Local Time 22:53 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Box drawing characters in TeraTerm
Posted: 08:21pm 15 Feb 2021
Hi folks,
Does anyone know if/how to configure Tera Term to display the box drawing characters specifically cp437 where they align with the box-drawing characters in the CMM2's fonts.
Thanks,
Posted: 09:40pm 15 Feb 2021
IIRC I was playing with something like that on the Micromite a while ago. I've put together a little VT100 library for it to give a bit of interaction via the console. I got rather waylaid though. As you do. :) At the time I was starting to play with the box characters (they are mapped to a logic all of their own!). Unfortunately I've never used them with a CMM2 as I haven't got one. Now, whether Tera Term was emulating a VT100 or something else I can't remember now. It might have been a VT220. I don't seem to have left any notes in my test routine.
Posted: 02:57pm 16 Feb 2021
Surely one of the grognard's (not a derogative term, not derived from "retard", see https://www.merriam-webster.com/dictionary/grognard) must know ?
I've done some more experimenting and if I send UTF-8 block-drawing codes then a sub-set of them are correctly rendered by TeraTerm (if set to use the UTF-8 Language) but that isn't really terribly convenient, unlike good old CP437.
Edited 2021-02-17 00:58 by thwill
Posted: 03:09pm 16 Feb 2021
both windows and linux versions of GFXterm use CP437 as much as is possible.
rob   :-)
Posted: 03:31pm 16 Feb 2021
  robert.rozee said  both windows and linux versions of GFXterm use CP437 as much as is possible.
rob   :-)
Hey Rob,
It took me a while to find it, Google didn't help, and then I vaguely recalled it might be something you had written yourself and posted about on TBS. I tried out this version: http://www.thebackshed.com/docregister/ViewDoc.asp?DocID=22
It does appear to accept the box-drawing codes
Does it have a 100 x 50 mode suitable for the CMM2 ?
It doesn't appear to support the (almost) standard control-code to hide the cursor: Esc[?251
To be honest I'm not sure this is the solution. I thought I was onto something with creating a library that could render a TUI on both the Serial and VGA displays, but if it won't work with TeraTerm unless I translate on the fly to UTF-8 codes then it may not be as usable/portable as I would have liked ... plus I'll probably have to switch to CSUBs to handle the translation as I was already at the limits of acceptable performance.
Thanks,
Edited 2021-02-17 01:31 by thwill
Posted: 08:48pm 16 Feb 2021
Have you tried changing TeraTerm to use code page 437?
Setting found under 'Terminal"
You will also need to use a font that has the line drawing characters defined.
Posted: 08:52pm 16 Feb 2021
  TassyJim said  Have you tried changing TeraTerm to use code page 437?
Which version of TeraTerm ? - no such setting for version 4.105
Posted: 08:59pm 16 Feb 2021
Posted: 09:05pm 16 Feb 2021
  TassyJim said
  thwill said  Which version of TeraTerm ? - no such setting for version 4.105
4.94
So an older version ... I've just installed that and still no such setting.
This is weird - can you post a screenshot of the dialog and the about box ?
Posted: 09:40pm 16 Feb 2021
I did a few tests.
CP65001 and CP437 both display the same extended ASCII characters so no help for you there.
I use Terminal font. It can be difficult to find fonts that have the line drawing characters.
I suggest that you have some odd setting in your teraterm.ini file. Delete it and start fresh.
Edited 2021-02-17 07:43 by TassyJim
Posted: 09:57pm 16 Feb 2021
Thanks Jim.
  Quote  I suggest that you have some odd setting in your teraterm.ini file. Delete it and start fresh.
That doesn't appear to be the case. To display the two "Coding" fields requires a change in Setup->General to use UTF-8 before they are displayed but I'm still to discover what setting needs flicking to show "CodePage".
I independently discovered that the key was using the "Terminal" font, but even that doesn't contain the full Cp437 set of line-drawing characters (it doesn't contain the junctions between double and single line borders).
Anyway I think I've got as good as I'm going to get from TeraTerm now, so thank you for your help.
CircuitGizmos
Posted: 10:39pm 16 Feb 2021
CMM2 Font #1 for installation in Windows:
CMM2f1.zip
Posted: 11:49pm 16 Feb 2021
For me, with Terminal font set in Teraterm, both CP65001 and CP437 have the anomaly of not printing the upper right corner, single or double, or double lower right corner if preceded by the appropriate horizontal line character.
In MMBasic DOS, the code draws the boxes properly.
Posted: 12:16am 17 Feb 2021
  lizby said  For me, with Terminal font set in Teraterm, both CP65001 and CP437 have the anomaly of not printing the upper right corner, single or double, or double lower right corner if preceded by the appropriate horizontal line character.
