Forum Index : Microcontroller and PC projects : Problem with JPG/BMP and Waveshare RP2040-LCD-1.28
| Page 1 of 2 |
Hi, I have tried the demo from Peter ( https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=15427 ). Unfortunately, the background image is not included. I have therefore experimented with my own images, unfortunately with only moderate success... Diese beiden Bilder zeigen mein Problem, hier die Originale: DSC03042.zip ...and this is how the JPG looks like: ...and this is the BMP: This is how it should look: ![]() I have the current beta version - ? mm.ver says 5.07.07 What's going wrong here? I have tried other images, also with different image programs... Frank |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11848 |
Are you using the framebuffer or loading direct to the display? If the framebuffer then this is what you would expect as it is only RGB121 |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3378 |
This will test the number of colours that the display is capable of producing, though it does need MISO to be connected to SDO on the display. 'Display Colour Counter - requires MISO connected to LCD_SDO dim a$(2)=(" Blues"," Greens"," Reds") dim integer b, c, n for b=0 to 2 n=0 for c=0 to 255 pixel 99,99,c<<b*8 if pixel(99,99)=c<<b*8 then inc n endif next Print n;a$(b) next Edited 2023-04-19 18:25 by phil99 |
@Peter: I tried LOAD IMAGE and LOAD JPG. Can you give me "face" from your demo??? How can I generate RGB121 pictures? @Phil: With your program nothing happens at all on the display - the clock hands from the previous program are still shown... At the first attempt (to save the previous program), XMODEM SEND gave the error NOT ENOUGH MEMORY!? Only after an aborted XMODEM RECEIVE I could send my previous program successfully... Frank |
You haven't answered the question. If you are loading an image to a framebuffer or moving it to a framebuffer it is compressed to RGB121 - the same colour set as the PicoMiteVGA. To create a RGB121 image to your specification you would need to tell your photo program what the VGA palette is and get it to just use those colours but you are still limited to just the 16. If you are not using the framebuffer then there may be a bug but please just reset the Pico and then load your image from the command line - nothing else - is it OK then? My image is not useful. It is a greyscale image that I have manipulated and just has the dial markings Edited 2023-04-19 20:37 by matherp |
Sorry Peter, I did not understand your question. Do you mean I should run LOAD JPG from Console? If yes, then it behaves a bit strange: > files A:/ <DIR> . <DIR> .. 00:00 01-01-2000 4 bootcount 00:02 01-01-2000 39808 DSC03042.jpg 2 directories, 2 files > load jpg "DSC03042" Error: Invalid address - resetting PicoMite MMBasic Version 5.07.07RC4 Copyright 2011-2023 Geoff Graham Copyright 2016-2023 Peter Mather > load jpg "DSC03042" > After that the image looks better: ![]() Is that what you need from me? ...if not, please tell me what to enter... Frank UPDATE: This behavior is reproducable! When I call LOAD JPG without FILES in front of it, nothing happens - no other image, just nothing at all! But if I call FILES before, every time after LOAD JPG the "Invalid address" error comes. After the reset I can load the image correctly. When I then start the program, it looks again like the pictures at the top. Edited 2023-04-19 22:03 by Frank N. Furter |
Peter fixed the memory issue with files some time ago. Try RC5 that seems ok. The colour counter only uses a single pixel, so that is why you didn't see anything on the screen. On the console you should see something like this:- > RUN 64 Blues 64 Greens 64 Reds > or this:- > RUN 32 Blues 64 Greens 32 Reds > Something is wrong if you get this:- > RUN 1 Blues 2 Greens 1 Reds > However you needn't bother as your last photo shows the display is working properly. |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1548 |
