Local Time 02:28 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Max-E-Man
realmnm
Posted: 11:48am 27 Jul 2020
Hi everyone,
  I've been working on this game for the last week or so now, so thought it was time to show off the progress so far.  There is still a fair bit to do, but I'm pretty happy with how it is coming along.
So I present to you CMM2 Max-E-Man.  It is playable, there are things that are not working or not implemented yet, see the todo list in the readme.tx file for what I know needs to be done.
Any feedback appreciated.
Enjoy,
Martin
Max-E-Man.zip
This signature intentionally left blank.
Posted: 03:35pm 27 Jul 2020
Looking good
Posted: 05:55pm 27 Jul 2020
Good format and nice movement.
  realmnm said  It is playable
How? I got no response with a nunchuk, and didn't find that arrow keys did anything. I haven't played this since it was an arcade game when it first came out, so wondering how it should work?
Atomizer_Zero
Posted: 07:16pm 27 Jul 2020
Nicely done. You can tell the AI isn't spot on yet, but it is close!. player movement super smooth and the game functions great.
Looking forward to trying it out again when its finished
The readme states that you need to enable the nunchuk support in the top of the program. regarding movement, it worked fine with the arrow keys for me, through USB. didnt respond through serial though.
Posted: 08:48pm 27 Jul 2020
Thanks. I read the readme and saw "nunchuk", so went and dug mine out, unused for years. Then it was several hours until I got to where my monitor is, and I had forgotten about having to enable it. And I don't have a keyboard connected, just the laptop.
Now it works--great job--and I have to remember what it is I'm trying to do and how to accomplish it.
Sasquatch
Posted: 09:08pm 27 Jul 2020
WOW Looks great and plays ok.  Almost hard to believe it's all done in BASIC!
-Carl
Posted: 07:55am 28 Jul 2020
Great work in progress Martin,
I now have to find my Nunchuk and give it a try..
I havent seen it since I bought one to test the alignment of my cutouts for the front panel.
It needs sound but I am sure it is in the ToDo list..
Keep up the good work
Kind Regards
Andrew_G
Posted: 06:33am 29 Jul 2020
Hi Martin,
Great effort. Looking forward to the next version!
Cheers,
Andrew
realmnm
Posted: 10:44am 17 Aug 2020
Ok, it's finally here, the new and greatly improved version of Max-E-Man (V0.7).  It has a lot less bugs, and a lot more features, including sound.
I hope you enjoy it as much as I have had in getting it to this point.  It's still not finished yet, but the todo list is getting shorter.
Support for the Nuckchuck in the front port if detected.
Press the 1 key or the Z button on the Nunchuck to start, use the arrow keys or Nunchuck joystick to move, press ESC to quit.
Any feedback is appreciated.
Martin
Max-E-Man.zip
Posted: 04:56am 18 Aug 2020
Hi Martin,
Great job I think this is `almost perfect'
I does need a volume level control.. I run my sound through a logitech bluetooth speaker and it seems the touch volume buttons dont work when fed via the AUX input so the roof tiles get blasted off my roof.
I tried adding a volume command in at the start but I assume you have set the volumes when you play  sounds
Looking great anyway.
If you feeling bored... A good rendition of Galaxians would go down well
Kind Regards
Edited 2020-08-18 14:56 by bigmik
realmnm
Posted: 05:07am 18 Aug 2020
  bigmik said  Hi Martin,
Thanks.  it still needs some more before I am happy with it.
Unfortunately, I had to use the DAC command to play the sound without killing performance, and that doesn't use the volume commands.  I would have to adjust the samples to change the volume.
I can neither confirm nor deny that it is on the to do list.
Martin
vegipete
Posted: 05:48am 18 Aug 2020
  realmnm said  Unfortunately, I had to use the DAC command to play the sound without killing performance, and that doesn't use the volume commands.  I would have to adjust the samples to change the volume.
The "MATH SCALE XXXnoise(), scale_amount, XXnoise()" command should work perfectly for this. Arrays with 1 dimension work fine for scaling.
Alas, Max-E-Man (V0.7) falls over and plays dead when I try to run it.
The error is line 69: data chase, scatter, chase, scatter ...
'Error: chase is not declared'
Looks like the variables/constants in data statements issue.
MMBasic v 5.05.05b10
realmnm
Posted: 05:58am 18 Aug 2020
Thanks, I will look into it.
Me too since I did the upgrade.
Martin
vegipete
Posted: 06:15am 18 Aug 2020
If I fill the const values into the data statements, change the rgb colour words to capitals and ensure I run it from the correct directory, it runs beautifully.
Very nicely done!
About the only annoyance to me is the keypress handling. Your code only checks the first keydown so cornering is sometimes slightly difficult if I've ham-fisted multiple direction keys.
My nunchuk also has trouble hitting the down direction. I often overshoot my desired passageway and end up as fodder. At least I don't have to feed it quarters.
All in all, pretty spectacular in my mind. You are setting the bar very high for the rest of us! (I love the ghost names. Especially Bruce. Did ELO sing about him?)
Sasquatch
Posted: 02:31pm 18 Aug 2020
WoW    This is amazing!!!  And 60FPS in MMBasic???  Great Work!!!  I'll no doubt spend waaay too much time testing this
-Carl
Posted: 02:52pm 18 Aug 2020
I agree with everyone else, that is awesome, just like the real thing
I must sort out a sound solution for my CMM2 so I can enjoy it fully
Jamesk
Posted: 08:44pm 18 Aug 2020
  realmnm said  Ok, it's finally here, the new and greatly improved version of Max-E-Man (V0.7).  It has a lot less bugs, and a lot more features, including sound.
This is amazing work.    A "pixel perfect" port of this game was something I wanted to create back when I was learning BASIC. I decided it was impossible. 40 years later ...
realmnm
Posted: 11:01am 19 Aug 2020
New version 0.71 fixes issues with CONST used in DATA statements.
Requires firmware Version 5.05.05b4 or higher.
I tried to put in a check for firmware versions, but that didn't work as well as I would like, so for now it is not being used.
Enjoy.
Martin
Max-E-Man.zip
ZXKIM81
Posted: 11:16am 19 Aug 2020
i get the [1418]error Sintax
i am on mmbasic version 5.05.4
can any one shed some light on this as i wanna play it
Posted: 11:23am 19 Aug 2020
  ZXKIM81 said  i get the [1418]error Sintax
  realmnm said  Requires firmware Version 5.05.05b4 or higher.
