Local Time 13:02 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: 270.000 lines of code per second, question
Decoy
Posted: 01:55pm 16 Jul 2020
Hi guys
This might be a silly question. I understand that the CMM2 is able to do 270000 lines of MMBasic per second.
I need to reference this to something - as an example, how many lines could a C64
pull off?
I know that a line isn't just a line, and that the numbers are dependent on what
the intructions on the line is.
Thanks,
Nicholas
Poppy
Posted: 02:16pm 16 Jul 2020
https://www.youtube.com/watch?v=IA7REQxohV4
This Guy apparently just took it from here.
  Quote  Full featured BASIC interpreter with double precision floating point, 64-bit integers and string
variables, long variable names, arrays of floats, integers or strings with multiple dimensions, extensive
string handling and user defined subroutines and functions. Typically it will execute a program at
270,000 lines per second.
Colour Maximite 2 User Manual - Page 4
And we need to know how Geoff measured it practically, to have a standard-code for an objective benchmark!
  Quote  I know that a line isn't just a line, and that the numbers are dependent on what
Just because!
Andre ... such a GURU?
Posted: 02:25pm 16 Jul 2020
  Quote  ' speed test
' will test and report the speed of MMBasic
SETPIN 3,2 : SETPIN 5, 8
lines = 5
loops = 1000000
TIMER = 0
' start of the timed section (5 lines)
FOR i = 1 TO loops
 inp = PIN(3)
 PIN(5) = inp
 cnt = cnt + 1
NEXT
PRINT "Speed is"; INT((loops * lines)/(TIMER /1000)); " lines per second."
Posted: 03:26pm 16 Jul 2020
  Decoy said  I need to reference this to something - as an example, how many lines could a C64 pull off?
I suspect it is 100s-1000s of times faster than C64 BASIC.
My specific experience with Z-MIM is that the CMM2 is probably interpreting BASIC at about 50-75% the speed of native 6502 machine code on the C64.
HOWEVER that is just for the basic data-handling and conditional statements. If you are doing something for which the CMM2 BASIC dialect provides built-in support, e.g. graphics or various computationally intensive maths functions then it is O(100) times faster (if not more) than 6502 machine code.
Edited 2020-07-17 01:33 by thwill
Posted: 03:56pm 16 Jul 2020
If you download the latest version
and make a tiny change to the benchmark
' speed test
dim integer i,cnt
lines = 5
loops = 1000000
TIMER = 0
FOR i = 1 TO loops
 inp = PIN(3)
 PIN(5) = inp
 cnt = cnt + 1
NEXT
You can now get 282000 lines per second
Posted: 07:03pm 16 Jul 2020
Coming in RC4
abraxas
Posted: 09:21pm 16 Jul 2020
Pete, what changes are you making in the release to optimize the interpreter? What expressions are going to see the most improvements?
mkopack73
Posted: 09:28pm 16 Jul 2020
Once mine arrives I plan to make a series of simple benchmarks to do comparisons between the CMM2, My C128 running in both 40 and 80 column modes (using BASIC 7 in 40 column, Basic 8 on the 80 column mode), and the C64 using Simons' Basic (to get the graphics commands).
I'm planning to do comparisons on:
Bubble Sort of an array of 1000 random numbers   (performed 10 times)
Calculating Pi to 1000 digits (using a relatively slow method)
2x2 matrix fill of 100x100 elements (tests looping speeds with nested loops)
Drawing colored random lines
Drawing unfilled + filled random rectangles
Drawing unfilled + filles ovals
Any other simple tests you guys can think of you'd like me to try?  (something that doesn't require me to do stuff in Assembly on the Commodore because I have NO idea on that stuff...)
Edited 2020-07-17 07:41 by mkopack73
Posted: 01:49am 17 Jul 2020
here is a rather classic speed test:
Print "Sieve of Eratosthenes Speed Test"
Print
Start = Timer
10 W=500:Dim F(W):P=1:A=3
20 F(P)=A:P=P+1:If P>W Then GoTo DONE
30 A=A+2:X=1
40 S=A/F(X):If S=Int(S) Then 30
50 X=X+1:If X<P And F(X)*F(X)<=A Then 40
60 GoTo 20
DONE:
Elapsed = (Timer-Start)/1000
Print Elapsed " seconds"
Print
I = 0 ' statement counter
J = 0 ' line counter
Erase F
110 I=I+4: J=J+1: W=500:Dim F(W):P=1:A=3
120 I=I+3: J=J+1: F(P)=A:P=P+1:If P>W Then GoTo FINI
130 I=I+2: J=J+1: A=A+2:X=1
Print ,P Chr$(13);
140 I=I+2: J=J+1: S=A/F(X):If S=Int(S) Then I=I+1: GoTo 130
150 I=I+2: J=J+1: X=X+1:If X<P And F(X)*F(X)<=A Then I=I+1: GoTo 140
160 I=I+1: J=J+1: GoTo 120
FINI:
Print I " statements"
Print J " lines"
Print
Print I / Elapsed " statements per second"
Print J / Elapsed " lines per second"
Print
> run
5.403 seconds
48122 statements
19747 lines
8906.53 statements per second
3654.82 lines per second
with a number of results for many 80's systems here:
http://www.retroprogramming.com/2010/01/8-bit-home-computer-benchmarks.html
and a compiled list:
How Fast Were Those Late 1970s Home Computers?
