Local Time 02:43 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Turtle Graphics Demos
Sasquatch
Posted: 09:25pm 02 Aug 2020
Here is a demo using turtle graphics, Each "slide" displays for 10 seconds.
'CMM2 Turtle Graphics Demo
'Adapted from various sources on the Internet
'by "Sasquatch"
Mode 1,8
Draw(400,45.5)
Pause(10000)
Draw (500,55.5)
Pause(10000)
Draw (600,60.2)
Pause(10000)
Draw (800,89.5)
Pause(10000)
Draw (900,110)
Pause(10000)
Draw (1000,119.9)
Pause(10000)
Draw (1000,120.1)
Pause(10000)
Draw (1000,135.1)
Pause(10000)
Draw (1000,145)
Pause(10000)
Draw (1000,176)
Pause(10000)
Draw (1000,190)
Pause(10000)
End
Sub Draw(Count,Angle)
 Turtle Reset
 N = 5
 A = 90
 For I = 1 To Count
   Turtle Forward N
   A = A + Angle
   Turtle Heading A mod 360
   Turtle Pen Colour Map(I mod 255)
   N = N + 0.5
 Next I
End Sub
-Carl
Sasquatch
Posted: 09:26pm 02 Aug 2020
This one uses recursion instead of looping.
' Hilbert Curve using recursion
Mode 1,8
C = 1
Turtle Reset
Turtle Pen Up
Turtle Move 20,600
Turtle Pen Down
'Hilbert(Level,Angle,Length)
Hilbert(7,90,6)
Pause 10000
Turtle Reset
Turtle Pen Up
Turtle Move 150,550
Turtle Pen Down
Hilbert(8,90,2)
'Pause 10000
End
Sub Hilbert(Level,Angle,Length)
 If Level = 0 Then Exit Sub
 C = C + 0.1
 Turtle Pen Colour Map(C Mod 255)
 TurnTurtle(Angle)
 Hilbert(Level - 1,0 - Angle, Length)
 Turtle Forward Length
 TurnTurtle(0 - Angle)
 Hilbert(Level - 1,Angle,Length)
 Hilbert(Level - 1,0 - Angle,Length)
 TurnTurtle(Angle)
End Sub
Sub TurnTurtle(Angle)
 If Angle > 0 Then
   Turtle Turn Right Angle
 Else If Angle < 0 Then
   Turtle Turn Left Abs(Angle)
 End If
End Sub
-Carl
Sasquatch
Posted: 03:30am 03 Aug 2020
Recursive Fractal Trees!
' Recursive Fractal Trees
Mode 1,8
Turtle Reset
Turtle Pen Up
Turtle Move 400,600
Turtle Pen Down
Tree(120)
End
Sub Tree(Length)
 If Length < 1 Then Exit Sub
 If Length > 20 Then
   Turtle Pen Colour RGB(139,69,19)
 Else
   Turtle Pen Colour RGB(34,139,34)
 EndIf
 Turtle Pen Down
 Turtle Turn Right 20
 Tree(Length - 15)
 Turtle Turn Left 40
 Tree(Length - 15)
 Turtle Pen UP
 Turtle Backward Length
End Sub
-Carl
Sasquatch
Posted: 03:32am 03 Aug 2020
These Trees include a small amount of randomization making the trees look less uniform and more natural.
' Random Recursive Fractal Trees
Mode 1,8
Turtle Reset
Turtle Pen Up
Turtle Move 400,600
Turtle Pen Down
For X = 1 to 5
 Tree(100)
 Pause(1000)
Next X
End
Sub Tree(Length)
 Local RndLength = Length + Rnd * 5
 Local RndAngle = 15 + Int(Rnd * 20.0)
 If RndLength > 20 Then
 Else
 EndIf
 Turtle Pen Down
 Turtle Forward RndLength
 Turtle Turn Right RndAngle
 Tree(RndLength - 15)
 Turtle Turn Left RndAngle * 2
 Turtle Pen UP
 Turtle Backward RndLength
End Sub
-Carl
Sasquatch
Posted: 03:47pm 03 Aug 2020
Sierpinski's Triangle Recursive Fractal.  If you un-comment the pause statement, you will see that the entire thing is drawn as a series of tiny triangles.
