Local Time 12:46 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help with Terminal Programm (MMEdit)
TweakerRay
Posted: 10:04am 21 Oct 2020
Hi ! If someone has a little time to help ?
Thanks in advance for your help. I know sometimes is might be hard to tell newbies the secrets but I want to learn and maybe get better in this ;-)
I have tried to connect the CMM2 to my pc and tried the MMEdit but I can't connect it to the computer somehow.
Can someone help me with the process how the setup will be correctly ?
As a beginner of this it's not easy to understand and I lack some knowledge how things work.
So lets start as if I just have bought this cool machine ;-)
I have a a-a usb calble and the cmm2 and the nice mmedit programm.
What should I do to use this correctly and can access my cmm2 from my pc with mmedit?
Cheers TweakerRay
http://tweakerray.bandcamp.com
Posted: 10:20am 21 Oct 2020
You need an A-B cable. The A connects to the PC, the B goes into the CMM2 instead of the power, the CMM2 will then get its power from, and can communicate with the PC.
Womble
Posted: 10:27am 21 Oct 2020
@TweakerRay
CMM2 Manual v5.05.05 p15
The default settings for the serial over USB console are 115200 baud, 8 bits, no parity and one stop bit.
Personally I use TerraTerm, but the principle is the same for MMEdit.
You connect the CMM2 to your PC using the USB-A to USB-B cable (the one that normally powers the CMM2).
You do not need to connect anything to the USB-A keyboard port on the CMM2.
I have highlighted the settings you need to use to connect.  This is the Portable version 4.01 from here which does not need installing, just unzip and run MMEdit.exe
Hope that helps.
Womble
Posted: 10:33am 21 Oct 2020
@Tom
LoL you were much faster typing that than I was
TweakerRay
Posted: 06:23pm 21 Oct 2020
Thank you very much I will try that out. Much appreciated. I thought I would use my a-a cable... see it's the little things ;-) Thanks again !
So I use an extensioncable on my a-b cable is that okay ? Or does that not work ?
When I try to access the MM File Master it says "Unable to get a response from the device"
Edited 2020-10-22 04:28 by TweakerRay
Posted: 06:28pm 21 Oct 2020
  Womble said  @Tom
You just had to be flashy and include pictures
Posted: 06:50pm 21 Oct 2020
It's OK to use an extension cable as well as the A-B one if that makes it reach better.
Er, don't know about that error, sorry.
TweakerRay
Posted: 06:56pm 21 Oct 2020
okay I got connected... but when I try to use the filebrowser the thing will hang...
maybe my SD card is too big ? Or too many files ?
I manage to type in "files" and I could see that the maximite will do that command...
so that works... very strange...
Posted: 07:02pm 21 Oct 2020
  TweakerRay said  okay I got connected... but when I try to use the filebrowser the thing will hang...
I doubt it's either of those two things. Assuming that we're talking about MMEdit then I'm sure Jim will be along in the next few hours and set you straight if nobody else beats him to it.
Posted: 07:06pm 21 Oct 2020
  Quote  maybe my SD card is too big ? Or too many files ?
My SD has 23 directories and 409 files and works fine. Have you set the CMM2 syntax in the dropdown. Top line furthest right
TweakerRay
Posted: 07:08pm 21 Oct 2020
yep CMM2 is set. I can change file directory if I write Files in the command line...
But somehow if I open the fileswindow it crashes...
TweakerRay
Posted: 07:25pm 21 Oct 2020
So I give up for today... This thing crashes all time I try to use the filebrowser... so I guess I stay on the normal editor on the CMM2 and programm there...
Posted: 07:37pm 21 Oct 2020
Maybe the extra current the SD card uses causes the USB voltage to drop. Check the usb cable.
Volhout.
Posted: 08:52pm 21 Oct 2020
It should work with the setting you have.
Does it crash as soon as you open the file manager window or does it send something to the CMM2 before crashing?