The Image has more Colors than the Pico can display Here is an Online Ditherer, where you can save (copy and Past) a Custom Color Palette and it dithers in many different ways: https://ditherit.com/ the Custom Palette for the Pico to past in looks like this: [{"hex":"#000000"}, {"hex":"#FF0000"}, {"hex":"#0000FF"}, {"hex":"#FF00FF"}, {"hex":"#004000"}, {"hex":"#FF4000"}, {"hex":"#0040FF"}, {"hex":"#FF40FF"}, {"hex":"#008000"}, {"hex":"#FF8000"}, {"hex":"#0080FF"}, {"hex":"#FF80FF"}, {"hex":"#00FF00"}, {"hex":"#FFFF00"}, {"hex":"#00FFFF"}, {"hex":"#FFFFFF"}] then it might look like this: ![]() 'no comment |
@Phil: Where can I find RC5? I just downloaded RC4 yesterday as the latest beta version from Geoffs site... Yes, the display seems to be ok - so the picture would be fine. @Martin: I don't think so - the image is displayed properly after the RESET. Frank |
RC5 https://www.thebackshed.com/forum/ViewTopic.php?TID=15793&P=4#202272 |
Thanks for the link! Unfortunately RC5 behaves the same way! Frank |
Please list options, delete anything in the library, specify exactly which version you are running and give me an exact sequence of commands that goes wrong following a H/W reset |
Hi Peter, I tried 5.07.07RC4 and the latest RC5 from yesterday - all the same! These are all options: > option list PicoMite MMBasic Version 5.07.07RC5 OPTION SYSTEM SPI GP10,GP11,GP28 OPTION COLOURCODE ON OPTION LCDPANEL GC9A01, LANDSCAPE,GP8,GP12,GP9,GP25 > I have never used the library. I used your program with only marginal changes. Only BACKGROUND and LOAD JPG was added (LOAD IMAGE behaved the same with the corresponding BMP). Option explicit Option default none ' Const Y_top = 0 'Y coordinate of top of the image file on the screen Const X_left = 0 'X coordinate of left of the image file on the screen Const s_Y_point = 172 'Y coordinate of the centre of the second hand relative to the image top Const s_X_point = 119 'X coordinate of the centre of the second hand relative to the image left Const h_Y_point = 119 'Y coordinate of the centre of the hour and minute hands relative to the image top Const h_X_point = 120 'X coordinate of the centre of the hour and minute hands relative to the image top Const sl=-30 Const ml=-100 Const hl=-75 Backlight 100 ' ' ' ' Now we define the pointers as the X,Y coordinates of a number of triangles with the rotation point at 0,0 ' It is simplest to define this in the 12-oclock position which means the Y-coordinates at the top of the pointer will be negative ' The order of data elements in the array is: ' t1x1,t1y1,t1x2,t1y2,t1x3,t1y3, t2x1,t2y1,t2x2,t2y2,t2x3,t2y3,...tntx1,tnty1,tntx2,tnty2,tntx3,tnty3 ' Dim integer nt=6 'Number of triangles used to define the pointer Dim integer x1(nt-1)=(-1,-1,-2,-2,-3,-3) Dim integer y1(nt-1)=(0,0,0,0,0,0) Dim integer x2(nt-1)=(-1,1,-2,2,-3,3) Dim integer y2(nt-1)=(sl,sl,ml,ml,hl,hl) Dim integer x3(nt-1)=(1,1,2,2,3,3) Dim integer y3(nt-1)=(sl,0,ml,0,hl,0) Dim INTEGER pcolour=RGB(Green) 'define the colour of the pointer Const s_pivot=3, m_pivot=5, h_pivot=3 'diameter in pixels of the fulcrum of the pointer ' Dim integer xx0(nt-1),yy0(nt-1),xx1(nt-1),yy1(nt-1),xx2(nt-1),yy2(nt-1),tcol(nt-1) Dim integer first=1 'marker to control alternate processing on first time through the loop ' FRAMEBUFFER create FRAMEBUFFER layer FRAMEBUFFER write l CLS Load JPG "DSC03042" 'Load Image "DSC03042" ' ' demo code moving the pointer Dim float secondangle=0, minuteangle=0, hourangle=0 Do FRAMEBUFFER copy l,f If secondangle Mod 60=0 Then Inc minuteangle,1 If (minuteangle Mod 72=0) And (secondangle Mod 60=0) Then Inc hourangle,6 drawpointer FRAMEBUFFER copy f,n Inc secondangle,6 Loop ' Sub drawpointer Local integer i,x,y Local float angle For i=0 To nt-1 If i<2 Then x=s_X_point y=s_Y_point pcolour=RGB(red) angle=secondangle Else x=h_X_point y=h_Y_point pcolour=RGB(white) If i<4 Then angle=minuteangle Else angle=hourangle EndIf EndIf rotatetriangle(i,pcolour,angle,x+X_left,y+Y_top,x1(i),y1(i),x2(i),y2(i),x3(i),y3(i)) 'rotate the pointer into the drawing array Next i FRAMEBUFFER write f Triangle xx0(), yy0(), xx1(), yy1(), xx2(), yy2(),tcol(),tcol() drawpivot End Sub Sub rotatetriangle(n As integer, col As integer, angle As float, x As integer,y As integer, x0 As integer, y0 As integer, x1 As integer, y1 As integer, x2 As integer, y2 As integer) Local float sine=Sin(Rad(angle)),cosine=Cos(Rad(angle)) Local integer x0a,y0a,x1a,y1a,x2a,y2a x0a= x0*cosine - y0 * sine + x y0a= y0*cosine + x0 * sine + y