better.
Edited by djuqa 2019-01-11
VK4MU MicroController Units
panky
Posted: 06:24am 10 Jan 2019
Peter,
I am trying to hook up a SSD1306 1.3" I2C display to the L476
OPTION LCDPANEL SSD1306I2C,L,2
Your pinout doco above says I2C is on pins 58 and 59 of the L476
{ GPIOB, GPIO_PIN_6, DIGITAL_IN | DIGITAL_OUT ,NULL, 0}, // pin 58 I2C-SCL -D10
{ GPIOB, GPIO_PIN_7, DIGITAL_IN | DIGITAL_OUT ,NULL, 0}, // pin 59 I2C-SDA
I can see the I2C clock on D10 of the Arduino connector which is pin 58 (PB6) of the L476. You show the I2C data being on pin 59 (PB7) however, this does not go out to the Arduino connector ( in fact, the circuit diagram shows it going to CN7-21 although I can not see any signal activity here).
Should I2C SDA be going to pin 38 of the L476 which is PC7 (Arduino D9)?
Doug.
Posted: 08:04am 10 Jan 2019
The pinout is correct. I2C-SDA does not appear on the Arduino connector
  Quote  Note: the special functions assigned to the pins do not map the silkscreening on the Nucleo - see table below. Also D0 and D1 are the console pins so cannot be used for normal I/O
Just tested a BMP180 on CN10-17/CN7-21 and it works perfectly
panky
Posted: 11:13pm 10 Jan 2019
Peter,
Tested the SSD1306i2c display on an L432 on PB6/D5 as SCL and PB7/D4 as SDA with the initialisation command -
tested with
TEXT 5,5,"Hello world"
.. works perfectly!
Tested the same display, same interconnect cables (double checked) on the L476 on PB6/CN10-17 as SCL and PB7/CN7-21 as SDA
Initialised and tested as above - no go! No display!
Running the same 5.05.04 on both.
Any suggestions?
Edit. Loaded up the latest 5.0505 - same results.
Edited by panky 2019-01-12
Posted: 10:26am 11 Jan 2019
  Quote  Any suggestions?
Thanks for the report - you found a serious bug for both 48 and 64 pins that was nothing to do with I2C but that just showed a symptom that enabled me to find it. See 5.05.05 thread for fix