' Sierpinski's Triangle Recursive Fractal
Mode 1,8
Colour 0,RGB(255,255,255)
Turtle Reset
Turtle Pen Up
Turtle Move 70,575
Turtle Turn Right 90
Turtle Pen Down
Turtle Pen Colour 0
Sierpinski(650,7)
End
Sub Sierpinski(Length,Level)
 If Level = 0 Then
   For i = 1 to 3
     Turtle Turn Left 120
'      Pause(50)
   Next i
   Exit Sub
 EndIf
 Sierpinski(Length / 2.0, Level - 1)
 Turtle Pen Up
 Turtle Forward Length / 2.0
 Turtle Pen Down
 Turtle Pen Up
 Turtle Turn Right 120
 Turtle Pen Down
 Turtle Pen Up
 Turtle Turn Left 60
 Turtle Backward Length / 2.0
 Turtle Turn Right 60
 Turtle Pen Down
End Sub
-Carl
Posted: 05:35pm 03 Aug 2020
Sasquatch
Posted: 05:50pm 03 Aug 2020
The Nautilus
' Square Nautilus Turtle Graphics Demo
Mode 1,8
Size = 275
N = 100
Angle = 10
Ratio = 0.97
Turtle Reset
For i = 1 to N
 'Draw a square
 For j = 1 to 4
   Turtle Forward Size
   Turtle Turn Left 90
 Next j
 'Rinse and Repeat
 Turtle Turn Left Angle
 Size = Size * Ratio
Next i
End
-Carl
Sasquatch
Posted: 07:03pm 03 Aug 2020
Here is a recursive fractal pine tree:
' Recursive Fractal Pine Trees
Mode 1,8
Turtle Reset
Turtle Pen Up
Turtle Move 400,500
Turtle Pen Down
PineTree(100,20)
End
Sub PineTree(Length,Depth)
'  Print Length
 If Depth <= 0 Then Exit Sub
 If Length > 2 Then
   Turtle Pen Colour RGB(139,69,19)  'Make the sticks brown
 Else
   Turtle Pen Colour RGB(0,100,0)  'Make the needles Green
 EndIf
 PineTree(Length * 0.8, Depth - 1)
 PineTree(Length * 0.5, Depth - 3)
 Turtle Pen Up
 Turtle Pen Down
End Sub
The second version includes a little randomization to make it less uniform
' Random Recursive Fractal Pine Trees
Mode 1,8
Turtle Reset
Turtle Pen Up
Turtle Move 400,500
Turtle Pen Down
PineTree(100,19)
End
 Local Angle = 110 + 20 * Rnd()
 If Length > 5 Then
 Else
 EndIf
 Turtle Turn Right 240 - Angle
 Turtle Pen Up
 Turtle Pen Down
End Sub
-Carl
Posted: 10:39pm 03 Aug 2020
Thank you for all the turtle demos.
It brings back memories of my brother demonstrating turtle drawing 50 years ago.
It was a new thing back then.
My brother went on to be a much better programmer than I will ever be.
Sasquatch
Posted: 11:29pm 03 Aug 2020
Ok, this one is basically blowing my poor little mind.
While it doesn't use Turtle Graphics it is a very interesting fractal known as the Barnsley Fern.  I may "need" to do this one as a CSUB to see how fast it will fill.  It would be interesting to zoom in if it would fill in faster.
'Barnsley's Fern
Mode 1,8
CLS
G = RGB(0,100,0)
For i = 1 to 1000000
 Select Case Rnd()
   Case IS < .01
     NextX = 0
     NextY = 0.16 * Y
   Case .01 TO .08
     NextX = .2 * X - .26 * Y
     NextY = .23 * X + .22 * Y + 1.6
   Case .08 TO .15
     NextX = -.15 * X + .28 * Y
     NextY = .26 * X + .24 * Y + .44
   Case Else
     NextX = .85 * X + .04 * Y
     NextY = -.04 * X + .85 * Y + 1.6
 End Select
 X = NextX
 Y = NextY
 Pixel X * 100 + 400,600 - Y * 55 ,G
Next i
-Carl
vegipete
Posted: 11:51pm 03 Aug 2020
Turtle meets Dragon
This is perhaps my favorite fractal line drawing. Especially neat is the way they fit together. In this code, the red and green dragons are identical, just rotated 180 degrees. And they fit together perfectly.
It does look though that rounding errors are creeping into play here. The start point is fixed but the end point should also always end up the same. But if you watch closely between different orders, particularly the higher ones, the end point moves quite a lot. As a result, the green and red dragons must be the same order or they won't line up at all.