8-Bit Home Computer Benchmarks
computer model clock CPU time
TRS 80 model I with Level II Basic 1.77 MHz Z80 421s
Sinclair ZX Spectrum +3 3.55 MHz Z80A 388s
Tandy 102 2.40 MHz 80C85 367s
Atari 130XE (Atari BASIC Rev. C) 1.79 MHz 6502C 338s
Atari 800XL 1.80 MHz 6502 316s
Tandy 64K CoCo 2 0.90 MHz 6809E 271s
Commodore Plus/4 1.80 MHz 8501 267s
Sony F1XV MSX2+ (MSX Microsoft BASIC 3.0) 3.58 MHz Z80A 260s
Commodore C64 1.00 MHz 6510 254s
Commodore VIC-20 (Microsoft BASIC 2a) 1.00 MHz 6502 234s
TRS-80 Micro Colour Computer (MC-10) 0.90 MHz 6803 220s
Apple IIe Enhanced (Applesoft II) 1.00 MHz 6502 211s
Sharp MZ-731 4.00 MHz Z80A 182s
Commodore 128 2.00 MHz 8502 152s
Tandy 64K CoCo 3 1.79 MHz 809E 147s
Amstrad CPC464 4.00 MHz Z80A 140s
Acorn Electron 2.00 MHz 6502 138s
BBC Model B (BBC BASIC 2) 2.00 MHz 6502 101s
BBC Master (BBC BASIC 4) 2.00 MHz 65SC12 76s
(the below list compiled June 2017)
Micromite MX150 40 MHz mips M4K 6.86s
Micromite MX170 (Mk II) 40 MHz mips M4K 5.31s
Micromite MX470 (plus) 100 MHz mips M4K 2.96s
Micromite MZ2048 (extreme) 200 MHz mips M 1.12s
MMbasic on RPi Zero (JG) ARMv6 0.89s
MMbasic on RPi B+ (DH) ARMv6 0.67s
MMbasic on RPi Zero W (PM) ARMv6 0.63s
MMbasic on RPi 3 (DH) ARMv8 0.22s
MMbasic on RPi 3 (PM) ARMv8 0.19s
MMbasic for WIN32 2400 MHz i7 0.06s
from this thread:
https://www.thebackshed.com/forum/ViewTopic.php?TID=9686
rob   :-)
vegipete
Posted: 05:35am 17 Jul 2020
That speed test is quite the bit of code but it is not the Sieve of Eratosthenes.
It's interesting, I find I am very out of tune with 'classic' BASIC, with line numbers and GOTOs. Perhaps I have largely purged the spaghetti code mindset. So I had some trouble understanding what that snippet from line 20 to line 60 was actually doing.
My rewrite in structured form looks like the following, although I cheat a bit and use "exit loop" statements. (Curiously, my rewrite is slightly faster than the original. Completely irrelevant for a performance test, but curious none the less.)
T3 = Timer
p = 1     ' position in array to store next prime
a = 3     ' number to be evaluated for primeness
F(p) = a  ' 1st one is chosen as prime
p = p + 1 ' advance to next position
do
 a = a + 2   ' next candidate prime
 x = 1       ' start with 1st prime
 do
   s = a / F(x)  ' test for division with no remainder
   if s = int(s) then exit do  ' divides evenly so this one isn't prime
   x = x + 1     ' advance to next prime with which to test candidate
   if x > p or F(x) * F(x) > a then ' stop testing after sqr(a)
     F(p) = a    ' found a new prime so save it
     p = p + 1   ' bump index
     exit do     ' time to start testing next prime candidate
   end if
 loop
loop until p > 500
T4 = Timer
Posted: 06:33pm 17 Jul 2020
mkopack73
Posted: 09:30pm 17 Jul 2020
  vegipete said  That speed test is quite the bit of code but it is not the Sieve of Eratosthenes.
I feel your pain... Last night I sat down at my C128D and tried to write a little simple program that would generate an array of random numbers, then do a simple bubble sort on them, timing the run, and then repeat it 10 times and avg the time results....
