Forum Index : Microcontroller and PC projects : PicoMite V5.07.06 preview - flash file system
| Page 1 of 5 |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11847 |
![]() Support for flash chips > 2M Copy to from SD to Flash |
LOL! But you can't do that.... ;) Nice one, Peter, very nice indeed. :) Can you write data files to the flash, not just programs? Mick Zilog Inside! nascom.info for Nascom & Gemini |
| Pluto Guru Joined: 09/06/2017 Location: FinlandPosts: 411 |
Great Peter! Just to clarify the "Flash". -I suppose this is the "onboard" flash memory chip, which is 2M on the "standard" green modules shown in the PicoMite User Manual. The new features will not be possible for these modules? -Do I have to buy an other module with e.g. 4M flash onboard or is it possible to add an "external" flash to the "standard" green modules for enabling the new features? Thanks! |
Standard Pico 2Mb |
Impressive - can you tell us some other things that can't be done with the PicoMite so that we can look forward to enjoying them in the future ? ![]() Joking aside, I thought the first post said it required flash > 2M ? Is this compatible with storing programs in flash slots ? Is access meaningfully faster than to the SDCard ? - I'm thinking in the context of using it to support the virtual memory that a full (128K) version of Z-MIM requires on the PicoMite. Best wishes, Tom Edited 2022-12-16 21:17 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Whoa, my PGA2040s have 8MB |
No: just includes support for >2Mb as well as the standard Based on simple test of just loading a file - yes much faster - remember the flash chip is memory mapped for read Current status is pretty much everything is working but only a single file allowed open at any one time (Same as ArmmiteL4) and single directory. That is the next (BIG) change (multiple files definite but directories not sure). Also not happy with the selection of the filesystem but can't use another command as no slots free. Finally haven't decided whether to allow file prefixes (A:, b:) also a very big change Edited 2022-12-16 21:23 by matherp |
<me> cheers! ![]() Mick Zilog Inside! nascom.info for Nascom & Gemini |
Brilliant! If some restrictions are needed, so be it. John |
This is such great news. I was planning on SD card but I don't need such capacity and I'm not 100% comfortable with them. |
Question: What trade-off between flash slots and flash disk? Flash slots can chain and run immediately (already tokenised) Disk is general purpose. My instinct is to set the maximum flash slots to 5 - thoughts? |
Could the max number of flash slots be a user option? Perhaps not to increase them, but to be able to sacrifice slots to get more "disk". Edited 2022-12-17 04:12 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
Woah, I know I asked for this, never thought it would ever be. You are asking for flash slots versus filesystem. I would either go for flash slots -or- filesystem. Personally I would use file system the most, since my programs are never large, but I do want to store data. And in many applications one Mbyte filesystem will suffice (300k is a bit limitted). Sacrifice all flash slots in that case. I would like to propose to make the command structure where possible identical to SD, since MMEdit filemanager can be used to pull data off. Or, discuss with Jim how this will work. Waow.... PicomiteVGA PETSCII ROBOTS |
| gadgetjack Senior Member Joined: 15/07/2016 Location: United StatesPosts: 236 |
I see this as a very nice gift for the picomite. Can't wait to try it out. Thanks Peter. |
Because of the complexity of the memory allocation flexible use of flash slots/flash disk is not possible |
| Bleep Guru Joined: 09/01/2022 Location: United KingdomPosts: 853 |
Can you give us a rough idea of what the trade off represents? ie. Is there any flash with 7 slots? How much flash do you gain for each slot lost? My current max is 3 slots linked, but I wouldn't want to be limited to only 3, so 5 may be a good compromise. Thanks as always for all the work you put into this. Regards Kevin Edited 2022-12-17 06:11 by Bleep |
Never mind, it was just an idea. :) In that case I'm rather undecided... Although you can mess about with data files to preserve variables it's not as "clean" as CHAIN. Program switching would also be slower as the new program would have to be tokenized. Perhaps it's as well to keep *some* flash slots. To get a command slot, would this be the time to get rid of, say, IRETURN which I doubt if anyone has used yet? It could be replaced by "*" or something to open up sub-commands: *filesystem [sd|flash] *copy or whatever... Probably a lot of work. Edited 2022-12-17 06:29 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
The preferred process is: Peter gets it working satisfactorily and then I adapt MMEdit to suit. If I am lucky, I will have to change one line in the MMCC.INF preferences file Change Type5 = picomite|autosave|\026|0|1|1|files|0|1|1|30 to Type5 = picomite|autosave|\026|0|2|1|files|0|1|1|30 The original Maximite had two drives so most of the 'user visible' work is already done in MMCC ready for any such innovation. What I have to do to get it working is not relevant. Jim Edited 2022-12-17 07:04 by TassyJim VK7JH MMedit |
| Page 1 of 5 |
