Local Time 00:47 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : dim var as byte
     Page 1 of 16
stanleyella
Posted: 04:53pm 02 Aug 2022
stanleyella
Posted: 05:01pm 02 Aug 2022
Dim var as byte gets accepted in mmedit. Does it work or are the minimal var values words?
What is the best way of adding minus values or even declaring them. I don't want floating point so dim all vars.
dx=-2:dy=-4
spx=spx+dx:spy=spy+dy
Posted: 05:51pm 02 Aug 2022
Hi there,
MMBasic doesn't have a BYTE type, so don't know what is going on there. The supported types are INTEGER, FLOAT and STRING.
On recent 'mite platforms INTEGER and FLOAT are both 64-bit not sure about historical platforms, I think the CMM1 had 32-bit FLOATs and no INTEGERs.
INC spx, dx
INC spy, -dy
is faster than:
spx = spx + dx
spy = spy - dy
Regarding declaration I suggest beginning every program with the "holy trinity":
OPTION BASE 0        ' 0 based arrays
OPTION DEFAULT NONE  ' Don't assume a type for variables
OPTION EXPLICIT      ' Force variables to be declared in advance with
                     ' DIM, LOCAL, CONST or STATIC
Posted: 06:02pm 02 Aug 2022
"dim var as byte" gives the error "variable type" on both picomite and MMBasic for Windows.
"dim byte var" doesn't give an error on either, but on MMBasic for Window, both byte and var are variables. On PicoMite, "var=1" gives "Error: Unknown Command".
With "dim byte,var" on the Picomite, "var=1" works.
I'm not sure why "DIM byte var" (with no comma) doesn't give a syntax error on both.
Edited 2022-08-03 04:08 by lizby
stanleyella
Posted: 06:27pm 02 Aug 2022
Thanks. MMbasic is new. I'm converting a great cow basic program to mmbasic on rpi pico. Lots of differences. Would read data+256 work?
I'm using arrays cos I haven't figured data and read but is this how to set up an array with values.. colours..word values.
For minus numbers do I use integers or is -1=65535?
I have not run/tested as I'm using mmedit v4.xxx and not a clue how to make it run with pico connected. Using teraterm but not happy using a terminal, It's all strange.
option explicit
OPTION DEFAULT NONE
dim sprite_x(8),sprite_y(8),sprite_lastx(8),sprite_lasty(8),sprite_dirx(8),sprite_diry(8) as word
'dir right_button in
'dir fire_button in
dim hiscore,hits as word
hiscore=0
'white, black,blue, green, cyan, red, magenta, yellow, brown, white, orange, pink, gold, salmon, beige, lightgrey and grey (orUSA spelling gray/lightgray).
CONST BLACK=bk
const white=wh
const blue=bl
const green=gr
const cyan=cy
const red=re
const magenta=ma
const yellow=ye
const brown=br
Start:
Randomize
dim sprite1(256) as word
dim sprite2(256) as word
dim cannon(120) as word
dim missile (16) as word
sprite1=(wh,bl,bl,bl,bl,bk,bk,bk,bk,bk,bk,bl,bl,bl,bl,wh
bk,bl,re,re,re,bl,bl,bk,bk,bl,bl,re,re,re,bl,bk
bk,bk,bl,re,re,re,bl,bk,bk,bl,re,re,re,bl,bk,bk
bk,bk,bk,bl,re,wh,bl,bk,bk,bl,wh,re,bl,bk,bk,bk