I believe it is happening because you have TeraTerm configured to receive UTF-8 and 0xC4BF just so happens to be a valid UTF-8 character so those two bytes are interpreted as a single character and it happens to be a character not present in the font you are using, so you get a ? When you insert the space you break the byte sequence and hence get the expected characters.
The same doesn't happen for all the horizontals because 0xC4C4 is not a valid UTF-8 character.
Or I might be adding 2 + 2 and getting 5.
Posted: 01:23am 17 Feb 2021
Hummm, maybe. My ignorance is deep here. The only choice I can see for coding other then UTF-8 is something called UTF-8m. Selecting that makes no difference.
Where does 0xC4BF come from? I thought I was sending chr$(191) or 187 or 188.
This may be too deep for me, but I hate it when things nearly work.
Posted: 06:44am 17 Feb 2021
  Quote  Where does 0xC4BF come from? I thought I was sending chr$(191) or 187 or 188.
That is the HEX equivalent to the decimal numbers.
I don't think that is the problem though.
I remember the corners causing grief many years ago but forget where and what I did about it.
You can get around it by drawing the corners first then backspacing to draw the lines.
Crude but it does work.
PRINT CHR$(218);: FOR i=1 TO 10: PRINT CHR$(196);: NEXT i: PRINT CHR$(191)
PRINT CHR$(179);: FOR i=1 TO 10: PRINT " ";: NEXT i: PRINT CHR$(179)
PRINT CHR$(192);: FOR i=1 TO 10: PRINT CHR$(196);: NEXT i: PRINT CHR$(217)
PRINT
PRINT CHR$(201);: FOR i=1 TO 10: PRINT CHR$(205);: NEXT i: PRINT CHR$(187)
PRINT CHR$(186);: FOR i=1 TO 10: PRINT " ";: NEXT i: PRINT CHR$(186)
PRINT CHR$(200);: FOR i=1 TO 10: PRINT CHR$(205);: NEXT i: PRINT CHR$(188)
PRINT CHR$(218);: FOR i=1 TO 9: PRINT CHR$(196);: NEXT i: PRINT " "+CHR$(191);CHR$(8);CHR$(8);CHR$(196)
PRINT
PRINT CHR$(201);: FOR i=1 TO 9: PRINT CHR$(205);: NEXT i: PRINT " "+CHR$(187);CHR$(8);CHR$(8);CHR$(205)
PRINT CHR$(200);: FOR i=1 TO 9: PRINT CHR$(205);: NEXT i: PRINT " "+CHR$(188);CHR$(8);CHR$(8);CHR$(205)
I see a use for a small macro.
Even simpler, print a space followed by a backspace before printing the corners.
PRINT CHR$(218);: FOR i=1 TO 10: PRINT CHR$(196);: NEXT i: PRINT " ";CHR$(8);CHR$(191)
PRINT
PRINT CHR$(201);: FOR i=1 TO 10: PRINT CHR$(205);: NEXT i: PRINT " ";CHR$(8); CHR$(187)
PRINT CHR$(200);: FOR i=1 TO 10: PRINT CHR$(205);: NEXT i: PRINT " ";CHR$(8); CHR$(188)
Edited 2021-02-17 16:50 by TassyJim
Posted: 09:47am 17 Feb 2021
  TassyJim said  I don't think that is the problem though.
In TeraTerm:
1. Go to [Setup->General...]
2. Change "Language" from "UTF-8" to "English"
3. Re run program
4. Question marks go away and boxes are displayed correctly
5. Think, "Huh, I guess Tom's theory may have been correct, what are the chances of that happening?"
Or it may just be coincidence
Have a nice day.
Edited 2021-02-17 20:02 by thwill
Posted: 10:05am 17 Feb 2021
  CircuitGizmos said  CMM2 Font #1 for installation in Windows:
CMM2f1.zip
Many thanks, that does nicely.
Posted: 12:29pm 17 Feb 2021
I understand that 191=0xBF, but where does the C4 come from?
Thanks, Jim, for the workaround.
  thwill said  In TeraTerm:
Who knew that UTF-8 was a language? Thanks.
(BTW, UTF-8 -> English worked.)
Edited 2021-02-17 22:49 by lizby
Posted: 01:57pm 17 Feb 2021
C4 is 196 which you are expecting to be the single horizontal line box-drawing character.
What follows is educated conjecture there may be another explanation for the facts:
Since your terminal was set to handle UTF-8 the two bytes:
       Chr$(196) + Chr$(191)
are interpreted as the single UTF-8 character U+013F (Latin capital letter L with middle dot), don't ask me how the conversion works
Because two bytes are converted to one character the resulting line is short by one character, and because the font you are using doesn't contain that character it is rendered as "?"
When you change the "Language" to something other than UTF-8 I would conject that TeraTerm interprets individual byte values as the first 256 characters of language specific fonts ... though it may be more involved than that.
Edited 2021-02-17 23:59 by thwill
