Local Time 03:49 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM2: Problems with MPRLS0015PA0000SA SPI pressure sensor
Frank N. Furter
Posted: 11:30am 01 Dec 2020
Hi to all,
i am desperately trying to read out a MPRLS0015PA0000SA pressure sensor here with a Micromite.
MPRLS0015PA0000SA_Datasheet.pdf
Somehow this does not work as expected. :-(
Can anyone help me with this?
According to the data sheet the following must be sent:
This is my testcode:
Option EXPLICIT
Option BASE 1 ' our array will start with the index 1
Option Default Integer
Dim data%(4) ' define the array for receiving the data
Dim Value
Dim Float PSI
Dim Float hPA
Pause 50
'SPI OPEN speed (kHz), mode, bits
SPI OPEN 100000, 0, 8
Const  EOC = 4      'End-of-conversion
Const  MPRL_sel = 2 'MPRLS0015PA0000SA Chip Select
SetPin EOC, din
SetPin MPRL_sel, dout
 Pin(MPRL_sel)=0 'activate chip (Chip Select Low)
 Pause 5
 SPI write 1, &HAA
 SPI write 1, 0
 SPI write 1, 0
 Pause 30
 SPI write 1,&HF0
 SPI READ 1, data%(1)
 SPI write 1,&H00
 SPI READ 1, data%(2)
 SPI write 1,&H00
 SPI READ 1, data%(3)
 SPI write 1,&H00
 SPI READ 1, data%(4)
'  data%(1)=SPI(&HF0)
'  data%(2)=SPI(0)
'  data%(3)=SPI(0)
'  data%(4)=SPI(0)
 Value=data%(1)+(data%(4)<<8)+(data%(3)<<16)
 PSI=(Value-&H19999A)*15
 PSI=PSI/(&HE66666-&H19999A)
 hPA=PSI*68.947572932
 Print data%(1)," ",data%(2)," ",data%(3)," ",data%(4)
 Print "Value: ",Value
 Print "PSI: ",PSI
 Print "hPA: ",hPA
 Pause 500
 Pin(MPRL_sel)=1 'Chip deaktivieren (Chip Select Low)
 Pause 5
Here is the result:
> run
0               0               64              92
Value:   4217856
PSI:     2.83882
hPA:     195.73
128             0               64              88
Value:   4216960
PSI:     2.83782
hPA:     195.661
128             0               64              89
Value:   4217216
PSI:     2.83811
hPA:     195.68
128             0               64              83
Value:   4215680
PSI:     2.83639
hPA:     195.562
128             0               64              84
Value:   4215936
PSI:     2.83668
hPA:     195.582
128             0               64              90
Value:   4217472
PSI:     2.83839
hPA:     195.7
It seems that data%(2) is the status byte?!? (The status byte should be the first byte?)
data%(4) seems to be the lowest byte but what is the highest?
When I use
 data%(1)=SPI(&HF0)
 data%(2)=SPI(0)
 data%(3)=SPI(0)
 data%(4)=SPI(0)
I get always "0" for all data% - WHY???
What am I doing wrong?
The air pressure should be around 1000 hPa - so the calculation seems to be wrong...
Any help is apreciated!!!
Frank
Justplayin
Posted: 05:18pm 01 Dec 2020
It looks like you need to read the Status byte and 2 Data bytes after you send the command to wake up.
Pressure calculations should be done using
data%(2), data%(3) and data%(4) as  data%(1) is the status byte.
--Curtis
Edited 2020-12-02 04:48 by Justplayin
CircuitGizmos
Posted: 06:54pm 01 Dec 2020
Your choice of mode 0 looks to be the right choice, but I've found that a few datasheets list this incorrectly. Might be worth the time experimenting with the other modes just to be sure.
Does the SPI routine not work correctly with BASE 1? Try BASE 0 (and adjust your offset/index accordingly) as a test.
Frank N. Furter
Posted: 07:18pm 01 Dec 2020
  Justplayin said  Pressure calculations should be done using
--Curtis
I would have understood it that way - but the numerical values speak against it.
  CircuitGizmos said  Your choice of mode 0 looks to be the right choice, but I've found that a few datasheets list this incorrectly. Might be worth the time experimenting with the other modes just to be sure.
I tried all other modes - only mode 0 worked...
I will try another BASE.
According to the manual this should be the same
data%(1)=SPI(&HF0)
data%(2)=SPI(0)
data%(3)=SPI(0)
data%(4)=SPI(0)
as this
SPI write 1,&HF0
SPI write 1,&H00
SPI write 1,&H00
SPI write 1,&H00
SPI READ 1, data%(4
Why do I only get "0" with the first expression??? :-(
Frank
Justplayin
Posted: 07:47pm 01 Dec 2020
Did you try something like this?
SPI write 1,&HAA
SPI READ 1, status%
SPI write 1,&H00
SPI READ 1, dontcare%
SPI write 1,&H00
Pause 30
SPI write 1,&HF0
SPI write 1,&H00
SPI write 1,&H00
SPI write 1,&H00
I could be wrong, but I think you need to write a byte then read a byte for this device.
--Curtis
Frank N. Furter
Posted: 09:04am 02 Dec 2020
Hmmmm,
I tried your code
  Justplayin said  SPI write 1,&HAA
SPI READ 1, status%
SPI write 1,&H00
SPI write 1,&H00
Pause 30
SPI write 1,&HF0
SPI write 1,&H00
SPI write 1,&H00
SPI write 1,&H00
...but I get always:
[54] SPI READ 1, status%
Error : Invalid variable
Why??? I tried it with and without OPTION EXPICIT and with "Dim status%" and "Dim dontcare%" (...it also doesn't work with other variable names...)
