Local Time 16:16 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Enter short text
rea23
Posted: 10:19am 27 Nov 2022
Hi
A short text, e.g. a name, is to be entered on a 2.4" display without touch screen. One possibility is shown in the listing. Maybe someone has a more elegant solution for this?
' INPUT a short text e.g. a name w/o KBD or Touch
' Use of three buttons: Left, Right and Enter
' Display 2.4", 320 x 240 ILI9341 (from MikroShop)
' works with ILI9488 driver only (Portrait mode)!
' Colors are inverted ! (255-RGB=iRGB) ?? cheap LCD
' MMBasic on Pi Pico with USB-C and on board RGB-LED!
' Test Buzzer: ok with SUB BUZZ
' 6.10.2022: Moving Cursor: two buttons < and >
' 09.11.2022: < / > button, 3rd button for Enter
' 10.11.2022: Display limit l/r ok
' Sometimes bouncing ===> 100 nF // to switches, ok
' New name: Move over margin </>, then Enter button
'OPTIONS:
'OPTION SYSTEM SPI GP18,GP19,GP16
'OPTION LCDPANEL ILI9488, P, GP15, GP14, GP13   !! false driver, but works
setpin GP23, dout                           'RGB-LED, on board
SETPIN GP3, dout                            'Buzzer
setpin GP4, intl, move_r, pullup            'Button >
setpin GP1, intl, move_l, pullup            'Button <
setpin GP2, intl, take, pullup              'Button Enter, pin4, GND: pin3
' !! inverted colors because of "false" driver for LCD!! Take RGB values
CONST black_= RGB(255,255,255)              'black inv.
CONST green_= RGB(255,127,255)              'green inv.
CONST yellow_= RGB(0,0,255)                 'yellow inv.
dim letter as string length 1                'letter for name
dim newname as string
Dim z, no, fini, t as Integer                'counter, number, flag, toggle
print mm.ver, "  RC9"
print mm.info$(lcdpanel), "  should be ILI9341, but then 240x240 only!?"
print mm.info$(flash), "    SD does not work"
print mm.info$(touch), "Touch does not work"
print
abc$ = "ABCDEFGHIJKLMNOPQRSTUVWXYZ"   'choice of letters
x = 148                               'cursor position at begin
dx = 12                               'spacing
ytxt = 60                             'y-position of text
dy = 20                               'distance cursor to text
no = 13                               'number of letter/cursor position
t = 0                                 'toggle
cls black_                            'display black, iRGB of (0,0,0)
box 0,0,320,240,1, yellow_            'FILL not possible on this display!
FONT 2, 1
text 4, ytxt, abc$,,,, green_, black_ 'ABCDE...Z
text x, ytxt+dy, "^",,2,, yellow_, black_
do
do while t = 0                      'wait on toggle/button
 pause 10
loop
letter = mid$(abc$,no,1)
 if t = 1 then
   t=0
   newname = newname + letter
   setpin GP2, off
 end if
text 4, 110, newname,,2,, yellow_, black_
pause 10
 if fini = 1 then exit do
loop
text 4, 16, "New name is: "+newname,,2,, yellow_, black_
print
print "New name:", newname
end
'>>>>>>>>>>>>>>>>>>>>>>>>> FINITO >>>>>>>>>>>>>>>>>>>>>>>
sub move_r                            'interrupt, move cursor
 t=0
 no = no + 1
 if x < (320-2*dx) then
   text x, ytxt+dy, " ",,2,, yellow_, black_
   text x+dx, ytxt+dy, "^",,2,, yellow_, black_
   x=x+dx
 else
   no = 33
   letter = ""                       'to the right, over Z
   fini = 1                          'flag
 endif
End sub
sub move_l                            'interrupt, move cursor
 t=0
 no = no - 1
 if x > 12 then
   text x-dx, ytxt+dy, "^",,2,, yellow_, black_
   x=x-dx
 else
   no = 33
   fini = 1                          'flag
 endif
End sub
sub take                              'interrupt to catch the letter
 t=1                                 'toggle
 z=z+1                               'counter
 BUZZ(1, 100)                        'buzzer 500Hz, 100 ms
end sub
SUB BUZZ(freq,length)                 'produces 0.5ms pulses on GP3
 local i
 for i = 1 to length                 'freq falls with higher numbers
   pulse GP3, 1                      'freq = 0.5 is 1kHz
   pause freq
 next
End sub
Edited 2022-11-27 21:32 by rea23
TimD
Posted: 12:04am 28 Nov 2022
Hi,
I've always found it frustrating trying to enter text using left & right buttons - a much quicker and friendlier method is to use a rotary encoder.  This will still need only 2 I/O pins, but it adds a little more complexity to your code.  I haven't used one personally, but you should be able to find plenty of information on the web and in this forum - indeed, there was a thread about this recently.
