Forum Index : Microcontroller and PC projects : Digital potentiometer?
| Page 1 of 2 |
Shamelessly looking for a short cut, here. Any recommendations/code out there? Cheers, Craig |
| SimpleSafeName Guru Joined: 28/07/2019 Location: United StatesPosts: 351 |
How about? PRINT "Hello World" :) |
| hitsware2 Guru Joined: 03/08/2019 Location: United StatesPosts: 738 |
I've had sucess with some much like these ... look here Edited 2020-04-04 23:51 by hitsware2 my site |
My apologies, I didn't read the title and I thought that you were looking for code ideas. LOL! |
No, that was funny Ah, many thanks |
goc30![]() Guru Joined: 12/04/2017 Location: FrancePosts: 435 |
hi tinine I give you an example of test prog for pot chip 4131 in SPI mode Pin(16)=1:SetPin 16,dout 'for CS valpot=&h1 'value to output Do Pin(16)=0 'active cs SPI open 5000000,3,8 junk=SPI(0) byte1=SPI(valpot) Pin(16)=1 SPI close Pause 1000 valpot=valpot+1 if valpot=64 then valpot=1 Loop |
Thanks for that code Goc Strange how things come up when you need them... I was also playing with digital pots and had been looking at the MCP4131... |
Quazee137![]() Guru Joined: 07/08/2016 Location: United StatesPosts: 603 |
There are a lot now days have a look at Analog Devices Funny in unpacking I found the demo playback unit today. Studio boards and code where abouts to be discovered. Years ago I used Xcore X9103 with 8748 in a message playback unit. It was sold for "message on hold telephone", in "store advertising shelf" and a rental truck "vocal guide to shifting" Had to make a studio board for a 286 motherboard with 2meg add on card as "ram Disk" the HD's at the time wasn't fast enough. and the noise from the power supply was a major problem to over come. Coding was Borland Pascal with a lot inline assembly. Hope you don't mine going down memory lane with me. ![]() The keypad was printed with my $240 radioshack printer "My mortgage was $105" layout/etching in the kitchen. Very Fun days. ![]() ![]() ![]() ![]() When I find the studio card I'll post few pic's. Hand wired. The Xcore series was the only D-pot I could find at the time that used U/D count pins it was easy to code for in 8748 asm. Today with MMBasic and the mites this would be a maybe few nights of coding and not the 18 months of programing/hardware trouble shooting on the 286 under MSDOS. The 8748 was not bad to program for. I'm Still having FUN doing this stuff. MMBasic has made it even more so !!! Thanks Geoff, Peter Mather, Robert Rozee, Serge Vakulenko, Jim Tassy and ALL the BACKSHEDERS that make this so ENJOYABLE and all the help given. BE SAFE ALL Quazee137 Edited 2020-04-05 06:32 by Quazee137 |
Yeah many thanks Goc ![]() Holy moly, 88 page data sheet!?!?!?! |
not at all Quazee... perhaps we should ask Glenn to make a specific forum for random "Memory lane... Stuff we made" posts. Back in 1995 I was working on a call router for least cost routing automatically... found the first PCB of the prototype the other day, while clearing out some junk. |
Craig, Dan Amos wrote up an article in Silicon Chip's Circuit Notebook (June 2016 p86) using a Micromite BackPack, an MCP4131 digital pot and an AD9833 DDS sig gen chip. The MMBasic code for that which uses SPI to the 4131, is available from Silicon Chip. Greg |
| mikeb Senior Member Joined: 10/04/2016 Location: AustraliaPosts: 180 |
Eproms. Remember those ? Baking them under UV, for 15 mins to reprogram. And greencaps. Very nostalgic. I remember a colleague putting the first Motorola 68HC microcontroller he ever played with in the socket backwards. AUD $95.00 back in 1985. There are 10 kinds of people in the world. Those that understand binary and those that don't. |
| Lightrock Newbie Joined: 19/05/2014 Location: AustraliaPosts: 26 |
Geoff Graham has an article on a DDS Signal Generator on his web site which uses a Microchip MCP41010 digital potentiometer for level control. Geoff's article was in Silicon Chip April 2017. Code is also available from both sources |
Many Thanks! Interesting to learn that above 211, it becomes distorted. ' sets the digital potentiometer (0-255) ' derived from an example written by Peter Mather (matherp on the Back Shed forum) ' note that when running on 3.3V the maximum undistorted level is 211 Sub SetLevel Local Integer x = (Level/100) * 211 SPI Open 1000000, 2, 16 Pin(CS) = 0 SPI write 1, x Or &H1100 Pin(CS) = 1 SPI Close End Sub Cheers! Craig |
Hi tinine I found another application with the MCP4131, it is an assembly allowing to manage the pulse width of a PWM. It is based on a 555 chip drived by the MCP http://tibuworks.blogspot.com/2013/05/pwm-sincrono-synchronous-pwm.html ![]() for using mcp4131 with an mx170. you must avoid the 28pin version, because it does not work properly, however with the 44pin version it is correct. I put here the last version that I tested with explorer64 (and validated with an arduino) const pincs=60 'chipselect mcp4131 const pinrel=16 'I have led on this pin const pinvl=30 'pin for ana read value dim i as integer dim valpot as integer dim valin as float setpin pinrel,DOUT SetPin pincs,dout setpin pinvl, ain Pin(pincs)=1 Pin(pinrel)=1 valpot=&h1 'value to output SetTick 500, task1,1 ' tache de base a faire toutes les 10ms utile pour eteindre led de signalisation do Pin(pincs)=0 'active cs SPI open 10000000,0,16 junk=SPI(0) spi write 1,valpot Pin(pincs)=1 SPI close valpot=valpot+1 if valpot=>256 then valpot=1 pause(50) valin=pin(pinvl) print "pot=";str$(valpot);" lue:";str$(valin) loop sub task1() pin(pinrel)=(pin(pinrel) xor 1) end sub |
@goc30 Is there a known problem with the SPI on the 28 pinner? It's this device that I am intending to use. Regards, Craig |
I do not know where the problem comes from, but I did not search in detail. I have a few tracks, either add a pullup on the SDI / SDO line (see picture), or there is a problem with pin3 (which is also used as vref-). I have a little time right now, since we're locked up, so I'm going to study the matter |
I have used MCP4151 with 28 pinner with no issues. Only MCU SDO is connected to the SDI/SDO pin and MCU SDI is not connected. Seems to work OK. F4 H7FotSF4xGT |
I have only used the 28 pin and remember no problems . my site |
Hi all Have you also use analog pin in sme time?? (to read mcp value) |
| Page 1 of 2 |
