Local Time 20:17 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Two problems - #1 ILI9341 not working and #2 I2C not working
VK2AHB
Posted: 02:12am 23 May 2023
I bought a couple of these TFT displays. They look very similar to the one on P47 of the manual except don't have the Touch IC.
I set up the OPTIONS as per P47 and connected one up as per the diagram (without the four SD card connections on the right).
Alas, all I got was a white screen for GUI TEST LCDPANEL.
After this failure, I did OPTION RESET, set the options as before and reconnected the SSD1306I2C display which had been working. I hadn't moved these connections on Pins 1,4,5.
OPTION SYSTEM I2C GP2, GP3
OPTION SYSTEM SPI GP10, GP11, GP12
OPTION LCDPANEL SSD1306I2C, LANDSCAPE
OPTION SDCARD GP13
When I ran my DateTimeTemp program, I got an error - RTC not responding. Nothing was working. PRINT TEMPR(1) returned 1000 from the DS18B20. Nothing on the display so I reloaded the firmware to see if that would help. No, it didn't.
Interestingly, the program was still in memory after the reload of firmware. I thought it would clear everything.
Paul VK2AHB
Posted: 03:37am 23 May 2023
That nothing on System I2C is working suggests a continuity issue. Check that you have low resistance from Pico 3V3, Gnd, SDA and SCL pins to the corresponding pins on each device and no shorts between them.
Could SDA and SCL have got transposed? GP2 = Pin 4 = SDA, GP3 = Pin 5 = SCL.
VK2AHB
Posted: 05:45am 23 May 2023
After putting #1 board back in, all worked.
So I put #2 board back in, and it worked too!
'5 Aces beats me!'
Paul VK2AHB
VK2AHB
Posted: 05:46am 23 May 2023
But the problem of the TFT display remains.
Paul VK2AHB
morgs67
Posted: 06:49am 23 May 2023
  VK2AHB said  I bought a couple of these TFT displays. They look very similar to the one on P47 of the manual except don't have the Touch IC.
Paul VK2AHB
I believe GUI controls only work with TOUCH, so no touch IC no GUI items, such as GUI TEST.
Tony
Posted: 12:18pm 23 May 2023
A simple way to test an LCD panel.
CLS RGB(RED): PAUSE 500: CLS RGB(GREEN): PAUSE 500: CLS RGB(BLUE)
Posted: 12:22pm 23 May 2023
  Quote  I believe GUI controls only work with TOUCH, so no touch IC no GUI items, such as GUI TEST.
Not true. GUI TEST LCDPANEL will always work when a display is configured.
If you get just a white screen then either the wiring is incorrect or it isn't an ILI9341 controller
stanleyella
Posted: 03:16pm 23 May 2023
ili9341 runs from 5V although the signal pins are 3.3V logic level.
RU powering at 5V?
Are the touch pins wired.. without the touch chip?
Posted: 03:43pm 23 May 2023
  stanleyella said  ili9341 runs from 5V although the signal pins are 3.3V logic level.
RU powering at 5V?
Not sure how relevant it is, but my experience is you can run an ILI9341 module (specifically the 2.8" red one) quite happily from 3.3V - though now I come to think of it whilst I have wired them for touch I have never actually used it, so someone else will need to chime in there.
Edited 2023-05-24 01:46 by thwill
stanleyella
Posted: 06:08pm 23 May 2023
RU powering at 5V?
supply says vcc and goes through a 3.3V 3 pin reg so might cause a problem with 3.3V supply. just a thought. I have an ili9341 without touch chip and works ok for display only. ones with touch and sd card work but from 5V supply. There's a solder jumper to short the 3.3V reg so it runs from 3.3V.
VK2AHB
Posted: 01:37am 24 May 2023
The diagram on P47 shows Vcc and LED going to 5V.
Paul
Posted: 07:04am 24 May 2023
An unmodified ILI9341 is designed to run from 5V on VCC. The IO signals are 3V3 compatible as the on-board components, apart from the LCD backlight, are fed via an on-board LDO regulator. The backlight is designed to run from 5V but will run a bit dimmer from 3V3. You can run the display completely from 3V3 by closing the link close to the regulator (it simply shorts it out). Don't apply 5V to VCC after you've done that - you'll probably kill the whole display permanently.
My personal choice is to use these displays as intended. The backlight is quite a heavy load and running it from a regulated supply brings no benefit. You are heating up a regulator for nothing. You *may* be able to power the whole display from the PicoMite's 3V3 switcher, but I'd suggest using PWM to dim the backlight to reduce the current draw. Also, put a capacitor from VCC to GND at the display to reduce those PWM pulses a bit.
Have you any idea what those displays actually are, Paul? Is the pinout the same as the P47 example?
Posted: 08:27am 24 May 2023
  matherp said  If you get just a white screen then either the wiring is incorrect or it isn't an ILI9341 controller
Some time ago, if my geriatric memory is to be trusted, someone received a display with a different controller chip to the one they ordered. They looked the same but as none have the chip ID printed on them a supplier could get them mixed up.
Trial and error may be the only way to find the right driver.
VK2AHB
Posted: 12:39pm 24 May 2023
Yes, the pinouts are exactly the same.  But if the controller chip is something else, where do I go then?
Paul
Posted: 12:55pm 24 May 2023
The manual lists a number of SPI panels that use the same pins on the Pico.
Type:-
OPTION LCDPANEL DISABLE
to remove the current driver.
Configure the next on the list and repeat till one works.
First I would check continuity from each pin on the Pico to the corresponding pin on the panel. Breadboard contacts aren't always reliable.
Posted: 01:18pm 24 May 2023
  Quote  First I would check continuity from each pin on the Pico to the corresponding pin on the panel. Breadboard contacts aren't always reliable.
Very true!
If ILI9341 doesn't work then ILI9488 would be my second guess.
Edited 2023-05-24 23:19 by Mixtel90
Posted: 02:15pm 24 May 2023
I use the same module.
You must power it from 5v (Vsys of pico).
The module has 4.7k pullup resistors. If you add 10k pull down resistors on your breadboard you get nice 3.3 v logic levels.
For me it is working fine.
Remark: my unit needed a rechargeable battery, if you use a lithium or alkaline battery you may destroy the battery sine it will try to charge it.
Edited 2023-05-25 00:16 by Volhout
VK2AHB
Posted: 02:16am 25 May 2023
Progress of sorts!  Using ILI9481 gave rubbish for most of the screen but GUI TEST worked in a small area.
ILI9488 works sorta! Orientation is reversed, ie P=Landscape and colours are wrong.
However, it's a start.
VK2AHB
Posted: 03:08am 25 May 2023
I spoke too soon!
I plugged in an RTC and DS18B20 on the breadboard, and now the display doesn't work.
I disconnected them, still no go.
There is 4.84 on Vbus and 4.5B on Vsys.
Paul VK2AHB
Posted: 05:00am 25 May 2023
That you keep having go / no-go hardware issues suggests that breadboard is ready for retirement.
Getting something on the screen is encouraging. When you have the reliability issue sorted try more drivers.
