Local Time 07:21 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Simplest possible PicoMite VGA hookup ......
     Page 1 of 3
hitsware2
Posted: 09:06pm 01 Mar 2023
MonoChrome ......
I'm sure it's been discussed before ,
but I can't seem to find a definitive
plan .
my site
Posted: 09:29pm 01 Mar 2023
Easy to do but you gain nothing as the firmware always reserves two pins for the synch signals and four pins for the video data. If you load the four video pins with series resistors in a binary series (1-2-4-8) then use an emitter follower to drive a single video output you can get 16 grey shades (including black and white).
Posted: 09:32pm 01 Mar 2023
A single 270R from any one of the 4 VGA colour pins on the Pico to any one of the three colour pins on the VGA socket (1,2,3).
In Mode 1 where a foreground colour needs to be specified use 1
In Mode 2 use RGB(White) or 2^24-1 (eg Const W = 2^24-1)
If using the Pico Blue pin that can be reduced to 255.
hitsware2
Posted: 09:57pm 01 Mar 2023
  phil99 said  A single 270R from any one of the 4 VGA colour pins on the Pico to any one of the three colour pins on the VGA socket (1,2,3).
One resistor .... No diodes ?
my site
Posted: 10:19pm 01 Mar 2023
No diodes. The diodes were included in that circuit to clip the the drive to about 0.6V. Only very old, cheap CRT monitors with no beam current limiting require that to prevent "Burning" the screen phosphor. Even the cheapest LCD can clip the level at 100% brightness.
Edit
The minimal 16 colour version is just 4 resistors.
R -> 270 -> 1
GH -> 390 -> 2
GL -> 820 -> 2
B -> 270 -> 3
Edited 2023-03-02 08:27 by phil99
hitsware2
Posted: 03:01am 02 Mar 2023
Like this ?
          Green Only
 Pico                   VGA
  28 x--------220-------x 2
  23 x------------------x 5,6,7,8,10
  21 x------------------x 13
  22 x------------------x 14
my site
Posted: 07:37am 02 Mar 2023
Almost, Pin 28 is a Ground pin. 220R should work but 270R puts a little less load on the Pico pin yet still gets close to 100% brightness.
Although Pin 24 (GP18) is the Blue signal it has the lowest colour number so any number from 0 to 127 is Black and 128 to 255 is Green with the following connections.
         Green Only
Pico pin                     VGA
 24  GP18 blue x---------270--------x 2 green
 23  Gnd x--------------------------x 5,6,7,8,10 Gnd
 22  GP17 V Sync x------------------x 14 V Sync
 21  GP16 H sync x------------------x 13 H sync
hitsware2
Posted: 04:37pm 02 Mar 2023
Thank You !
This will work with the Pico tied to a PC right ?
Not only on the stand alone version .............
my site
Posted: 04:46pm 02 Mar 2023
  hitsware2 said  This will work with the Pico tied to a PC right ?
Such as via USB (PC USB A to Pico uUSB cable)? Yes.
And then run a "terminal" program (putty, tera term, ...).
You don't need a PS/2 keyboard.
Edited 2023-03-03 02:46 by JohnS
Posted: 04:51pm 02 Mar 2023
It's still a VGA signal and has to be fed into a VGA input on something. Mono VGA monitors aren't all that common now.
The USB connection will connect to a PC as usual for a PicoMite - but it's the console, not a graphics display.
Posted: 05:07pm 02 Mar 2023
  Mixtel90 said  The USB connection will connect to a PC as usual for a PicoMite - but it's the console, not a graphics display.
Oh, yes, very good point.
Things like EDIT do produce some colour on the USB terminal, though, sent as VT100 escape sequences.  So you can have coloured characters if you use EDIT.  (So long as your terminal program understands the escape sequences, as things like screen & putty do.)
hitsware2
Posted: 08:17pm 02 Mar 2023
Won't using the above circuit (blue RGB pin only)
make a mono VGA using a meant for color VGA monitor ?
my site
Posted: 08:25pm 02 Mar 2023
  hitsware2 said  Won't using the above circuit (blue RGB pin only)
I think so.
Blue and dark (black) may not be lovely to look at. Green, maybe?
Posted: 09:20pm 02 Mar 2023
For mono the names of the Pico output colours don't mean anything, only the VGA pin it is connected to affects the colour. Hitsware2 will be connecting it to green (pin 2).
Any of the 4 outputs can be used, it's just a little simpler to use the Blue output as noted in my previous post.
If OPTION COLOURCODE ON is used it will colour the editor in TeraTerm but make the monitor unusable for editing.
Going colour requires just 3 more resistors. Then when you want mono just use RGB(green) for every colour.
Latest VGA manual, top of p6 shows how to connect it.
hitsware2
Posted: 09:22pm 02 Mar 2023
I think so.
Blue(Pico).................Green(VGA connector) ..... ???
my site
Posted: 09:30pm 02 Mar 2023
Yes, connect blue to green if you like.
Posted: 10:23pm 02 Mar 2023
I'm a bit confused...
What *exactly* is the point? Is it a VGA mono monitor? If it's a colour VGA monitor have you tried just turning the colour setting down to zero? Is the idea to get mono (i.e. black and green, black and amber etc) or shades of grey?
The existing VGA interface cant really get much simpler - four resistors (and two of those are the same value). :)
Posted: 10:54pm 02 Mar 2023
  Quote  What *exactly* is the point? Is it a VGA mono monitor? If it's a colour VGA monitor have you tried just turning the colour setting down to zero?
Yes, I have been wondering that myself....
hitsware2
Posted: 12:43am 03 Mar 2023
The point is the elegance of simplicity.
1 resistor is simpler than 4.
I have a standard (color) monitor.
By "monochrome" I mean 1 color over black (no color)
Since I would like to emulate a CRT oscilloscope,
a green "trace" would be fine.
my site
hitsware2
Posted: 03:10am 03 Mar 2023
O.K..........
I have a Pico in a breadboard with  V5.07.06
The editor comes up and works .... ( On RaspBerry Pi ( using SCREEN ) )
Monitor says ' no signal '
Neither pin 21 or 22 show any pulses (low)
Do I need to do something to initiate VGA ?
my site
     Page 1 of 3