Frank
Posted: 10:21am 02 Dec 2020
Frank
Use the SPI function rather than the READ and WRITE. I think you will then find it works
Frank N. Furter
Posted: 11:07am 02 Dec 2020
Hi Matherp,
thank you very much for your response! Which SPI function did you mean? Did you mean the C-SPI function? Where can I find it?
I had addressed SPI devices before (especially with the Maximite) and never had such problems...
Frank
Posted: 11:34am 02 Dec 2020
use:
inbyte=SPI(outbyte)
Remember SPI isn't like I2C. Every byte sent in SPI also receives a byte
When you use SPI READ you are also sending a byte (probably 0) to cause the read
When you do SPI WRITE you are also reading a byte and discarding it
The SPI function returns the byte that was received at the same time as the byte in the brackets was sent
Frank N. Furter
Posted: 01:13pm 02 Dec 2020
Dear Peter,
thanks for your suggestion - I know and I tried this first. Please take a look on my code above. I tried:
data%(1)=SPI(&HF0)
data%(2)=SPI(0)
data%(3)=SPI(0)
data%(4)=SPI(0)
...but I have always read only "0" with this construction. :-(
Frank
Posted: 01:26pm 02 Dec 2020
Some devices need SPI(&HFF) - worth trying
Frank N. Furter
Posted: 02:32pm 02 Dec 2020
Peter,
instead of what?
The sensor would like to see: &HAA,&H00,&H00 (Wait) &HF0,&H00,&H00,&H00
Now I tried &HFF instead of &H00, &HFF instead of &HF0, &HFF instead of &HAA - it's always the same: All read back values are "0". :-(
I get only other values with "SPI write 1" and "SPI READ 1" :-(
Frank
Posted: 02:36pm 02 Dec 2020
Frank
I assume you have tried the other SPI modes?
Assuming none of this works my next step would be to bitbang the I/F in Basic so you can see exactly what is happening
Frank N. Furter
Posted: 10:04am 03 Dec 2020
Hi Peter,
I have just tried all modes again:
I get always "0" with
data%(1)=SPI(&HF0)
data%(2)=SPI(0)
data%(3)=SPI(0)
data%(4)=SPI(0)
0               0               0               0
Value:   0
PSI:    -1.875
hPA:    -129.277
0               0               0               0
Value:   0
PSI:    -1.875
hPA:    -129.277
0               0               0               0
Value:   0
PSI:    -1.875
hPA:    -129.277
I only get values when I use READ and WRITE with mode 0:
128             0               64              255
Value:   4259712
PSI:     2.8856
hPA:     198.955
128             0               64              253
Value:   4259200
PSI:     2.88503
hPA:     198.916
128             0               64              254
Value:   4259456
PSI:     2.88531
hPA:     198.935
128             0               64              2
Value:   4194944
PSI:     2.81321
hPA:     193.964
128             0               64              0
Value:   4194432
PSI:     2.81264
hPA:     193.925
...is it possible that something is wrong with "inbyte=SPI(outbyte)" command??? I use MM.VER 5.0503.
Why did I get "Error : Invalid variable" with "SPI READ 1, status%" or "SPI READ 1, dontcare%" ???
Frank
Posted: 10:14am 03 Dec 2020
  Quote  ..is it possible that something is wrong with "inbyte=SPI(outbyte)" command??? I use MM.VER 5.0503.
Very unlikely. Connect spi-out to spi-in and try ? spi(123)
  Quote  Why did I get "Error : Invalid variable" with "SPI READ 1, status%" or "SPI READ 1, dontcare%" ???
From the manual:
  Quote  Data can also be received in bulk:
SPI READ nbr, array()
Where 'nbr' is the number of data items to be received and array() is a single dimension integer array where the received data items will be saved.  This command sends zeros while reading the data from the slave.
Read can only use arrays as the input data item
Other thoughts:
- why not try I2C
- I assume you are pulling SS low. Try controlling SS as you do the transactions. Some devices don't like SS just pulled continuously low
Edited 2020-12-03 20:20 by matherp
Frank N. Furter
Posted: 10:44am 03 Dec 2020
Thanks for your explanation!!!
I shorted pin 3 with pin 14 (it's a 28 pin device) and changed my code:
 Data %(1)=SPI(123)
 Print Data%(1)
 Pause 50
This is the result:
0
0
0
0
0
0
0
0
0
With this...
'  Data %(1)=SPI(123)
 SPI write 1, (123)
 Print Data%(1)
 Pause 50
...I get this:
0
0
64
26
0
0
64
26
0
0
64
26
0
Frank
Posted: 11:29am 03 Dec 2020
Frank
We need to go back to first principles as there is something wrong.
Disconnect everything from the MM
Connect pin 3 to pin 14
At the command prompt type
SPI OPEN 1000000,3,8
? SPI(123)
If you don't get back 123 then you have a H/W problem. I've just tested on a 28-pin MM2 running a fresh install of 5.05.03 downloaded from Geoff's site and it works perfectly.
Until this works everything else is just adding to the confusion
Edited 2020-12-03 21:30 by matherp
Frank N. Furter
Posted: 12:24pm 03 Dec 2020
Peter,
SUCCESS! This works:
SPI open 1000000,3,8
 Print SPI(123)
Result:
123
123
123
123
123
123
123
123
123
123
Frank
Posted: 02:08am 04 Dec 2020
Try using integers instead of an array.
data1% = SPI(&HF0)
data2% = SPI(0)
data3% = SPI(0)
data4% = SPI(0)
Frank N. Furter
Posted: 10:32am 09 Dec 2020
Hi Jim,
thanks for your suggestion. Unfortunately that did not help either!
...I will probably have to connect my logic analyzer...
Frank