bk,bk,bk,bk,bl,wh,bl,bk,bk,bl,wh,bl,bk,bk,bk,bk
bk,bk,bk,bk,bk,bl,bl,bk,bk,bl,bl,bk,bk,bk,bk,bk
bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk
bk,bk,bk,bk,ye,ye,ye,bk,bk,ye,ye,ye,bk,bk,bk,bk
bk,bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk,bk
bk,ye,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,ye,bk
bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk
ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bl,ye
ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye
bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk)
sprite2=(bl,bl,bl,bl,bl,bk,bk,bk,bk,bk,bk,bl,bl,bl,bl,bl
bk,bk,bl,wh,wh,re,bl,bk,bk,bl,re,wh,wh,bl,bk,bk
bk,bk,bk,bk,bk,bk,bk,ye,ye,bk,bk,bk,bk,bk,bk,bk
bk,bk,bk,bk,bk,ye,ye,bk,bk,ye,ye,bk,bk,bk,bk,bk
bk,bk,bk,bk,ye,ye,bk,bk,bk,bk,ye,ye,bk,bk,bk,bk
bk,bk,bk,bk,ye,bk,bk,bk,bk,bk,bk,ye,bk,bk,bk,bk
bk,bk,bk,ye,ye,bk,bk,bk,bk,bk,bk,ye,ye,bk,bk,bk
bk,bk,bk,bk,bk,ye,bk,bk,bk,bk,ye,bk,bk,bk,bk,bk
bk,bk,bk,bk,bk,bk,ye,bk,bk,ye,bk,bk,bk,bk,bk,bk)
cannon=(bk,bk,bk,bk,bk,wh,wh,bk,bk,bk,bk,bk
bk,bk,bk,bk,ye,cy,cy,ye,bk,bk,bk,bk
bk,bk,bk,ye,cy,wh,wh,cy,ye,bk,bk,bk
bk,bk,bk,ye,cy,cy,cy,cy,ye,bk,bk,bk
bk,bk,ye,ye,cy,wh,wh,cy,ye,ye,bk,bk
bk,bk,ye,cy,cy,cy,cy,cy,cy,ye,bk,bk
bk,ye,bl,bl,bl,re,re,bl,bl,bl,ye,bk
ye,ye,bl,bl,bl,re,re,bl,bl,bl,ye,ye
bk,bk,ye,re,re,re,re,re,re,ye,bk,bk
bk,bk,bk,ye,fu,fu,fu,fu,ye,bk,bk,bk)
missile=(wh,wh
re,re
ye,ye
wh,wh
wh,wh
ye,ye
re,re
wh,wh)
do
loop
sub sprite1
 ptr=0
 for spht=0 to 15
   for spw=0 to 15
     pset=sprite1(ptr)
     pixel spx(temp)+spw,spy(temp)+spht,pset
     ptr=ptr+1
   next spw
 next spht
end sub
sub sprite2
 ptr=0
 for spht=0 to 15
   for spw=0 to 15
     pset=sprite2(ptr)
     ptr=ptr+1
   next spw
 next spht
end sub
sub erase_sprite 'fills window background colour
 for spht=0 to 15
   for spw=0 to 15
   (oldspx(temp),oldspy(temp)
     pixel oldspx(temp)+spw,oldspy(temp)+spht,black
     ptr=ptr+1
   next spw
 next spht
end sub
end sub
Posted: 06:30pm 02 Aug 2022
You can't split MMbasic commands across lines
You need to use DATA and READ, they really are very easy.
stanleyella
Posted: 06:54pm 02 Aug 2022
@matherp If I use data then could read data+256 work? I am converting basic that used tables.
would this be ok for setting an array?... editing missed the commas
cannon=(bk,bk,bk,bk,bk,wh,wh,bk,bk,bk,bk,bk,
bk,bk,bk,bk,ye,cy,cy,ye,bk,bk,bk,bk,
bk,bk,bk,ye,cy,wh,wh,cy,ye,bk,bk,bk,
bk,bk,bk,ye,cy,cy,cy,cy,ye,bk,bk,bk,
bk,bk,ye,ye,cy,wh,wh,cy,ye,ye,bk,bk,
bk,bk,ye,cy,cy,cy,cy,cy,cy,ye,bk,bk,
bk,ye,bl,bl,bl,re,re,bl,bl,bl,ye,bk,
ye,ye,bl,bl,bl,re,re,bl,bl,bl,ye,ye,
bk,bk,ye,re,re,re,re,re,re,ye,bk,bk,
I can set up data for images but how to select 256 elements ie words if they're colours is not clear.
Posted: 07:31pm 02 Aug 2022
If you are using DATA and READ then you need to read the data using a loop. You can't simply fill an array in one statement.
e.g.
