Local Time 00:05 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite - adventures in sound
     Page 1 of 3
Posted: 12:33pm 08 Nov 2023
I've been playing with the VS1053 module from LC (this one )
So far I've managed to get it playing back mp3, flac and wav files from SDcard with, of course, better audio quality than the native PicoMite audio.
In addition I've got it supporting real-time midi. i.e. you can send it the various midi instructions (note on, note off, channel, etc.) and it will interpret them. The chip supports a maximum polyphony of 64, and the maximum sustained polyphony is 40.
the instruments supported are as below.
If I can get the various wrinkles sorted out I will include full support for this board into the PicoMite firmware
Edited 2023-11-08 22:34 by matherp
Pluto
Posted: 01:24pm 08 Nov 2023
PilotPirx
Posted: 01:59pm 08 Nov 2023
Sounds great
Ideal for midi files in the background.
Next PicoMite board with this chip?
Martin H.
Posted: 03:13pm 08 Nov 2023
nice
Datasheet
Edited 2023-11-09 01:14 by Martin H.
'no comment
Pluto
Posted: 04:31pm 08 Nov 2023
Newer datasheet.
VS1053.PDF
Don't know if any significant differences compared to Martin's.
Fred
Pluto
Posted: 04:36pm 08 Nov 2023
Sorry, link was not Ok.
VS1053 (1).PDF
Posted: 06:23pm 08 Nov 2023
If anyone has got one of these here is some firmware to play with
PicoMite.zip
PLAY VS1053 XCSpin, XDCSpin, DREQpin, XRSTpin [, fname$ [,interrupt]]
NB: OPTION SYSTEM SPI must be set up and wired to the MISO, MOSI, and SCK pins on the module
NB: OPTION AUDIO does not need to be set to use the VS1053
NB: maximum CPU speed for this module is 252MHZ
modes of use:
File playback
PLAY VS1053 XCSpin, XDCSpin, DREQpin, XRSTpin , fname$ [,interrupt]
Plays the file fname$ in the background. This can be a FLAC, MP3, WAV or MIDI file.
NB: The MIDI file must be in format 0, i.e. all tracks interleaved.
Use the optional parameter interrupt to trigger an MMBasic interrupt when playback is complete.
Real time MIDI
This opens the VS1053 in real time MIDI mode meaning it responds to MIDI commands. To support this use:
PLAY NOTE ON channel, note, velocity
PLAY NOTE OFF channel, note [,velocity]
PLAY CMD cmd, data1 [,data2]
Together these allow you to use all the channels, instruments and notes the VS1053 is capable off
Use PLAY STOP to exit this mode
Feedback appreciated
Edited 2023-11-09 04:27 by matherp
vegipete
Posted: 10:27pm 08 Nov 2023
There's a version of these VS1053 boards with a line in jack and an SD card slot. Are these usable too?
Is microphone support possible?
Posted: 08:46am 09 Nov 2023
Should work but no promises. The issue is that connections to the VS1053 I/O pins configure how it behaves on boot. My code overrides these default configurations but I can't guarantee that I've caught them all. Hopefully I have as the board I picture is known to have an unusual default configuration which I had to override to get it to play mp3 etc.
Posted: 10:36am 09 Nov 2023
Lots of midi files posted seem to be the wrong format for the VS1053 so I've included a format conversion program in MMB4W. Uses too much memory to be included in the PicoMite.
Use
PLAY CONVERT fname1$,fname2$
MMBasic.zip
Posted: 12:41pm 09 Nov 2023
Is the file in that zip supposed to be MMBasic.exp (that is, exp rather than exe)?
Posted: 12:44pm 09 Nov 2023
Oops
MMBasic.zip
goc30
Posted: 04:23pm 20 Nov 2023
Hi Pete
I have the same configuration
MAKER PI PICO card
Pico 2040
sound card as your (gp9,gp8,gp7,gp6)
PicoMite MMBasic Version 5.07.08RC20
OPTION SDCARD GP15
for that I send midi command and I receive
> play vs1053 gp9,gp8,gp7,gp6
Error : Audio not enabled
if I put option audio, I receive that
> option audio spi gp9,gp6,gp7
Copyright 2011-2023 Geoff Graham
Copyright 2016-2023 Peter Mather
Error : Unknown command
where I make mistake ??
Posted: 04:37pm 20 Nov 2023
See here
goc30
Posted: 04:44pm 20 Nov 2023
> option list
OPTION SDCARD GP15
> option audio vs1053 gp10,gp11,gp12,gp9,gp8,gp7,gp6
Error : Pin 14/GP10 is in use
Edited 2023-11-21 02:48 by goc30
Posted: 05:01pm 20 Nov 2023
From the referenced post
  Quote  Note that like the MCP4822 the VS1053 uses a separate SPI port from that specified by OPTION SYSTEM SPI. A dedicated SPI channel is essential to allow it to be used in a H/W interrupt routine.
goc30
Posted: 05:03pm 20 Nov 2023
You wrote at the top of this page
and on yours pictures VScard is connected on the same SPI as sdcard
Edited 2023-11-21 03:05 by goc30
Posted: 05:20pm 20 Nov 2023
Yes but this thread refers to an experimental test version. As always the final version will be in the release candidate thread and documented there.
goc30
Posted: 06:00pm 20 Nov 2023
now it work
> option list
OPTION SDCARD GP15
OPTION AUDIO VS1053 GP2,GP3,GP4,GP9,GP8,GP7,GP6', ON PWM CHANNEL 1
> play mp3 "b:track0002.mp3"
pb of doc not very clear
Frank N. Furter
Posted: 01:03pm 29 Nov 2023
Hi,
is it possible to start an MP3 file at a certain point or can the file only be started from the beginning?
It would be great to build an audiobook reader that can memorize the position in the MP3 file and play it back from that position after switching it on again.
Would that be possible?
Frank
     Page 1 of 3
