Local Time 19:15 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CNC Speed Monitor
OA47
Posted: 08:13am 05 Feb 2024
I would like to monitor the speed of the spindle in my CNC router. It has a motor capable of 20,000 rpm and I was wondering if any shedders could offer assistance with this project. I am considering using a mite with a display attached and contemplating either using IR transceiver with a reflector on the 52mm barrel fan at the top of the spindle or using the audio generated by the spindle.
Any thoughts?
0A47
PhenixRising
Posted: 08:35am 05 Feb 2024
Magnet + hall-effect? Bit more robust than an optical solution.
Posted: 09:01am 05 Feb 2024
Hall sensors are good !
If you place a (even small, such as 3mm) magnet you have to re-balance the spindle (definitely at 20000 rpm). Put 2 magnets at opposite sides, as good as you can balanced, use epoxy glue).
Reflective optical sensor. You can mark half of the fan blades white, the other half black. A reflective sensor will distinguis between white and black.
But it is a spindle of a CNC, so when dus settles in I would go for the hall sensor..
Posted: 09:50am 05 Feb 2024
At that speed, personally, I'd go for optical - but only if you have access to the back of the shaft where you can enclose the sensor. Just paint half the shaft matt black.
An approach that might be worth a try is to wind an air cored coil and stick it to one side of the motor. You *might* be able to pick up the field winding. Try it with a scope. You couldn't use the signal directly, it would have to be amplified, shaped and possibly divided down to something sensible.
PhenixRising
Posted: 10:19am 05 Feb 2024
A more elegant solution
Posted: 10:27am 05 Feb 2024
At 20,000 RPM you don't really want to be attaching anything to the shaft at all. Rebalancing the system is no easy job. If it's not perfectly balanced then, as a minimum, you are going to make the cut wider as the motor body oscillates.
Ideally, if it's some sort of digital motor, you'd extract the speed signal from the motor electronics.
PhenixRising
Posted: 11:21am 05 Feb 2024
  Mixtel90 said  At 20,000 RPM you don't really want to be attaching anything to the shaft at all. Rebalancing the system is no easy job. If it's not perfectly balanced then, as a minimum, you are going to make the cut wider as the motor body oscillates.
It's a cutting tool, not a turbine. They're designed for radial loading.
Posted: 11:30am 05 Feb 2024
At that speed attach nothing to the shaft, the vibration will be excessive.
An IR remote control receiver and LED modulated at 38kHz make an excellent tacho as the receiver is designed to tolerate a lot of ambient light.
One I made uses a NE555 for modulation and plugs on to a handheld scope. The frequency readout gives the speed and the trace shows the signal quality.
Edited 2024-02-05 21:33 by phil99
Posted: 11:43am 05 Feb 2024
That's true, but any imbalance in the motor shaft will also cause imbalance in the tool - and, in fact, in the whole motor. If you are lucky it won't break the motor mountings or damage the X-Y axis bearings.
I've seen the inside of a control panel mounted on a wall of a wind tunnel. You don't feel the vibration in that area but it unscrewed self-tapping screws and some components were only in position because at least some of their wires were still attached. You don't mess with vibration. :)
Posted: 01:21pm 05 Feb 2024
  phil99 said  At that speed attach nothing to the shaft, the vibration will be excessive.
That is actually a good idea. The IR sensors have build in AGC (automatic gain control) so they might even work fine as reflective sensors. On a half black/half white painted shaft
PhenixRising
Posted: 01:34pm 05 Feb 2024
  PhenixRising said  A more elegant solution
This is concentric with the shaft.
Posted: 01:56pm 05 Feb 2024
Oh, it's elegant ok. If it happens to fit the shaft and you are capable of re-balancing the shaft if needed, then yes. On the end of a 1500RPM mains synchronous motor with several kg of rotor om a variable frequency speed controller I wouldn't argue at all. On a little DC motor driving a gearbox and some wheels it's fine. Even at 3000RPM it would probably be fine. 20,000RPM is a different kettle of fish, especially when it has a precision cutting blade on the other end and you have to keep that blade cutting in the right place and to the right depth.
Posted: 09:42pm 05 Feb 2024
Hi All,
This is something I have been wondering about as well.
I only have a cheapo 3018 (standard NOT pro) and there is no way I would want to attach anything to the motor.
Ideas I have had before I saw this conversation were either of these.
As the shaft is bright silver I could paint a black line on the side and use a photo transistor to read when it spun around and feed this into a ’mite pin and use the COUNT input.
Or, if that didn’t work.
Create a variable strobe flash that I could tune till the black line stayed ‘static’ then I would know the speed because I know the flash rate of my strobe (probably bright white LED).
Interested in others views on this.
OA47
Posted: 09:44pm 05 Feb 2024
Thanks for the discussion, has anyone had any thoughts on using the audio from the spindle?
0A47
Posted: 10:20pm 05 Feb 2024
The pitch will be proportional to the speed but mechanical resonances from the motor and supporting structure may cause issues at some speeds.
Edit. Calibration may require another tacho method. Why build two?
Big Mick,  I tried a white LED and photo transistor but it was very fussy about ambient light and needed to be quite close to the shaft to reliably read the black stripe. White worked better as the shiny shaft reflects most of the light away from the sensor.
The IR optical method (earlier post) works much better with a stripe of any colour.
Best results are with white masking tape right round the shaft then colour one half with black marker pen.
Clean the surface with solvent first to help the tape stay stuck at high speed.
Edit. Or maybe instead of tape paint the shaft matte white first.
Edited 2024-02-06 08:31 by phil99
OA47
Posted: 10:32pm 05 Feb 2024
  Quote  The pitch will be proportional to the speed but mechanical resonances from the motor and supporting structure may cause issues at some speeds.
My biggest worry with an optical sensor is the cloud of dust that is produced when milling wood etc. I would at least have to detect the speed from the furtherest point away from the chuck which is a 52mm chromed plastic barrel fan. I would have to be careful not to put it out of balance.
0A47
OA47
Posted: 03:21am 06 Feb 2024
It seems that it is very hard to keep a piece of vinyl tape stuck on an object spinning at 20K rpm.
0A47
Posted: 06:10am 06 Feb 2024
Yes, also found vinyl tape useless. Not tried at 20k but masking tape sticks much better. Better still if the shaft is first wiped with a solvent such as metho.
OA47
Posted: 06:16am 06 Feb 2024
  Quote  Better still if the shaft is first wiped with a solvent such as metho.
I used isopropyl alcohol and I did need a dark colour as the fan is chrome plated.
0A47
Posted: 09:06am 06 Feb 2024
Can you see the spinning boss of the fan? That would be a good place, Or, depending on the number of fan blades, paint a mat black stripe on opposite blades or something.
A simple reflective sensor might be fine, just looking at the blades. Use a reflective 38kHz modulated IR type and divide the pulse rate by the number of blades.