x1a= x1*cosine - y1 * sine + x y1a= y1*cosine + x1 * sine + y x2a= x2*cosine - y2 * sine + x y2a= y2*cosine + x2 * sine + y xx0(n)=x0a yy0(n)=y0a xx1(n)=x1a yy1(n)=y1a xx2(n)=x2a yy2(n)=y2a tcol(n)=pcolour End Sub ' Sub drawpivot() 'put anything you like here to draw the fulcrum as you wish Circle s_X_point+X_left,s_Y_point+Y_top,s_pivot,0,,,RGB(green) Circle h_X_point+X_left,h_Y_point+Y_top,m_pivot,0,,,RGB(white) Circle h_X_point+X_left,h_Y_point+Y_top,h_pivot,0,,,RGB(black) End Sub If I start your program, quit (CTRL-C) and call LOAD JPG "DSC03042", nothing happens. But if I type FILES before that and then LOAD JPG "DSC03042", the system crashes and reboots. If I then enter LOAD JPG "DSC03042", the image is displayed correctly. When I start the program again, the image is displayed incorrectly again. During this procedure, the OPTION AUTOSTART ON function was apparently also lost... This is reproducible with RC4 and RC5 for me. Before I used RC5, I first flashed "Clear_flash.uf2". Here you can see what I just entered: > option list PicoMite MMBasic Version 5.07.07RC5 OPTION SYSTEM SPI GP10,GP11,GP28 OPTION COLOURCODE ON OPTION LCDPANEL GC9A01, LANDSCAPE,GP8,GP12,GP9,GP25 > LIBRARY DELETE > run > Load JPG "DSC03042" > run > Load JPG "DSC03042" > files A:/ <DIR> . <DIR> .. 00:00 01-01-2000 4 bootcount 00:01 01-01-2000 39808 DSC03042.jpg 2 directories, 2 files > Load JPG "DSC03042" Error: Invalid address - resetting PicoMite MMBasic Version 5.07.07RC5 Copyright 2011-2023 Geoff Graham Copyright 2016-2023 Peter Mather > Load JPG "DSC03042" > run LIBRARY DELETE has no influence. At the lowest LOAD JPG call the image is displayed correctly, at the following RUN the image is wrong again. Frank |
OK Let's go through this bit by bit This is because the image is being written to a framebuffer and not the screen after you ctrl-C out of the program. Framebuffers need to be understood and treated with caution. This is a bug that I think I have found and fixed in RC6. Please let me know once posted This is correct. The image is being compressed to RGB121 when copied into the framebuffer. The image will only ever show properly if loaded direct into the display itself. This is because after a reset the image is sent directly to the screen |
...exact same behavior with RC6: > load jpg "DSC03042" > files A:/ <DIR> . <DIR> .. 00:00 01-01-2000 4 bootcount 00:01 01-01-2000 39808 DSC03042.jpg 2 directories, 2 files > load jpg "DSC03042" Error: Invalid address - resetting PicoMite MMBasic Version 5.07.07RC6 Copyright 2011-2023 Geoff Graham Copyright 2016-2023 Peter Mather > Frank |
Hi Martin, I would use THIS as a pallette for "dither_it". Green can be 0, 1/3, 2/3 or 1 (not 0, 1/4, 1/2, 1 as suggested above). [{"hex":"#000000"}, {"hex":"#FF0000"}, {"hex":"#0000FF"}, {"hex":"#FF00FF"}, {"hex":"#005500"}, {"hex":"#FF5500"}, {"hex":"#0055FF"}, {"hex":"#FF55FF"}, {"hex":"#00AA00"}, {"hex":"#FFAA00"}, {"hex":"#00AAFF"}, {"hex":"#FFAAFF"}, {"hex":"#00FF00"}, {"hex":"#FFFF00"}, {"hex":"#00FFFF"}, {"hex":"#FFFFFF"}] Volhout PicomiteVGA PETSCII ROBOTS |
Please post the jpg. I can't replicate with my normal "tiger" test jpg |
DSC03042.zip Can you send me your tiger? It happens here with all JPG's that I try... Frank |
There is something not quit right with the JPG compression of that image. First time I loaded it no problem but after files:- . . . 01:45 01-01-2000 230454 VGAPico_Test.bmp 11:55 20-04-2023 5812 VU Meter.bas 11:20 20-04-2023 460854 VUmeter.bmp 3 directories, 124 files > load jpg "DSC03042a.jpg" Error : pjpeg_decode_init() failed with status 19 > Made a new JPG from the original BMP using Irfanview and it loads without problems after files. Also tried another JPG much bigger than the screen, still no problem. Try this. ![]() Right click on the image an choose "save image as". Edited 2023-04-20 23:43 by phil99 |
I renamed it to "A.jpg" - same behavior: > load jpg "A" > files A:/ <DIR> . <DIR> .. 00:01 01-01-2000 9472 A.jpg 00:00 01-01-2000 4 bootcount 00:18 01-01-2000 14592 DSC03042.jpg 2 directories, 3 files > load jpg "A" Error: Invalid address - resetting PicoMite MMBasic Version 5.07.07RC6 Copyright 2011-2023 Geoff Graham Copyright 2016-2023 Peter Mather > Frank |
| Page 1 of 2 |