DIM cannon(120)
RESTORE cannon
for i=1 to 120
READ cannon(i)
next
cannon:  'this is a label
DATA bk,bk,bk,bk,bk,wh,wh,bk,bk,bk,bk,bk
DATA bk,bk,bk,bk,ye,cy,cy,ye,bk,bk,bk,bk
DATA bk,bk,bk,ye,cy,wh,wh,cy,ye,bk,bk,bk
DATA bk,bk,bk,ye,cy,cy,cy,cy,ye,bk,bk,bk
DATA bk,bk,ye,ye,cy,wh,wh,cy,ye,ye,bk,bk
DATA bk,bk,ye,cy,cy,cy,cy,cy,cy,ye,bk,bk
DATA bk,ye,bl,bl,bl,re,re,bl,bl,bl,ye,bk
DATA ye,ye,bl,bl,bl,re,re,bl,bl,bl,ye,ye
DATA bk,bk,ye,re,re,re,re,re,re,ye,bk,bk
DATA bk,bk,bk,ye,fu,fu,fu,fu,ye,bk,bk,bk
stanleyella
Posted: 07:58pm 02 Aug 2022
how would I read various blocks of data? is there just one data statement?
sorry I'm dim.
data
wh,bl,bl,bl,bl,bk,bk,bk,bk,bk,bk,bl,bl,bl,bl,wh,
bk,bl,re,re,re,bl,bl,bk,bk,bl,bl,re,re,re,bl,bk,
bk,bk,bl,re,re,re,bl,bk,bk,bl,re,re,re,bl,bk,bk,
bk,bk,bk,bl,re,wh,bl,bk,bk,bl,wh,re,bl,bk,bk,bk,
bk,bk,bk,bk,bl,wh,bl,bk,bk,bl,wh,bl,bk,bk,bk,bk,
bk,bk,bk,bk,bk,bl,bl,bk,bk,bl,bl,bk,bk,bk,bk,bk,
bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,
bk,bk,bk,bk,ye,ye,ye,bk,bk,ye,ye,ye,bk,bk,bk,bk,
bk,bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk,bk,
bk,ye,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,ye,bk,
bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,
ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bl,ye,
ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,
bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk,
'data+256
How do I access blocks of data and use them directly to plot pixels?
Thinking data is program memory but maybe not as fast as reading array in ram.
MMbasic is so new.
Edited 2022-08-03 06:25 by stanleyella
Posted: 08:30pm 02 Aug 2022
  stanleyella said  how would I read various blocks of data? is there just one data statement?
Along the lines Mixtel90 showed.
Use a unique label for each block, do a RESTORE label, then use a loop to read in the data.
You need each separate line of data to start with the word DATA.
Edited 2022-08-03 06:30 by JohnS
No, you need to split your data into chunks of up to one screen line long. No data statement can be longer than a single screen line. However, when you are reading the statements READ jumps from the end of the line to the first item in the next DATA statement automatically.
DATA*256 isn't supported at all in MMBasic.
You can put all your data into one block then read the individual arrays (one after another) if you like. I prefer to use RESTORE <label> before each loop. That way I can read the arrays out of sequence if I want to. It also makes it easier to keep track of.
e,g,
DIM a(5), b(3), c(4)
RESTORE first
for i-1 to 5
READ a(i)
next
RESTORE third
for i=1 to 4
read c(i)
next
RESTORE second
for i=1 to 3
READ b(i)
next
first:
DATA 10,20,30,40,50
second:
DATA 100,200,300
third:
DATA 101,102,103,104
stanleyella
Posted: 08:56pm 02 Aug 2022
@Mixtel90, Thanks. Would this work please? Last time I used read-data was sinclair zx spectrum.
restore sprite1
draw sprite1 data
restore cannon
draw cannon data
sprite1:
data wh,bl,bl,bl,bl,bk,bk,bk,bk,bk,bk,bl,bl,bl,bl,wh
data bk,bl,re,re,re,bl,bl,bk,bk,bl,bl,re,re,re,bl,bk
data bk,bk,bl,re,re,re,bl,bk,bk,bl,re,re,re,bl,bk,bk
data bk,bk,bk,bl,re,wh,bl,bk,bk,bl,wh,re,bl,bk,bk,bk
data bk,bk,bk,bk,bl,wh,bl,bk,bk,bl,wh,bl,bk,bk,bk,bk
data bk,bk,bk,bk,bk,bl,bl,bk,bk,bl,bl,bk,bk,bk,bk,bk
data bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk
data bk,bk,bk,bk,ye,ye,ye,bk,bk,ye,ye,ye,bk,bk,bk,bk
data bk,bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk,bk
data bk,ye,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,ye,bk
data bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk
data ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bl,ye
data ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye
data bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk
cannon:
data bk,bk,bk,bk,bk,wh,wh,bk,bk,bk,bk,bk
data bk,bk,bk,bk,ye,cy,cy,ye,bk,bk,bk,bk
data bk,bk,bk,ye,cy,wh,wh,cy,ye,bk,bk,bk
data bk,bk,bk,ye,cy,cy,cy,cy,ye,bk,bk,bk
data bk,bk,ye,ye,cy,wh,wh,cy,ye,ye,bk,bk
data bk,bk,ye,cy,cy,cy,cy,cy,cy,ye,bk,bk
data bk,ye,bl,bl,bl,re,re,bl,bl,bl,ye,bk
data ye,ye,bl,bl,bl,re,re,bl,bl,bl,ye,ye
data bk,bk,ye,re,re,re,re,re,re,ye,bk,bk
data bk,bk,bk,ye,fu,fu,fu,fu,ye,bk,bk,bk
is reading data from program memory slower than reading from an array in ram?