You could even use one that incorporates a momentary push switch as your 'enter' button - then you've got everything in one controller, and if you intend to house your circuit in a box then you'll only need to drill a single hole to mount it, rather than have to make 3 separate cut-outs for the push buttons.
Kind regards,
Tim.
Posted: 01:45am 28 Nov 2022
TimD's idea is excellent, and that is how I would go about it for this kind of text entry, but separate buttons is very simple and easy to manage in code, so I can see why you went in that direction.
Rotary-encoders need a bit more code to decipher what they are doing, but as TimD said, there are examples here on the forum if you do a search.
With any luck, someone in the know with rotary-encoders, will link to one of those threads, or post example code here for you to experiment with.  I too, have not really done anything with them, otherwise I would post some code.
panky
Posted: 05:35am 28 Nov 2022
For absolute minimum pin count, you could use an IR receiver and a spare remote you may have floating around. You could use just left, right and enter or decode in software the number keys into letters (like the old early mobile phones).
Doug.
Turbo46
Posted: 06:53am 28 Nov 2022
Geoff's Super Clock uses 'keyboard' touch buttons to enter text. It works quite well.
Bill
Posted: 07:53am 28 Nov 2022
Not elegant, just a bit shorter. Still needs work.
'Character Selector -  brief press pin 4 button to save character,
' long press after last character to save name & exit
CLS
Font 2 '12x20
SetPin 4,din,pullup :SetPin 5,din,pullup :SetPin 6,din,pullup
For n=1 To 52:carat$=carat$+" ":Next 'Make marker
MID$(carat$,26)="^"
x=14 : done=0
vpos = 100
For n=2 To 27 'make A - Z
 Text n*MM.Info(FONTWIDTH),vpos,Chr$(n+63)
Next
Text 1,vpos+MM.Info(FONTHEIGHT),Mid$(carat$,x)
 Do While Pin(4) And Pin(5) And Pin(6) : Loop ' wait for a button press
  If Pin(6)=0  Then
    Inc x,-1
    If x<1 Then x=1 :Print x,
    Text 2*MM.Info(FONTWIDTH),vpos+MM.Info(FONTHEIGHT),Mid$(carat$,27-x)
    Do : Loop Until Pin(6) 'wait for button release
  EndIf
  If Pin(5)=0  Then
    Inc x, 1
    If x>26 Then x=26 :Print x,
    Do : Loop Until Pin(5) 'wait for button release
  EndIf
  If Pin(4)=0  Then
    Timer = 0
    name$=name$+Chr$(x+64)
    Print x,Chr$(x+64),name$
    Do : Loop Until Pin(4) Or (Timer > 1500) 'wait for button release or finished
    If Timer > 1500 Then  done=1
  EndIf
Loop Until done
Text 100, vpos+3*MM.Info(FONTHEIGHT),name$
Print name$
Tinine
Posted: 08:19am 28 Nov 2022
Bluetooth....Phone...job done
Frank N. Furter
Posted: 08:33am 28 Nov 2022
Have any of you ever seen this concept here?
This is a "Filewalker " PDA: https://linuxdevices.org/new-euro-pda-boasts-linux-gsm-gprs-gps/
It works with a rotary encoder AND three buttons for index, middle and ring fingers.
I think this input is genius!
Frank
rea23
Posted: 01:15pm 28 Nov 2022
Thank you for the many good ideas and the shortening of the program. I have to think about what I want to use. But the idea to use a rotary encoder is really tempting.
Posted: 02:37pm 28 Nov 2022
For those who have no access to a rotary encoder: you can use a analog input and measure the voltage at a potmeter connected to 3.3V and 0.
A potmeter (and knob) have enough resolution to select individual characters (1 of 26).
Posted: 02:38pm 28 Nov 2022
Poor mans rotary....
TimD
Posted: 02:58pm 28 Nov 2022
A potentiometer is nice idea, especially since the cursor is travelling a line of letters with stops at each end - so turn it fully left and it's at 'A', turn it fully right and it's at 'Z' - there's no wrap-around to contend with.  You'd just have to ensure that it's linear rather than logarithmic, otherwise you'd need some extra maths in the code to keep the spread of the letters equally spaced around the travel of the potentiometer!
Kind regards,
Tim.
vegipete
Posted: 06:41pm 28 Nov 2022
An extra choice for DELETE would be useful too, in case the user mis-enters a character.
TimD
Posted: 07:16pm 28 Nov 2022
And wouldn't you need an 'End' option as well, to allow for variable length names?  Unless the intention is just to let it time out and accept what's been entered after a certain period of inactivity.
I think this would end up resembling a classic arcade game's 'name registration' screen for the high scores!
Kind regards,
Tim.
Posted: 08:36pm 28 Nov 2022
A button can be added to the pot. input without using an extra pin.
Add resistors (about 1/10th of pot. value) between the top and bottom ends of the pot. to the rails and put the button from wiper to ground. The bottom resistor ensures voltage can only reach zero when the button is pressed. The top resistor prevents a short if the button is pressed while the wiper is at the top.