Orders higher than 19 don't work because the draw distance becomes less than 1 so nothing beyond a single dot gets drawn.
cls
turtle reset
text 100,500,"Dragon Curve - a Fractal","CT"
do
 print @(0,520) "Order: (1-19)"
 input "0 to quit: "; dord
loop until dord >= 0 and dord < 20
do
 if dord = 0 then end
 dord = dord - 1
 dist = MM.HRES/2/(sqr(2)^dord)
 cls
 turtle reset
 text 80, 0,"Dragon Curve","CT",2
 text 80,20,"Order:" + str$(dord+1), "CT",2
 turtle pen up   ' no line yet
 turtle move MM.HRES * .25, MM.VRES * .55
 turtle pen down
 turtle heading 90 - (dord MOD 8) * 45
 turtle pen colour rgb(red)
 DrawDragon(dord,1)
 turtle heading 270 - (dord MOD 8) * 45
 turtle pen colour rgb(green)
 DrawDragon(dord,1)
 do
loop
sub DrawDragon(ord, sig)
 if ord = 0 then
   turtle forward dist
 else
   DrawDragon(ord-1,  1)
   turtle turn right 90 * sig
   DrawDragon(ord-1, -1)
 endif
end sub
Sasquatch
Posted: 12:12am 04 Aug 2020
  vegipete said  Turtle meets Dragon
That is a nice one!  At lower orders it doesn't give any clue as to it's potential.  It amazes me how such a simple looking algorithm can generate something so complex.
Thanks for sharing, if you have any other gems I'd like to see them.
-Carl
capsikin
Posted: 12:46am 04 Aug 2020
Cool thread, there's some other recursive line fractals I'd like to try if I get time (I think I was inspired by one called the koch curve and I changed things around and got a new one with a kind of hexagonal pattern)
capsikin
Posted: 01:32am 04 Aug 2020
Cool thread, there's some other recursive line fractals I'd like to try if I get time (I think I was inspired by one called the koch curve and I changed things around and got a new one with a kind of hexagonal pattern).
Update:
I gave it a quick try by modifying the Sierpinski program above. The rounding errors were already spoiling it before I got as much detail as I wanted. Here's the code I used:
' Hex Gasket Recursive Fractal
Mode 1,8
Turtle Reset
Turtle Pen Up
Turtle Move 70,575
Turtle Pen Down
Turtle Pen Colour 0
'Gasket(650,7)
Gasket(650,5)
End
Sub Gasket(Length,Level)
If Level = 0 Then
'   Pause(50)
  Exit Sub
EndIf
Turtle Pen Up
Turtle Pen Down
Gasket(Length / 2.0, Level - 1)
Turtle Turn Left 60
Turtle Turn Left 60
Turtle Pen Up
Turtle Pen Down
End Sub
I changed the program to exactly retrace the same lines when going backwards, rather than taking a shortcut. It's more complicated, but it cancels out the rounding errors:
Mode 1,8
Turtle Reset
Turtle Pen Up
Turtle Move 70,575
Turtle Pen Down
Turtle Pen Colour 0
'Gasket(650,7)
Gasket(650,10)
End
If Level = 0 Then
  Turtle Pen Up
  Turtle Pen Down
'   Pause(50)
  Exit Sub
EndIf
Turtle Turn Left 60
Turtle Pen Up
Turtle Forward Length/2
Turtle Pen Down
Turtle Turn Right 180
Turtle Turn Left 180
Turtle Pen Up
Turtle Pen Down
Turtle Pen Up
Turtle Pen Down
Turtle Pen Up
Turtle Turn Left 60
Turtle Turn Left 60
Turtle Pen Down
End Sub
Sasquatch
Posted: 03:53am 04 Aug 2020
  capsikin said  Cool thread, there's some other recursive line fractals I'd like to try if I get time (I think I was inspired by one called the koch curve and I changed things around and got a new one with a kind of hexagonal pattern)
Good Job!  MMBasic does make it easy to try changes quickly.  I've added this one to my collection as well.
-Carl
Posted: 08:21am 04 Aug 2020
Just in case anyone doesn't know, each dragon is the same as folding a piece of paper in half repeatedly (you can't do it much as it gets too thick) then opening it out so every crease is a right angle and viewing from an edge side.
Origami...
Atomizer_Zero
Posted: 04:38pm 04 Aug 2020
Wow, these are awesome. I love seeing these patterns drawing and stuff. Before I got my CMM2, I played around in QBASIC 1 in DOS, and made this
https://www.youtube.com/watch?v=zJe2Ajp2eVg
Keep em coming!
Posted: 06:57am 05 Aug 2020
Hi Pete,
That code fails for anything after Option 3.. I think it is to do with negative angles.
Maybe something changed in a later version of MMBasic, I am using 5.05.04
There is also an error in the Barnsley Fern by sasqatch.
Kind Regards
Posted: 07:11am 05 Aug 2020
Yep. All fixed in the latest beta.
Posted: 10:02am 05 Aug 2020
Thanks Jim,
I thought it was firmware differences, I will try the latest beta..
I usually stick to the latest release version
Mik
