Local Time 18:30 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GameBoy Emulator for PicoMiteVGA HW
     Page 1 of 3
javavi
Posted: 02:05pm 13 Feb 2024
Adapted the pico-gameboy firmware of the GameBoy emulator for the PicoMiteVGA board
https://github.com/xrip/pico-gameboy
On the SD card, create a folder GB: in the root, put the ROM (*.gb *.gbc) files there.
Controls:  PS/2 Keyboard & NES Gamepad
UP, DOWN, LEFT, RIGHT - Arrow keys
A Button - Z key
B Button - X key
START - Enter key
SELECT - Backspace key
SELECT+START in game menu
The NES gamepad is connected like the PicoGAME VGA board
        NES_GPIO_CLK=  GP3
        NES_GPIO_LAT=  GP2
        NES_GPIO_DATA= GP1
Gamepad power supply is 3.3 V
Mono Audio on GP22
GameBoy_for_PicoMiteVGA.zip
Edited 2024-02-14 00:29 by javavi
javavi
Posted: 03:03pm 13 Feb 2024
Another version of the GameBoy firmware for the PicoGAME VGA board
       NES_GPIO_CLK=  GP3
       NES_GPIO_LAT=  GP2
       NES_GPIO_DATA= GP1
       PWM Audio on   GP6
GameBoy_for_PicoGAME_VGA.zip
Posted: 04:25pm 13 Feb 2024
Nice !!!
Plasmamac
Posted: 08:18pm 13 Feb 2024
cant test it atm. thx
Plasma
Amnesie
Posted: 09:17pm 13 Feb 2024
Wow, this is cool! Love old gameboy!
Thanks!
Greetings
Daniel
cosmic frog
Posted: 12:12pm 14 Feb 2024
Can't seem to get this to work on my PicoMiteVGA.
No output to the monitor and the pico just stays in BOOTSEL mode.
Dave.
Martin H.
Posted: 01:21pm 14 Feb 2024
sorry doesn't work here, just a screen with a few cryptic characters at the top left and a line by the button that says something like "<==page left page right ==>".
Also doesn't respond to the keyboard and resets when I press a controller key
'no comment
javavi
Posted: 05:21pm 14 Feb 2024
  Martin H. said  sorry doesn't work here, just a screen with a few cryptic characters at the top left and a line by the button that says something like "<==page left page right ==>".
On the SD card, a GB folder with cartridge images must be created in the root
javavi
Posted: 05:26pm 14 Feb 2024
  cosmic frog said  Can't seem to get this to work on my PicoMiteVGA.
What version of PicoMiteVGA board do you have?
(Ver.1.0 PWM or Ver.1.1 I2S )
Unfortunately, I don’t have the PicoMite board itself and I ported it on a breadboard assembly (photo at the beginning)
cosmic frog
Posted: 05:42pm 14 Feb 2024
Hi, it's just a PicoMiteVGA. It's built on a piece of proto board. I wasn't aware there was a special board.
Is there a schematic for this board so I could build it myself?
Thanks.
Dave.
javavi
Posted: 05:47pm 14 Feb 2024
PicoMiteVGA10_scheme.pdf
cosmic frog
Posted: 05:56pm 14 Feb 2024
Thanks.
I'll give it a go.
Dave.
javavi
Posted: 06:01pm 14 Feb 2024
PicoGAME VGA
https://github.com/thwill1000/pico-game-vga
PicoGAME VGA_14A Circuit.pdf
cosmic frog
Posted: 08:42pm 14 Feb 2024
Just looked at the schematics and the wiring is the same on my board, only the sound is wired to GP0 and GP1 so my board should work ok just without sound.
I will have to have another try.
Posted: 09:16pm 14 Feb 2024
I sort of recognise that board. :)
PicoGAME has GP0, GP1, GP2 and GP3 on Port A for the joystick/controller connections.
Edited 2024-02-15 07:17 by Mixtel90
javavi
Posted: 04:06am 15 Feb 2024
  Mixtel90 said  I sort of recognise that board. :)
Hi Mick,
I did an assembly for PicoGAME VGA using a NES gamepad connected to Port A, which uses GPIO ports for its operation: GP1, GP2, GP3
PWM sound on ports GP6, GP7
If you or anyone else needs it, I can change the connection as you please.
And, although the RTS is shown in this diagram, it is not used for the GameBoy emulator.
Best regards to everyone,
Java
cosmic frog
Posted: 10:51am 15 Feb 2024
Thanks for the great diagram javavi, this is very useful.
Would you be able to convert other consoles as well as the Gameboy on this platform?
Dave.
javavi
Posted: 11:23am 15 Feb 2024
Yes, this could be done, for example Sinclair Spectrum 48k and 128k!
But there is one point, I don’t know how to convey the Spectrum color palette (8 colors with two brightness levels) using the PicoMite VGA121 scheme!??
javavi
Posted: 11:30am 15 Feb 2024
Yes, I understand from the PicoGameVGA scheme that on port A to connect the NES joystick, pins 2,3,4 are used corresponding to the GPIO ports GP1, GP2, GP3
Martin H.
Posted: 01:43pm 15 Feb 2024
could be done , only missing Color is Bright White
Spectrum Colors
Scolors:
'Normal 8 Colors
Data 0,255,16711680,16711935,32768,33023,16744448,16777215
'With Bright
Data 0,16639,16728064,16728319,65280,65535,16776960,16777215
Normal 8 Colors
R  G  B
00 00 00 BLACK
00 00 FF BLUE
FF 00 00 RED
FF 00 FF MAGENTA
00 80 00 Green
00 80 FF Cyan
FF 80 00 Yellow
FF FF FF WHITE
With Bright on
R  G  B
00 00 00 BLACK
00 40 FF Light BLUE
FF 40 00 Light RED
FF 40 FF Light MAGENTA
00 FF 00 Light Green
00 FF FF Light Cyan
FF FF 00 Light Yellow
FF FF FF WHITE
see :
Open SCR file (ZX Spectrum standard screen)
Edited 2024-02-15 23:44 by Martin H.
'no comment
     Page 1 of 3