A short press enters the letter and a long one enters the name, as in the above program.
Edit
Forget that.
Two buttons can be added to the pot. input without using any extra pins. Use the second to delete the last letter.
The top button inputs 3V3 and the lower 0V while the pot goes from 0.16V to 3.14V.
Edited 2022-11-29 17:23 by phil99
rea23
Posted: 10:16am 01 Dec 2022
Yes, TimD and phil99, it's a clever idea. And I like to turn instead of clicking.
I will do it with a potentiometer and one switch.
Many thanks
rea23
Posted: 03:59pm 03 Dec 2022
I made the circuit with a 10k potentiometer and R1k to 3.3 V and R1k to AGND. A button from wiper to ground is inserted. The setting of the letters works fine. But the transfer in the name always results in "?". Something in the program is terribly wrong and my old brain can't find the error.
' Text input with poti (TimD and phil99)
' ADC0, 1k-10k-1k gives (measured):
' 0.2790...3.0080 V over poti
' Switch down on lower R1k: 0.0130 V
' Poti works ok ==> shows A...Z
' Newname shows ??? instead
SetPin GP26, AIN                      'ADC0 at pin31
newname = ""
FONT 2, 1
Again:
do
 mvolt=int(1000*pin(31))             'millivolt
 diff=3008-279                       'measured min/max
 du=diff/25                          '26-1 between
 u=int(mvolt/du)-1                   'first # should be 1
 letter=chr$(u+64)                   'A is chr$(65)
 text 4, 100, "Letter is: " + letter,,2,, yellow_, black_  'is ok, A...Z
 pause 100
loop until mvolt < 220                'leave the loop
Take:
newname = newname + letter            '??? only, letter lost
text 4, 16, "New name is: " + newname,,2,, yellow_, black_
goto Again
'How to save the name? ===> long press
end
Posted: 04:56pm 03 Dec 2022
Hasn't the action of leaving the loop
changed the letter?
Posted: 05:38am 04 Dec 2022
Using Peter's insight and adding provision for a second button (top one in the above diagram) to delete the last letter.
It should work as you intend with your current wiring. The extra lines should not matter.
Const black_= RGB(255,255,255)        'black inv.
Const green_= RGB(255,127,255)        'green inv.
Const yellow_= RGB(0,0,255)           'yellow inv.
Dim letter As string length 1         'letter for name
Dim newname As string
newname = ""
CLS black_                            'display black, iRGB of (0,0,0)
Box 0,0,320,240,1, yellow_
Font 2, 1
Again:
 NewLetter = 0 : finished = 0
 mvolt=Int(1000*Pin(31))             'millivolt
 If (mvolt > 220) And (mvolt < 3100) Then   'Read letter if no buttons pressed
  u=Int(mvolt/du)-1                   'first # should be 1
  letter=Chr$(u+64)                   'A is chr$(65)
  Text 4, 100, "Letter is: " + letter,,2,, yellow_, black_  'is ok, A...Z
  Pause 100
 EndIf
 If mvolt < 220 Then                  'If lower button pressed add current letter
  Timer = 0
   If Timer > 1500 Then Finished = 1
  Loop While (mvolt < 220) And (finished = 0)               'wait for button release
  NewLetter = 1
  Print newname
 EndIf
 If mvolt > 3100 Then                 'If upper button pressed remove last letter
  Timer = 0
  Loop While (mvolt > 3100) And (finished = 0)              'wait for button release
  If Len(newname) > 0 Then newname = Left$(newname, Len(newname)-1)
  Print newname
  NewLetter = 1
 EndIf
Loop Until (NewLetter =1) Or (Finished =1)                'leave the loop
Take:
Text 4, 16, "New name is: " + "                             ",,2,, yellow_, black_
Text 4, 16, "New name is: " + newname,,2,, yellow_, black_
If Finished = 0 Then GoTo Again
Print newname
Text 4, 200, "Saved name is: " + newname,,2,, yellow_, black_
'How to save the name? >=== long press
End
edit
got something wrong in the delete letter loop but otherwise seems ok.
Edited 2022-12-04 17:26 by phil99
rea23
Posted: 09:20am 04 Dec 2022
@matherp:
Yes, we have to define what happens if mvolt < 220 (switch down).
But if I insert a line "IF mvolt < 220 THEN letter=letter" at the end inside the loop, the same behavior can be seen.
@phil99:
It's strange, but I get the error:
[31] Print If(mvolt > 220) And (mvolt < 3100) Then   'Read letter if no buttons pressed
Error : IF is not declared
And indeed, MM Edit or the interpreter knows nothing about a command IF or ENDIF/END IF. I don't no what happens.
Edit:
False alarm: After a restart of MM Edit the program works as intended. Thank you very much.
Edited 2022-12-04 20:47 by rea23