You should see the 'files' command list on the CMM2 monitor then appear in the MMEdit file manager after a short delay.
IF it is crashing as soon as you try to open the filemanager window, I would try:
Close down MMEdit
delete locate.inf, macro.inf and mmedit.inf from the data folder.
You can finds the location of the data folder from help/about
My data folder is at "C:\Users\Jim\AppData\Local\CCom\MMedit\*.inf"
Restart MMEdit and it will recreate the inf files with default values.
I would prefer you to make a copy of the files before you delete them so if that fixes it, I can see what is wrong with the files.
TweakerRay
Posted: 01:09pm 22 Oct 2020
It crashes when I click the filebrowser... then I only got a round coursor symbol (of windows that it's doing something) and it needs a looooooooong time...
I suspect maybe because I have so much files on the card that this might confuse the programm ? I clear my card (after a backup of course) and try again today later...
I also will try the erasing what you said (also before that i do a backup)
I will report ;-) Thanks for your help !
TweakerRay
Posted: 08:24pm 22 Oct 2020
hmmm ... so I tried a different SD Card today ;-) a small one 256 mb only...
I could use the filebrowser but when I tried to upload a programm to the cmm2
it crashed again... the card was empty...
I made a test.bas and it stored a temp.bas on the card but the filebrowser on the pc then crashed again...
I deleted (actually just put them in another folder outside that directory) you said:
locate.inf, macro.inf  >>> where moved out of that folder
Now I could use the filebrowser, upload a short test.bas and it saved correctly.
I tried the small icon "Load and run current code" but it gave me an
error after it said
Load"temp.bas"
syntex...
Hmmm... what do I do wrong ?
I checked the files on the MM2
The temp.bas and Test.bas i transfered before where there but they had a
long ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ Line at the end...
My programm only was
10 Print"Hello World"
20 goto 10
and it added below that in inverse writing
ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
so maybe the CMM2 was sleepy or my code was too boring ;-)
Edited 2020-10-23 06:29 by TweakerRay
Posted: 08:54pm 22 Oct 2020
XMODEM always pads the last packet out to 128 bytes using either chr$(0) or chr$(26)
That's the way it's always been and there is no easy way to remove the trailing characters.
Try opening the chat window and using the "LOAD" button.
That method uses AUTOSAVE instead of XMODEM  and doesn't add the padding characters.
It will still save your code as temp.bas but in the next release of MMEdit, you will have the option of saving under the current file name instead of temp.bas
TweakerRay
Posted: 12:18pm 23 Oct 2020
So can I start a programm on the CMM2 from the terminal of the pc ?
When I tried the small icon "Load and run current code" but it gave me an
error after it said
Load"temp.bas"
syntex...
Just a few beginner questions you surely can answer:
1. So is it better to edit with MMEdit ?
  then transfer programm and manually run it there ?
2. Whats the advantage to programm on MMEdit
  compared to programm on the CMM2 directly ?
Greets TweakerRay
Tinine
Posted: 12:32pm 23 Oct 2020
I use a combination of MMEdit and Notepad++
I prefer to edit in n++ because it has a lot of powerful features.
My programs are only a few hundred lines and even at 230K BAUD, loading takes longer than I would like.
This may or may not be an issue for the guys who write thousands of lines. I guess the SD card is the way to go for the CMM2.
Posted: 09:02pm 23 Oct 2020
Greets TweakerRay
The editor on the CMM2 is very powerful but you don't have the ability to have multiple files open at the same time.
When editing on the PC, I will often have Notepad++ open as well as MMEdit and copy and paste between the two. It might be a PDF reference or the Internet that I copy from.
I can use the tools that I need to make typing easier for me on the PC and those tools are not available on the maximites.
MMEdit has syntax help (which is much improved in the next release).
So, I find the PC easier for me to use but the time taken to transfer files after editing is significant.
Editing on the maximite saves the transfer time.
There is no best method.
To each his own...