Edited 2022-08-03 07:00 by stanleyella
Posted: 09:04pm 02 Aug 2022
Nope, sorry. The DATA statements are only that - lists of data. They are basically REM statements that can be read using the READ command. To use them you have to load an array with them first, hence the for-next loops.
label: is a line label called "label"
RESTORE <label> moves the read pointer to the line with the label on it.
for i=1 to n
READ a(i)
next
is a loop that READs each value in turn and puts it into the array element i.
The DATA statement is the only way that you can read from program memory (that is actually stored as part of the program). It can only be accessed by the READ command - it's not usable directly. What READ does is to read a value from the program area of memory so that it can be stored in the variables area, so once it's transferred you are accessing it as a variable, not as DATA statements.
Edited 2022-08-03 07:09 by Mixtel90
stanleyella
Posted: 09:16pm 02 Aug 2022
by the way it seems from the manual that an array can be
dim arrayvar(9) as word
arrayvar=(0,1,2,3,4,65535,65534,65533,65532,65531)
arrays start at 0 as 1st element
please correct me if I'm wrong. The manual is not clear as is gwbasic help.
Posted: 09:27pm 02 Aug 2022
You can do stuff like
DIM INTEGER a(5)=(0,1,2,3,4,5)
Note that the line length will restrict you to how many items you can stuff the array width - and you can't append multiple lines.
You can't do
DIM a(4)
a=(0,1,2,3,4)
as a and a() cause a variables collision. Only the second is an array.
OPTION BASE 1
will make arrays start at 1
OPTION BASE 0
is the default, starting at the zeroeth element.
stanleyella
Posted: 09:31pm 02 Aug 2022
@Mixtel90- Thanks again. I use Great Cow Basic which uses tables in prog mem and pics don't have much ram usually and they are usable anytime for sprite data.
I don't see reading sprite data to arrays useful if the array can be directly filled ie
In mmedit only 8 colour short cuts are recognised, no pink,brown,grey
Posted: 09:39pm 02 Aug 2022
The array can only be directly filled in the DIM statement, and only to the maximum length of a single editor line. It simply doesn't work anything like GCBASIC. You can't have tables in program memory.
stanleyella
It seems the manual is wrong
You can't do
DIM a(4)
a=(0,1,2,3,4)
from the manual
Arrays can also be initialised when they are declared by adding an equals
symbol (=) followed by a bracketed list of values at the end of the
declaration. For example:
DIM INTEGER nbr(4) = (22, 44, 55, 66, 88)
or DIM s$(3) = ("foo", "boo", "doo", "zoo")
Note that the number of initialising values must match the number of
elements in the array including the base value set by OPTION BASE. If a
multi dimensioned array is initialised then the first dimension will be
initialised first followed by the second, etc.
Also note that the initialising values must be after the LENGTH qualifier (if
used) and after the type declaration (if used)
Posted: 09:49pm 02 Aug 2022
The PicoMite has 16 colours (including black and white). You can easily set up whatever colour names you want:
CONST pink=RGB(255,150,150) 'or something like that - I've not checked
stanleyella
Posted: 09:54pm 02 Aug 2022
So would this work? It would be ok as rpi pico has lots of ram.
dim word cannon(120)=(bk,bk,bk,bk,bk,wh,wh,bk,bk,bk,bk,bk,
all help appreciated... not much on line ie examples
     Page 1 of 16