It was SOOOOOOO painful going back to old style Commodore BASIC, no while/Wend or repeat/until, etc., the old style editor (there was a time when I would have taken the C64 screen editor over VI in a heartbeat - not anymore!) the "everything in uppercase" and huge font...
Needless to say it took me about 2 hours to get something that should have been very simple working the way I wanted it to.
THANK GOD CMM2 and MMBasic are modern and reasonable...
GregZone
Posted: 04:20am 20 Jul 2020
  matherp said  If you download the latest version
' speed test
dim integer i,cnt
lines = 5
loops = 1000000
TIMER = 0
FOR i = 1 TO loops
 inp = PIN(3)
 PIN(5) = inp
 cnt = cnt + 1
NEXT
Hmm... I'm using lastest RC5 and without the DIM line I was ~242000 lines/sec, after adding the pre-declare i,cnt variables the speed only went to ~244000 lines/sec.
How did you achieve 282000 with the same code?
Ahh.. actually, I'm guessing 480Mhz vs 400Mhz STM32?  (I've a 400Mhz chip).
KeepIS
Posted: 04:46am 20 Jul 2020
That is where it shows, I'm still running an older version and your code does 277760 @ 480 MHz.
KeepIS
Posted: 05:27am 20 Jul 2020
Speed 285304 lines per second with MMBasic Version 5.05.04RC5.
abraxas
Posted: 11:21pm 20 Jul 2020
  KeepIS said  Speed 285304 lines per second with MMBasic Version 5.05.04RC5.
Yeah, I have two Waveshare boards and it mirrors my own experience that the 480 MHz version is about 10-15% faster. Not the 20% one might instinctively deduce. The RAM interface is probably limiting the speed somewhat so a faster CPU can only accomplish so much.
KeepIS
Posted: 11:52pm 20 Jul 2020
Similar to the earlier ARMH7 boards that we use running MMbasic, I have one running a big automated CNC type of woodwork routing machine. They started out as 400MHz proto boards that could be overclocked, then a 480MHZ release which could also be overclocked, but in real world programs the difference was not really noticeable, it just made these sort of Speed tests look better.
Mike.
mkopack73
Posted: 12:12am 21 Jul 2020
Just to give some comparison...
Simple BASIC program that generates 20 random integers then performs a bubble sort on them, repeated 10 times to get an average run time...
On a C128 it took 3.5 sec on average (FAST mode)
The cmm2 does it in 10ms!! LOL
berighteous
Posted: 12:58am 21 Jul 2020
Does the CMM2 processor have hardware math?  The horrible soul crushing experience with AppleSoft basic is that 6502 had no math above addition and subtraction, so doing something like this plot
takes several HOURS to draw.
Here's the applesoft code for this:
10 GOTO 40
20 XE = - X * S1 + Y * C1 : YE = -X * C1 * C2 - Y* S1 * C2 + Z * S2 : ZE = - X * S2 * C1 - Y *S2 * S1 + Z * C2 + RHO
30 SX = D * XE / Z E + CX : SY = CY - D * YE / Z E :RETURN
40 RHO = 30 : D = 350 : THETA = .1 : PHI = 1 : CX =140 : CY = 96 : S1 = SIN (THETA) : S2 = SIN(PHI) : C1 = COS (THETA) : C2 = COS (PHI)
50 DEF FN Z(X) = COS (.1 * (X * X + Y * Y))
60 HGR2 : HCOLOR= 3
70 FOR X = -20 TO 20 STEP .3
80 FL = 0
90 FOR Y = - 20 TO 20 STEP .07
100 Z = FN Z(X): GOSUB 20
110 IF SX < 0 OR SX > 279 OR SY < 0 OR SY > 191 THEN FL = 0 : GOTO 140
120 IF FL = 0 THEN FL = 1 : HPLOT SX,SY
130 HCOLOR=3:HPLOT SX,SY:HCOLOR=0:HPLOT SX,SY+1 TO SX,191
140 NEXT Y,X
150 PRINT CHR$(7):GET Q$:TEXT
Even in AppleWin on full speed (like 100x apple native) it took a few minutes to do.
abraxas
Posted: 01:16am 21 Jul 2020
CMM2 definitely has hardware for floating point calculations. Whether the implementation of trig functions in MMBasic is speedy I don't know. Just port and test it. However, with the amount of RAM that CMM2 gives you it's trivial to optimize this by precalculating and storing SIN/COS outputs for a quarter of the circle to the accuracy that is required and then the cost of trig functions will be that of a lookup in an array. You can make this run on a CMM2 in seconds. Maybe faster.
